Home » Eclipse Projects » Rich Client Platform (RCP) » IExtensionRegistry question
IExtensionRegistry question [message #455286] Wed, 20 September 2006 07:33 Go to next message
Originally posted by: osipov.appliedtech.ru
Hi everybody!
Could you, please, help me out with this interface? My question is just the
same as the one here:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg16126.html
The problem is that nobody answered that post.
So, where should I get the second parameter to be able to call the following
method without causing an exception?
public boolean removeExtension(IExtension extension, Object token) throws
IllegalArgumentException;
Thanks very much in advance for your help.
Re: IExtensionRegistry question [message #455309 is a reply to message #455286] Wed, 20 September 2006 08:38 Go to previous messageGo to next message
Peter Osipov wrote:
> Hi everybody!
Actually, I just found that out yesterday. There are 2 tokens available
to the registry, a master token and a user token. The master token is
what controls the registry, and allows addition and removals of
anything. The user token allows the addition and removal of
"unpersisted" extension registry objects.
The master token is an internal object. The user token is an internal
object, but it can be set to null using the property
IRegistryConstants.PROP_REGISTRY_NULL_USER_TOKEN in an RCP app.
That allows the RCP app to add/remove the unpersisted elements.
Everything in the a plugin.xml is persisted, so you can't change exiting
extensions, just add to them.
In 3.3 they considering a product based "transformer" that would allow
the product to apply XSLT transforms to incoming plugin.xml (which would
allow you to remove certain entries before they even get into the
extension registry).
Later,
PW
Re: IExtensionRegistry question [message #455323 is a reply to message #455309] Wed, 20 September 2006 23:58 Go to previous messageGo to next message
Hi, Paul!
Thanks very much for your answer. It clears up everything. As far as I
understand, you are saying that I cannot remove an extension point. What I
needed to do is to optionally remove an extension point in a plugin.xml
depending on a type of license the user has. That extension is declaring a
view. So, let us what until we move to 3.3. It is the only opportunity, as I
understand, right?
> Peter Osipov wrote:
> > Hi everybody!
the
following
throws
> Later,
> PW
Re: IExtensionRegistry question [message #455332 is a reply to message #455323] Thu, 21 September 2006 08:55 Go to previous messageGo to next message
Peter Osipov wrote:
> Hi, Paul!
> understand, right?
yeah, although there are 3.2 options if this is about controlling one of
your own plugins.
1) you can create an activity (and possibly capability) for your view.
Default the activity to false, and the view shouldn't show up anywhere
in the UI. Check the license, and then turn the activity on if it
checks out.
2) Use the additive approach. Don't include the view config element in
your plugin.xml. When you start up, check the license, and if it is
valid use the IExtensionRegistry null user token to add the <view/>
config element to the org.eclipse.ui.views extension point.
Option 1 is the most commonly used option. The difference between them
is option 1 is all about hiding things from the User in the UI, and
option 2 hides them (or shows them) from the extension registry itself.
Later,
PW
Re: IExtensionRegistry question [message #455357 is a reply to message #455332] Fri, 22 September 2006 00:53 Go to previous messageGo to next message
Hi, Paul.
Thanks very much for that! It is really a view of my own, i.e. I am
declaring it in fact.
You are very smart. :-) thank you very much indeed for you support.
> Peter Osipov wrote:
> > Hi, Paul!
I
a
as I
> > understand, right?
> your own plugins.
> checks out.
> Later,
> PW
Re: IExtensionRegistry question [message #455519 is a reply to message #455309] Thu, 28 September 2006 04:34 Go to previous messageGo to next message
Hi Paul,
Could you please post a pointer to a source of the info on the XSL
tranformer route that is being considered for 3.3? I searched the web but
couldn't find anything. Would be great to know where things are moving with
that.
Thanks!
-Andrei
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:eercsj$310$1@utils.eclipse.org...
> Peter Osipov wrote:
>> Hi everybody!
>> the
>> following
> what controls the registry, and allows addition and removals of anything.
> The user token allows the addition and removal of "unpersisted" extension
> registry objects.
> That allows the RCP app to add/remove the unpersisted elements. Everything
> in the a plugin.xml is persisted, so you can't change exiting extensions,
> just add to them.
> In 3.3 they considering a product based "transformer" that would allow the
> product to apply XSLT transforms to incoming plugin.xml (which would allow
> you to remove certain entries before they even get into the extension
> registry).
