Home » Eclipse Projects » Standard Widget Toolkit (SWT) » table row height
table row height [message #455964] Tue, 24 May 2005 06:44 Go to next message
hello
how to change table row height ?
when I place an image (16x16) in row the row becomes higher (better to read)
is there any other way to get higher rows without placing icons ?
there is no such method setRowHeight(int)... (there is only getRowHeight())
is it possible to change the row height ?
im using eclipse 3.02
thanks
Artur
Re: table row height [message #455981 is a reply to message #455964] Tue, 24 May 2005 10:19 Go to previous messageGo to next message
Not right now. Windows controls use the hieght of the first image assigned
to the table to control the row height of the table.
"Artur" <artekzx@o2.pl> wrote in message
news:d6v0oo$9ls$1@news.eclipse.org...
> hello
read)
getRowHeight())
> thanks
> Artur
Re: table row height [message #703558 is a reply to message #455981] Wed, 27 July 2011 13:31 Go to previous message
This seems to work for me (I found this someplace the other day from Google):
table.addListener(SWT.MeasureItem, new Listener() {
   public void handleEvent(Event event) {
      // height cannot be per row so simply set
      event.height = 28;
That being said, I'm using Steve's rule of letting the first image determine the row size. Just wanted to put this out here as an alternative.
-Kevin
Previous Topic:Custom Widget Not Displaying When Using
Next Topic:How can i catch a message asking if you want to install flash plugins?
Current Time: Fri Jul 18 09:14:22 EDT 2025
Powered by FUDForum. Page generated in 0.32368 seconds
