Home » Eclipse Projects » Standard Widget Toolkit (SWT) » tree layout
tree layout [message #454172] Mon, 18 April 2005 15:11 Go to next message
after migrating to Eclipse 3.1M6, I switched my app from
TableTree(Viewer) to Tree(Viewer) because the forme has become
deprecated. However, I am now looking for a layout to attach to the Tree
in the same way that a TableLayout is attached to a Table. In
particular, I am looking for ways to specify the relative weight of the
columns, and the automatic resizing that is performed by TableLayout.
Can anybody help?
thanks,
christian
Re: tree layout [message #454175 is a reply to message #454172] Mon, 18 April 2005 15:44 Go to previous messageGo to next message
I just copied TableLayout into a TreeLayout class and changed the
(Table) casts to (Tree) casts. All was well afterwards. I assume there
will be some change before 3.1 GA that makes the same class usable in
both cases?!
chris
Christian Sell wrote:
> Hello,
> Can anybody help?
> thanks,
> christian
Re: tree layout [message #454231 is a reply to message #454175] Tue, 19 April 2005 10:10 Go to previous messageGo to next message
I don't think so since api is frozen for 3.1. This was logged recently, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91662 .
Grant
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:d4135f$hcr$1@news.eclipse.org...
> both cases?!
> chris
> > Hello,
> > Can anybody help?
> > thanks,
> > christian
Re: tree layout [message #454293 is a reply to message #454231] Tue, 19 April 2005 14:50 Go to previous messageGo to next message
hmm, I dont think I understand the conclusion. Right now, Tree is not
able to fully replace TableTree, as there are no similar layout
facilites (in fact, there seem to be none). So, in order to avoid API
change, the only way would be to remove the deprecation IMO..
chris
> Grant
>>both cases?!
>>chris
>>>Hello,
>>>Can anybody help?
>>>thanks,
>>>christian
Re: tree layout [message #454689 is a reply to message #454293] Wed, 27 April 2005 10:02 Go to previous message
TableLayout is not really a satisfactory answer for Table or Tree. The idea
of TableLayout is probably going to be rethought post 3.1 and therefore it
does not make too much sense for a copy of TableLayout to be created for
Tree. The work being done in TableLayout can quite simply be done with a
resize listener. For example, the PropertySheet view does the following:
tree.addControlListener(new ControlAdapter() {
public void controlResized(ControlEvent e) {
Rectangle area = tree.getClientArea();
TreeColumn[] columns = tree.getColumns();
if (area.width > 0 && columns[0].getWidth() == 0) {
columns[0].setWidth(area.width * 40 / 100);
columns[1].setWidth(area.width - columns[0].getWidth() - 4);
tree.removeControlListener(this);
news:d43kd3$tb7$1@news.eclipse.org...
> hmm, I dont think I understand the conclusion. Right now, Tree is not able
> to fully replace TableTree, as there are no similar layout facilites (in
> fact, there seem to be none). So, in order to avoid API change, the only
> chris
>> see
>> Grant
>>>both cases?!
>>>chris
>>>>Hello,
>>>>Can anybody help?
>>>>thanks,
>>>>christian
Previous Topic:TreeColumn.setMoveable() ?
Next Topic:Unable to set background color of an SWT Button
Current Time: Mon Jul 28 20:40:37 EDT 2025
Powered by FUDForum. Page generated in 0.05325 seconds