> Later,
> PW
Re: IExtensionRegistry question [message #455535 is a reply to message #455519] Thu, 28 September 2006 21:38 Go to previous messageGo to next message
Andrei Lissovski wrote:
> Hi Paul,
> that.
So the plan item it would be covered under is Customization,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154099
although I don't see anything posted there about XSLT.
Later,
PW
Re: IExtensionRegistry question [message #455928 is a reply to message #455332] Tue, 10 October 2006 06:32 Go to previous messageGo to next message
------=_NextPart_000_0125_01C6EC89.A26090B0
Content-Type: text/plain;
charset="UTF-8"
Content-Transfer-Encoding: quoted-printable
Hi Paul!
Could you please give another piece of advice?
Well, I read tons of information on adding contribution items
dynamically and I still cannot make it work. Here is how I am attempting =
to add a view in my plugin when its method start is called. You can see =
there is some hacking techniques but I tried to make it work anyway =
which did not help anyway:
IExtensionRegistry reg =3D RegistryFactory.getRegistry();
Object masterKey =3D =
null;//((ExtensionRegistry)reg).getTemporaryUserToken();
Field [] declaredFields =3D reg.getClass().getDeclaredFields();
for (int i =3D 0; i < declaredFields.length; i++)
Field field =3D declaredFields[i];
String strName =3D field.getName();
if (strName.equalsIgnoreCase("masterToken"))
field.setAccessible(true);
try
masterKey =3D field.get(reg);
break;
catch (IllegalArgumentException exception)
exception.printStackTrace();
catch (IllegalAccessException exception)
Bundle bundle =3D context.getBundle();
IContributor contributor =3D ContributorFactoryOSGi
.createContributor(bundle);
try
StringBuffer stringBuffer =3D new StringBuffer();
stringBuffer.append("<?xml version=3D\"1.0\" =
encoding=3D\"UTF-8\"?>");
stringBuffer.append(StringConst.CRLF);
stringBuffer.append("<?eclipse version=3D\"3.0\"?>");
stringBuffer.append("<extension =
point=3D\"org.eclipse.ui.views\">");
stringBuffer.append("<view");
stringBuffer.append("icon=3D\"icons/objects/users.gif\"");
stringBuffer
..append("class=3D\"com.stuff.ide.admin.views.security.SecurityManagerView=
stringBuffer.append("category=3D\"com.stuff.ide.views\"");
stringBuffer.append("name=3D\"%securityManagerView\"");
stringBuffer
..append("id=3D\"com.stuff.ide.admin.views.security.SecurityManagerView\ "/=
stringBuffer.append("</extension>");
=20
String strXML =3D stringBuffer.toString();
if (OTCLicense.present())
org.apache.tools.ant.filters.StringInputStream =
stringInputStream =3D new =
org.apache.tools.ant.filters.StringInputStream(
strXML)
=20
public synchronized void close() throws IOException
try
super.close();
catch (NullPointerException ignore)
// that parser is disposing this stream as =
well as=20
// method addContribution and that causes an =
NPE
reg.addContribution(stringInputStream, contributor, =
true,
null, null, masterKey);
catch (Exception e)
e.printStackTrace();
Am I on the right track or not? I mean here =
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D112954 you guys say how =
to do it. But when and how exactly - no.
Could you please give me a clue?
"Paul Webster" <pwebster@ca.ibm.com> =
=D1=81=D0=BE=D0=BE=D0=B1=D1=89=D0=B8=D0=BB/=D1=81=D0=BE=D0=B E=D0=B1=D1=89=
=D0=B8=D0=BB=D0=B0 =D0=B2 =
=D0=BD=D0=BE=D0=B2=D0=BE=D1=81=D1=82=D1=8F=D1=85 =
=D1=81=D0=BB=D0=B5=D0=B4=D1=83=D1=8E=D1=89=D0=B5=D0=B5: =
news:eeu29c$nf3$1@utils.eclipse.org...
> Peter Osipov wrote:
> > Hi, Paul!
> > Thanks very much for your answer. It clears up everything. As far as =
I
> > understand, you are saying that I cannot remove an extension point. =
What I
> > needed to do is to optionally remove an extension point in a =
plugin.xml
> > depending on a type of license the user has. That extension is =
declaring a
> > view. So, let us what until we move to 3.3. It is the only =
opportunity, as I
> > understand, right?
>=20
> yeah, although there are 3.2 options if this is about controlling one =
of=20
> your own plugins.
