Home » Eclipse Projects » Standard Widget Toolkit (SWT) » What's the difference between CAP_FLAT and CAP_SQUARE?
What's the difference between CAP_FLAT and CAP_SQUARE? [message #454562] Sun, 24 April 2005 16:10 Go to next message
Can someone tell me what the difference is between the GC endcap styles,
After drawing several lines with both styles,
I've concluded that they're the same. Is that correct?
Re: What's the difference between CAP_FLAT and CAP_SQUARE? [message #454569 is a reply to message #454562] Sun, 24 April 2005 19:54 Go to previous messageGo to next message
Originally posted by: aaa.domain.invalid
My 2c..
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet168.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
After running the above example it seems like the CAP_SQUARE extends the
original line which CAP_FLAT does not.
-chhil
Re: What's the difference between CAP_FLAT and CAP_SQUARE? [message #454571 is a reply to message #454569] Sun, 24 April 2005 20:11 Go to previous message
yup, you're right, Chhil. Thanks for the sanity check.
I was trying to compare thin diagonals.
Not a good comparison really.
Previous Topic:PNG support in SWT Toolbar
Next Topic:OS X anti aliasing
Current Time: Sat Jul 19 04:00:39 EDT 2025
Powered by FUDForum. Page generated in 0.04563 seconds
