Home » Archived » M2M (model-to-model transformation) » Where to get source code of ATL?
Where to get source code of ATL? [message #45652] |
Tue, 12 June 2007 23:02  |
Are ATL plugins open source, right? Currently, I'm working on Model
transformation based on ATL.Would you tell me where to get the source code
for ATL related plugins?
I need source code for following plugins:
org.atl.eclipse.adt.builder
org.atl.eclipse.adt.debug
org.atl.eclipse.adt.doc.developer
org.atl.eclipse.adt.doc.user
org.atl.eclipse.adt.editor
org.atl.eclipse.adt.perspective
org.atl.eclipse.adt.wizard
org.atl.eclipse.engine
org.atl.eclipse.km3
org.atl.engine.repositories.emf4atl
org.atl.engine.repositories.mdr4atl
org.atl.engine.vm
org.eclipse.am3.core
org.eclipse.am3.tools.tge
org.eclipse.am3.ui
Thanks a lot
Stephen
Re: [ATL] Where to get source code of ATL? [message #45745 is a reply to message #45715] |
Wed, 13 June 2007 02:38   |
Hi Frédéric,
Thanks for your reminder. However, I'm talking about the source code for
Build February 16, 2007 [the file I downloaded is
atl_am3-stable.zip.See:http://www.eclipse.org/m2m/atl/downlo ad/]
Just as you mentioned, I check out the source code from CVS, but they are
not the source code for the build Build February 16, 2007.
In addition, some source code are not found in
[ http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/?root=Modeling_Project],
for example org.atl.eclipse.km3 is not there, where to get its source code?
Thanks a lot.
Stephen Yu.
Frédéric Jouault wrote:
> Hello,
> Could you please prefix the subject of your ATL-related posts to this
> newsgroup with [ATL], as I did in this reply? Thanks.
> You can get the source of ATL the same way you get the source of every
> other Eclipse project: on the Eclipse CVS. The parameters for ATL are:
> Server: dev.eclipse.org
> Repository: /cvsroot/modeling
> Path: org.eclipse.m2m/org.eclipse.m2m.atl
> There is also a link to browse the CVS at the bottom of the ATL page
> (http://www.eclipse.org/m2m/atl/):
> Regards,
> Frédéric Jouault
> Stephen Yu wrote:
>> Hi,
>> code for ATL related plugins?
>> org.atl.eclipse.adt.builder org.atl.eclipse.adt.debug
>> org.atl.eclipse.adt.doc.developer org.atl.eclipse.adt.doc.user
>> org.atl.eclipse.adt.editor org.atl.eclipse.adt.perspective
>> org.atl.eclipse.adt.wizard org.atl.eclipse.engine org.atl.eclipse.km3
>> org.atl.engine.repositories.emf4atl org.atl.engine.repositories.mdr4atl
>> org.atl.engine.vm org.eclipse.am3.core org.eclipse.am3.tools.tge
>> org.eclipse.am3.ui
>> Thanks a lot
>> Stephen
Re: [ATL] Where to get source code of ATL? [message #45775 is a reply to message #45745] |
Wed, 13 June 2007 02:55   |
CVS keeps the history of everything that happened. If you want the
source code for a given date, just ask ;-).
Note that if the date you are interested in is before the migration of
ATL from GMT to M2M you have to use the GMT CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/ATL /?root=Technology_Project
The KM3 plugin did not follow the migration of ATL from GMT to M2M, and
is now in AM3 (see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /?root=Technology_Project).
Frédéric Jouault
Stephen Yu wrote:
> Hi Frédéric,
> are not the source code for the build Build February 16, 2007.
> Thanks a lot.
> Stephen Yu.
>> Hello,
>> Regards,
>> Frédéric Jouault
>> Stephen Yu wrote:
>>> Hi,
>>> org.atl.engine.repositories.mdr4atl org.atl.engine.vm
>>> org.eclipse.am3.ui
>>> Thanks a lot
>>> Stephen
Re: [ATL] Where to get source code of ATL? [message #45807 is a reply to message #45775] |
Wed, 13 June 2007 03:41   |
I got all the source code now. Thank you so much!
Stephen
> Hello,
> is now in AM3 (see
> Regards,
> Frédéric Jouault
> Stephen Yu wrote:
>> Hi Frédéric,
>> Thanks a lot.
>> Stephen Yu.
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>> Stephen Yu wrote:
>>>> Hi,
>>>> org.eclipse.am3.ui
>>>> Thanks a lot
>>>> Stephen
Current Time: Sat Jul 26 16:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.05178 seconds