>=20
> 1) you can create an activity (and possibly capability) for your view. =
> Default the activity to false, and the view shouldn't show up anywhere =
> in the UI. Check the license, and then turn the activity on if it=20
> checks out.
>=20
> 2) Use the additive approach. Don't include the view config element =
in=20
> your plugin.xml. When you start up, check the license, and if it is=20
> valid use the IExtensionRegistry null user token to add the <view/>=20
>=20
> Option 1 is the most commonly used option. The difference between =
them=20
> is option 1 is all about hiding things from the User in the UI, and=20
> option 2 hides them (or shows them) from the extension registry =
itself.
>=20
> Later,
> PW
Content-Type: text/html;
charset="UTF-8"
=EF=BB=BF<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dutf-8">
<META content=3D"MSHTML 6.00.2800.1561" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3D"Arial Cyr" size=3D2>Hi Paul!<BR>Could you please give =
another=20
piece of advice?<BR>Well, I read tons of information on adding =
contribution=20
items<BR>dynamically and I still cannot make it work. Here is how I am=20
attempting to add a view in my plugin when its method =
<STRONG>start</STRONG> is=20
called. You can see there is some hacking techniques but I tried to make =
it work=20
anyway which did not help anyway:</FONT></DIV><FONT face=3D"Arial Cyr" =
size=3D2>
<P class=3DMsoNormal=20
style=3D"MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"><SPAN =
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US"><SPAN=20
style=3D"mso-spacerun: yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;=20
</SPAN>IExtensionRegistry <I>reg</I> =3D=20
RegistryFactory.<I>getRegistry</I>();</SPAN><SPAN lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'; mso-ansi-language: =
EN-US"><?xml:namespace=20
prefix =3D o ns =3D "urn:schemas-microsoft-com:office:office"=20
/><o:p></o:p></SPAN></P>
lang=3DEN-US=20
</SPAN>Object <I>masterKey</I> =3D </SPAN><B><SPAN lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #7f0055; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US">null</SPAN></B><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">;<SPAN=20
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #3f7f5f; FONT-FAMILY: 'Courier New'; =
EN-US">//((ExtensionRegistry)reg).getTemporaryUserToken();</SPAN ><SPAN=20
lang=3DEN-US=20
EN-US"><o:p></o:p></SPAN></P></SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>Field [] <I>declaredFields</I> =3D=20
<I>reg</I>.<B>getClass</B>().<B>getDeclaredFields</B >();</SPAN><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN></SPAN><B><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">for</SPAN></B><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">=20
(</SPAN><B><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">int</SPAN></B><SPAN=20
lang=3DEN-US=20
<I>i</I> =3D 0; <I>i</I> &lt; <I>declaredFields</I>.</SPAN><B><SPAN =
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #0000c0; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US">length</SPAN></B><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">;=20
<I>i</I>++)</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>{</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-spacerun: =
yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
</SPAN>Field <I>field</I> =3D =
<I>declaredFields</I>[<I>i</I>];</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>String <I>strName</I> =3D =
<I>field</I>.<B>getName</B>();</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">if</SPAN></B><SPAN=20
lang=3DEN-US=20
(<I>strName</I>.<B>equalsIgnoreCase</B>(</SPAN><SPAN lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #2a00ff; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US">"masterToken"</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">))</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
</SPAN><I>field</I>.<B>setAccessible</B>(</SPAN><B ><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">true</SPAN></B><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">);</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">try</SPAN></B><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;=20
</SPAN><I>masterKey</I> =3D =
<I>field</I>.<B>get</B>(<I>reg</I>);</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">break</SPAN></B><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">;</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>}</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">catch</SPAN></B><SPAN=20
lang=3DEN-US=20
(IllegalArgumentException <I>exception</I>)</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
</SPAN></SPAN><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier =
New'">{</SPAN><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier =
New'"><o:p></o:p></SPAN></P>
style=3D"MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"><SPAN=20
New'"><SPAN=20
</SPAN><I>exception</I>.<B>printStackTrace</B>();</SPAN ><SPAN=20
New'"><SPAN=20
</SPAN>}</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
(IllegalAccessException <I>exception</I>)</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
New'"><SPAN=20
New'"><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>Bundle <I>bundle</I> =3D =
<B>context</B>.<B>getBundle</B>();</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>IContributor <I>contributor</I> =3D =
ContributorFactoryOSGi</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>.<I>createContributor</I>(<I>bundle</I>);</SPAN ><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp; </SPAN><SPAN=20
yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN><B><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: #7f0055; FONT-FAMILY: 'Courier =
New'">try</SPAN></B><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>StringBuffer <I>stringBuffer</I> =3D </SPAN><B><SPAN lang=3DEN-US =
mso-ansi-language: EN-US">new</SPAN></B><SPAN=20
lang=3DEN-US=20
<B>StringBuffer</B>();</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
</SPAN><I>stringBuffer</I>.<B>append</B>(</SPAN><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">"&lt;?xml=20
version=3D\"1.0\" encoding=3D\"UTF-8\"?&gt;"</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN><I>stringBuffer</I>.<B>append</B>(StringConst. </SPAN><I><SPAN =
lang=3DEN-US=20
mso-ansi-language: EN-US">CRLF</SPAN></I><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"&lt;?eclipse=20
version=3D\"3.0\"?&gt;"</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"&lt;extension=20
point=3D\"org.eclipse.ui.views\"&gt;"</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"&lt;view"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
EN-US">"icon=3D\"icons/objects/users.gif\""</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN><I>stringBuffer</I></SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>.<B>append</B>(</SPAN><SPAN lang=3DEN-US=20
EN-US">"class=3D\"com.stuff.ide.admin.views.security.SecurityManagerView\=
""</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
EN-US">"category=3D\"com.stuff.ide.views\""</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"name=3D\"%securityManagerView\""</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp;</SPAN><SPAN=20
yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
EN-US">"id=3D\"com.stuff.ide.admin.views.security.SecurityManagerView\ "/&=
gt;"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"&lt;/extension&gt;"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
EN-US">&nbsp;<o:p></o:p></SPAN></P>
lang=3DEN-US=20
</SPAN>String <I>strXML</I> =3D =
<I>stringBuffer</I>.<B>toString</B>();</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
(OTCLicense.<I>present</I>())</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>org.apache.tools.ant.filters.StringInputStream =
<I>stringInputStream</I> =3D=20
lang=3DEN-US=20
org.apache.tools.ant.filters.<B>StringInputStream</B>(</SPAN ><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN><SPAN=20
bsp;&nbsp;&nbsp;&nbsp;&nbsp;</SPAN><I>strXML </I>)</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
Re: IExtensionRegistry question [message #455929 is a reply to message #455928] Tue, 10 October 2006 06:34 Go to previous messageGo to next message
------=_NextPart_000_013E_01C6EC89.F25E5160
charset="UTF-8"
I am sorry if I bothered anybody by posting the previous message in a =
html format, but I wanted just to save original formating for the code. =
So, do not be aggravated. :-)
"Peter Osipov" <osipov@appliedtech.ru> =
news:egfsrh$a0r$1@utils.eclipse.org...
Hi Paul!
dynamically and I still cannot make it work. Here is how I am =
attempting to add a view in my plugin when its method start is called. =
You can see there is some hacking techniques but I tried to make it work =
Field [] declaredFields =3D =
try
break;
try
stringBuffer
stringBuffer
=20
strXML)
=20
public synchronized void close() throws =
IOException
try
super.close();
well as=20
// method addContribution and that causes =
an NPE
true,
catch (Exception e)
> Peter Osipov wrote:
> > Hi, Paul!
> > Thanks very much for your answer. It clears up everything. As far =
as I
> > understand, you are saying that I cannot remove an extension =
point. What I
plugin.xml
declaring a
opportunity, as I
> > understand, right?
>=20
> yeah, although there are 3.2 options if this is about controlling =
one of=20
> your own plugins.
>=20
> 1) you can create an activity (and possibly capability) for your =
view.=20
> Default the activity to false, and the view shouldn't show up =
anywhere=20
> checks out.
>=20
in=20
> your plugin.xml. When you start up, check the license, and if it is =
>=20
them=20
itself.
>=20
> Later,
> PW
charset="UTF-8"
<HTML xmlns:o =3D "urn:schemas-microsoft-com:office:office"><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3D"Arial CYR" size=3D2>I am sorry if I =
bothered&nbsp;anybody by=20
posting the previous message in a html format, but I wanted just to save =
original formating for the code. So, do not be aggravated. =
:-)</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Peter Osipov" &lt;<A=20
href=3D"mailto:osipov@appliedtech.ru">osipov@appliedtech.ru</A>&gt;=20
=D1=81=D0=BB=D0=B5=D0=B4=D1=83=D1=8E=D1=89=D0=B5=D0=B5: <A=20
href=3D"news:egfsrh$a0r$1@utils.eclipse.org">news:egfsrh$a0r$1@utils.ecli=
pse.org</A>...</DIV>
<DIV><FONT face=3D"Arial Cyr" size=3D2>Hi Paul!<BR>Could you please =
give another=20
contribution=20
items<BR>dynamically and I still cannot make it work. Here is how I am =
<STRONG>start</STRONG>=20
is called. You can see there is some hacking techniques but I tried to =
make it=20
work anyway which did not help anyway:</FONT></DIV><FONT face=3D"Arial =
Cyr"=20
size=3D2>
lang=3DEN-US=20
style=3D"mso-spacerun: yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; =
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US"><o:p></o:p></SPAN></P>
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US"><o:p></o:p></SPAN></P></SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
<I>reg</I>.<B>getClass</B>().<B>getDeclaredFields</B >();</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
New'"><SPAN=20
New'"><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
New'"><SPAN=20
New'"><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>StringBuffer <I>stringBuffer</I> =3D </SPAN><B><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN><I>stringBuffer</I>.<B>append</B>(StringConst. </SPAN><I><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
""</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
gt;"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&nbsp;<o:p></o:p></SPAN></P>
lang=3DEN-US=20
</SPAN>String <I>strXML</I> =3D=20
<I>stringBuffer</I>.<B>toString</B>();</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
Re: IExtensionRegistry question [message #455992 is a reply to message #455535] Tue, 10 October 2006 10:38 Go to previous messageGo to next message
Are you referring to
http://eclipse.pookzilla.net/2006/08/enough-rope-to-hang-you rself-with.php
There's a patch, but I don't know if it ever got brought into production.
Alex.
Re: IExtensionRegistry question [message #456009 is a reply to message #455992] Tue, 10 October 2006 20:54 Go to previous messageGo to next message
Yes, Pookzilla said they were still considering the functionality (but
it's not available yet).
Later,
PW
Re: IExtensionRegistry question [message #456010 is a reply to message #455928] Tue, 10 October 2006 21:34 Go to previous messageGo to next message
Peter Osipov wrote:
> Hi Paul!
> to add a view in my plugin when its method *start* is called. You can
> see there is some hacking techniques but I tried to make it work anyway
Here's what I did. I create an RCP app and ran it with
-Declipse.registry.nulltoken=true ... that means the user token will be
null.
Then I created a resource file (new_command.xml) with the extension I
wanted to add:
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.ui.commands">
<command
name="Down Message Dialog"
description="Down a message dialog"
categoryId="z.ex.rcp.mail.registry.category"
id="z.ex.rcp.mail.registry.downMessage">
</command>
</extension>
</plugin>
Then in my action code:
IExtensionRegistry ereg = Platform.getExtensionRegistry();
IContributor contributor = ContributorFactoryOSGi
.createContributor(Activator.getDefault().getBundle());
boolean rc = ereg.addContribution(getClass().getResourceAsStream(
"new_command.xml"), contributor, false, "add new command",
null, null);
It returned true. Before this code runs my commnad is undefined, but
after the command is defined (which means this should have made it into
the registry).
There doesn't seem to be anything obviously wrong in your code, so I'd
start off by putting your view XML in a resource file and reading that
in. That'll help eliminate if the problem is in your java encoded xml.
I'd also try getting the registry from Platform unless you have a good
reason not to.
Good luck.
Later,
PW
Re: IExtensionRegistry question [message #456017 is a reply to message #456010] Tue, 10 October 2006 23:45 Go to previous messageGo to next message
Hi Paul!
Thanks very much indeed for your answer. Yep, my code seems very much alike.
Could you please tell me another thing - where did you put your code? As for
me I am placing in a special plugin's class inheriting AbstractUIPlugin. And
there in method start. Is that right?
And what kind of Activator are you using? I have tried all of them and none
had a proper sequence of method calls Activator.getDefault().getBundle())
Thank you very much post factum and in advance and for you help!
Re: IExtensionRegistry question [message #456019 is a reply to message #456010] Wed, 11 October 2006 02:05 Go to previous message
------=_NextPart_000_00F8_01C6ED2D.7F980BE0
charset="UTF-8"
Hi, Paul.
Anyway, Paul! I figured it out!
I want to share this fully, because I hate coming on the forum across =
answers:=E2=80=9DO, eh! I did it!Hurray for me!=E2=80=9D and no =
explanation on how he or she did it. This is how I did it in detail.
I went to plugin.xml and saw this:
<extension
point=3D"org.eclipse.ui.views">
<view
name=3D"%repositoryManagerViewName"
icon=3D"icons/objects/repo_rep.gif"
category=3D"com.stuff.ide.views"
class=3D"com.stuff.ide.admin.views.manager.RepositoryManagerView "
id=3D"com.stuff.ide.admin.views.manager.RepositoryManagerView ">
</view>
<view
icon=3D"icons/objects/users.gif"
class=3D"com.stuff.ide.admin.views.security.SecurityManagerView "
name=3D"%securityManagerView"
id=3D"com.stuff.ide.admin.views.security.SecurityManagerView "/>
</extension>
I removed the second one and was left only with this:
<extension
<view
</view>
</extension>
Then I went to the class inheriting AbstractUIPlugin in the plugin and =
in overloaded method start before super.start() I am calling the =
following method:=20
* @param context
private void preStart(BundleContext context)
if(OTCLicense.present())
Object userKey =3D =
InputStream inputStream =3D getClass().getResourceAsStream(
"users_and_groups_view.xml"); // $IGNORE_NLS_LINE
boolean rc =3D reg.addContribution(inputStream, contributor, =
false,
"add security view", ResourceTranslator // =
$IGNORE_NLS_LINE
.getResourceBundle(bundle), userKey);
return;
File users_and_groups_view.xml should be in the package where the class =
inheriting AbstractUIPlugin. There I wrote down the following:
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<?eclipse version=3D"3.2"?>
<plugin>
<extension point=3D"org.eclipse.ui.views">
<view icon=3D"icons/objects/users.gif"
</extension>
</plugin>
> Peter Osipov wrote:
> > Hi Paul!
attempting=20
> > to add a view in my plugin when its method *start* is called. You =
can=20
anyway=20
>=20
>=20
>=20
> Here's what I did. I create an RCP app and ran it with=20
> -Declipse.registry.nulltoken=3Dtrue ... that means the user token will =
be=20
> null.
>=20
> Then I created a resource file (new_command.xml) with the extension I=20
> wanted to add:
> <plugin>
>=20
> <extension
> point=3D"org.eclipse.ui.commands">
> <command
> name=3D"Down Message Dialog"
> description=3D"Down a message dialog"
> categoryId=3D"z.ex.rcp.mail.registry.category"
> id=3D"z.ex.rcp.mail.registry.downMessage">
> </command>
> </extension>
>=20
> </plugin>
>=20
>=20
> IExtensionRegistry ereg =3D Platform.getExtensionRegistry();
> boolean rc =3D ereg.addContribution(getClass().getResourceAsStream(
> null, null);
>=20
> It returned true. Before this code runs my commnad is undefined, but=20
> after the command is defined (which means this should have made it =
into=20
> the registry).
>=20
> There doesn't seem to be anything obviously wrong in your code, so I'd =
> start off by putting your view XML in a resource file and reading that =
> in. That'll help eliminate if the problem is in your java encoded =
xml.
>=20
> I'd also try getting the registry from Platform unless you have a good =
> reason not to.
>=20
> Good luck.
>=20
> Later,
> PW
charset="UTF-8"
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial>Hi, Paul.</FONT></DIV>
<DIV><FONT face=3DArial>Anyway, Paul! I figured it out!</FONT></DIV>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><SPAN lang=3DEN-US=20
style=3D"FONT-FAMILY: Arial; mso-ansi-language: EN-US"><FONT size=3D3>I =
want to=20
answers:=E2=80=9DO, eh! I=20
did it!Hurray for me!=E2=80=9D and no explanation on how he or she did =
it. This is how I=20
did it in detail.<?xml:namespace prefix =3D o ns =3D=20
"urn:schemas-microsoft-com:office:office" =
/><o:p></o:p></FONT></SPAN></P>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><FONT size=3D3><SPAN =
lang=3DEN-US=20
style=3D"FONT-FAMILY: Arial; mso-ansi-language: EN-US">I went to =
plugin.xml and=20
saw this:</SPAN><SPAN lang=3DEN-US=20
style=3D"mso-ansi-language: EN-US"><o:p></o:p></SPAN></FONT></P>
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #0000e1; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US">&lt;extension<o:p></o:p></SPAN></P>
lang=3DEN-US=20
yes"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;=20
</SPAN></SPAN><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">point=3D</SPAN><SPAN=20
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'; =
mso-ansi-language: EN-US">"org.eclipse.ui.views"</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&gt;<o:p></o:p></SPAN></P>
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;view<o:p></o:p></SPAN></P>
lang=3DEN-US=20
mso-ansi-language: EN-US">name=3D</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"%repositoryManagerViewName"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">icon=3D</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"icons/objects/repo_rep.gif"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">category=3D</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"com.stuff.ide.views"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">class=3D</SPAN><SPAN=20
lang=3DEN-US=20
EN-US">"com.stuff.ide.admin.views.manager.RepositoryManagerView "</SPAN><S=
PAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">id=3D</SPAN><SPAN=20
lang=3DEN-US=20
PAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;/view&gt;<o:p></o:p></SPAN></P>
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"icons/objects/users.gif"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
EN-US">"com.stuff.ide.admin.views.security.SecurityManagerView "</SPAN><SP=
AN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"%securityManagerView"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
AN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">/&gt;<o:p></o:p></SPAN></P>
style=3D"FONT-SIZE: 10pt; COLOR: #0000e1; FONT-FAMILY: 'Courier =
New'">&lt;/extension&gt;<o:p></o:p></SPAN></P>
lang=3DEN-US=20
style=3D"COLOR: black; FONT-FAMILY: Arial; mso-ansi-language: EN-US">I =
removed the=20
second one and was left only with this:</SPAN><SPAN lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #0000e1; FONT-FAMILY: 'Arial Unicode =
MS'; mso-ansi-language: EN-US; mso-fareast-font-family: 'Times New =
Roman'"><o:p></o:p></SPAN></FONT></P>
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp; </SPAN></SPAN><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
PAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
PAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
<P style=3D"MARGIN: 0in 0in 0pt"><SPAN lang=3DEN-US=20
Roman'"><SPAN=20
style=3D"mso-spacerun: yes">&nbsp;</SPAN></SPAN><SPAN lang=3DEN-US=20
Roman'">&lt;/extension&gt;</SPAN><SPAN=20
lang=3DEN-US=20
style=3D"FONT-SIZE: 10pt; COLOR: #0000e1; FONT-FAMILY: 'Times New =
Roman'; mso-ansi-language: EN-US"><o:p></o:p></SPAN></P>
style=3D"FONT-FAMILY: Arial; mso-ansi-language: EN-US"><FONT =
size=3D3>Then I went to=20
the class <SPAN style=3D"COLOR: black">inheriting</SPAN> =
</FONT></SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">AbstractUIPlugin</SPAN><FONT=20
size=3D3><SPAN lang=3DEN-US style=3D"FONT-FAMILY: Arial; =
mso-ansi-language: EN-US"> in=20
the plugin and in overloaded method start before super.start() I am =
calling the=20
following method: </SPAN><SPAN lang=3DEN-US=20
style=3D"MARGIN: 0in 0in 0pt; mso-layout-grid-align: none"><FONT =
size=3D3><FONT=20
face=3D"Times New Roman"><SPAN lang=3DEN-US=20
style=3D"COLOR: #7f0055; mso-ansi-language: EN-US"><SPAN=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;=20
</SPAN><STRONG>/**</STRONG></SPAN><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US"><o:p></o:p></SPAN></FONT></FONT></P>
size=3D3><FONT=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; =
</SPAN><STRONG>*</STRONG>=20
<STRONG>@param</STRONG> <STRONG>context</STRONG></SPAN><SPAN =
lang=3DEN-US=20
size=3D3><FONT=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;=20
</SPAN><STRONG>*/</STRONG></SPAN><SPAN lang=3DEN-US=20
size=3D3><FONT=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; =
</SPAN><STRONG>private</STRONG>=20
<STRONG>void</STRONG> <STRONG>preStart</STRONG>(BundleContext=20
<STRONG>context</STRONG>)</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>{</SPAN><SPAN =
lang=3DEN-US=20
size=3D3><FONT=20
</SPAN><STRONG>if</STRONG>(OTCLicense.<I>present</I>()) </SPAN><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>Object <I>userKey</I> =3D=20
((ExtensionRegistry)<I>reg</I>).<STRONG>getTemporaryUserToken </STRONG>();=
</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>Bundle <I>bundle</I> =3D=20
<STRONG>context</STRONG>.<STRONG>getBundle</STRONG>(); </SPAN><SPAN =
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN><SPAN style=3D"mso-spacerun: yes">&nbsp;</SPAN>IContributor=20
<I>contributor</I> =3D ContributorFactoryOSGi</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>InputStream <I>inputStream</I> =3D=20
<STRONG>getClass</STRONG>().<STRONG>getResourceAsStream </STRONG>(</SPAN><=
SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"users_and_groups_view.xml"</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">);=20
mso-ansi-language: EN-US">//=20
$IGNORE_NLS_LINE</SPAN><SPAN lang=3DEN-US=20
size=3D3><FONT=20
</SPAN><STRONG>boolean</STRONG> <I>rc</I> =3D=20
<I>reg</I>.<STRONG>addContribution</STRONG>(<I>inputStream </I>,=20
<I>contributor</I>, <STRONG>false</STRONG>,</SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"add=20
security view"</SPAN><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">,=20
ResourceTranslator </SPAN><SPAN lang=3DEN-US=20
lang=3DEN-US=20
</SPAN>.<I>getResourceBundle</I>(<I>bundle</I>), =
<I>userKey</I>);</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
New'">}</SPAN><SPAN=20
size=3D3><FONT=20
face=3D"Times New Roman"><SPAN style=3D"COLOR: #7f0055"><SPAN=20
</SPAN><STRONG>return</STRONG>;</SPAN><SPAN=20
New'"><o:p></o:p></SPAN></FONT></FONT></P>
New'"><SPAN=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>}</SPAN><SPAN=20
style=3D"COLOR: #7f0055; FONT-FAMILY: 'Arial Unicode MS'; =
mso-fareast-font-family: 'Times New Roman'"><o:p></o:p></SPAN></P>
lang=3DEN-US=20
style=3D"COLOR: black; FONT-FAMILY: Arial; mso-ansi-language: =
EN-US">File</SPAN><SPAN=20
lang=3DEN-US style=3D"COLOR: black; mso-ansi-language: EN-US"><FONT=20
face=3D"Times New Roman">&nbsp;</FONT></SPAN></FONT><SPAN lang=3DEN-US=20
mso-ansi-language: EN-US">users_and_groups_view.xml&nbsp;</SPAN><FONT=20
size=3D3><SPAN lang=3DEN-US=20
EN-US">should be in=20
the package where the class inheriting</SPAN><SPAN lang=3DEN-US=20
style=3D"FONT-FAMILY: Arial; mso-ansi-language: EN-US"> =
</SPAN></FONT><SPAN=20
lang=3DEN-US=20
style=3D"COLOR: black; FONT-FAMILY: Arial; mso-ansi-language: EN-US">. =
There I=20
wrote down the following:</SPAN><SPAN lang=3DEN-US=20
style=3D"COLOR: #7f0055; mso-ansi-language: =
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;?xml</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">version=3D</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"1.0"</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">encoding=3D</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">"UTF-8"</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">?&gt;</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;?eclipse</SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">version=3D"3.2"</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;plugin&gt;</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;extension</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&gt;</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN><SPAN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">&lt;view</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
style=3D"mso-tab-count: =
2"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
</SPAN><SPAN style=3D"mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
lang=3DEN-US=20
AN=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
lang=3DEN-US=20
AN=20
lang=3DEN-US=20
mso-ansi-language: EN-US">/&gt;</SPAN><SPAN=20
lang=3DEN-US=20
lang=3DEN-US=20
New'">&lt;/extension&gt;</SPAN><SPAN=20
New'"><o:p></o:p></SPAN></P><SPAN=20
mso-ansi-language: RU; mso-fareast-font-family: 'Times New Roman'; =
mso-fareast-language: RU; mso-bidi-language: =
AR-SA">&lt;/plugin&gt;</SPAN><BR></DIV></FONT><FONT=20
face=3D"Arial Cyr" size=3D2>&gt; Peter Osipov wrote:<BR>&gt; &gt; Hi =
Paul!<BR>&gt;=20
&gt; Could you please give another piece of advice?<BR>&gt; &gt; Well, I =
read=20
tons of information on adding contribution items<BR>&gt; &gt; =
dynamically and I=20
still cannot make it work. Here is how I am attempting <
Previous Topic:Custom layout for views
Next Topic:Find fragments of a plugin
Current Time: Wed Sep 24 05:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.08667 seconds
