SWT startup problem [message #453435] |
Tue, 05 April 2005 11:03  |
Hi.
I have downloaded the latest version of SWT:swt-3.0.2-win32.zip
And have added the VMArg:-Djava.library.path=C:\program1\eclipse\swt
dir C:\program1\eclipse\swt
Volume in drive C has no label.
Volume Serial Number is 3492-34FC
Directory of C:\program1\eclipse\swt
2005-04-05 15:51 <DIR> .
2005-04-05 15:51 <DIR> ..
2005-03-11 09:58 1 717 about.html
2005-03-11 09:58 548 javaw.exe.manifest
2005-03-11 09:58 32 768 swt-awt-win32-3064.dll
2005-03-11 09:58 307 200 swt-win32-3064.dll
2005-03-11 09:58 1 128 591 swt.jar
2005-03-11 09:58 1 196 131 swtsrc.zip
I am trying to show one display with the following code:
Display pDisp = new Display();
Shell pShell = new Shell(pDisp);
pShell.setSize(200, 200);
pShell.pack();
pShell.open();
while ( !pShell.isDisposed() ) {
if ( !pDisp.readAndDispatch() )
pDisp.sleep();
pDisp.dispose();
} // main
But I still receive the following error:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3064 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1781)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:356)
at org.eclipse.swt.widgets.Display.<init>(Display.java:352)
at ui.MainAppl.main(MainAppl.java:23)
Any ideer about what I am missing or doing wrong?
Best regards/William
Re: SWT startup problem (Swt installation problem) [message #453617 is a reply to message #453435] |
Fri, 08 April 2005 04:03   |
Originally posted by: f.bollaert.xxx.com
I am having a similar problem with swt installation.
Here is what I have done:
I am developiong with WSDD 5.7.1
on the pda I installed both Foundation, and Personal Profile, using the
cab files.
The pda is a pocket pc with
Microsoft Pocket PC Version 4.20.1081 installed.
Intel(R) PXA255
I have downloaded:
Windows CE (ARM PocketPC, J2ME profile)
swt-3.0.1-win32-ce-arm-ppc-j2me.zip
which contains:
11/03/2005 09:59 1,717 about.html
11/03/2005 09:59 145,408 swt-win32-3064.dll
11/03/2005 09:59 145,408 swt-win32.dll
11/03/2005 09:59 486,479 swt.jar
11/03/2005 09:59 752,617 swtsrc.zip
I have copied "swt-win32-3064.dll" into the
\Program Files\J9\FOUN10\bin
\Program Files\J9\PPRO10\bin
Also swt.jar is copied into:
\install
The start file looks like this:
139#"\Program Files\J9\FOUN10\bin\j9.exe" "-jcl:foun10"
"-cp:\install\HelloWorld.jar;\install\swt.jar" "HelloWorld"
And this is the exception I get:
(W)EXEL0051
WARNING: The command line argument "-cp:" has been deprecated.
WARNING: Use "-classpath <path>" or "-cp <path>".
org/eclipse/swt/internal/win32/OS.GetVersionExW(Lorg/eclipse /swt/internal/win32/OSVERSIONINFOW;)Z
at org.eclipse.swt.internal.win32.OS.<clinit>(Unknown Source)
at java.lang.Class.initializeImpl(Native Method)
at java.lang.Class.initialize(Unknown Source)
at org.eclipse.swt.graphics.Device.init(Unknown Source)
at org.eclipse.swt.widgets.Display.init(Unknown Source)
at org.eclipse.swt.graphics.Device.<init>(Unknown Source)
at org.eclipse.swt.widgets.Display.<init>(Unknown Source)
at HelloWorld.main(Unknown Source)
The HelloWorld class you can find in "A small cup of SWT" works fine on
Personal Profile.
But when I extend the example with a tree, it crashes on this error again.
Extracting the jar file does not do the trick for me.
Any help would be soo much appreciated.
Re: SWT startup problem (Swt installation problem) [message #453741 is a reply to message #453617] |
Fri, 08 April 2005 09:06   |
You're likely running into a conflict between the swt.jar you've put on the
path and the swt which in embedded within PPro and on the bootclasspath. So
are you trying to build a PPro app or an SWT app? You mention using a tree
which is not part of PPro, so if you're building an SWT app, why have PPro
on the path at all?
Stef
"Frankie Bollaert" <f.bollaert@xxx.com> wrote in message
news:e2e4b142c2d52b2e757bc9a59058dfd8$1@www.eclipse.org...
> cab files.
> Intel(R) PXA255
> I have downloaded:
> which contains:
> \install
> (W)EXEL0051
> Personal Profile.
Re: SWT startup problem (Swt installation problem) [message #453743 is a reply to message #453741] |
Fri, 08 April 2005 09:25   |
Oh, my mistake. I see you're original problem was using jcl:foun10, so no
PPro. But what I said about a conflict does hold true for your second
problem when you tried extending the example with a tree.
Not sure why your setup isn't working, but you might try adding
a -Djava.library.path="\Program Files\J9\FOUN10\bin" to explicitly point to
the SWT dll. I assume in your setup that the foundation classes are in
"\Program Files\J9\FOUN10\lib\jclFoundation10", right?
BTW, since you're running on CDC/Foundation, you don't actually need the
"j2me" version of the SWT for PPC code. It's a bit of a misnomer. The "j2me"
version is really if you're running on CLDC. But that shouldn't be the cause
of your problem.
Stef
"Stef van Dijk" <not-me@not-here.com> wrote in message
news:d35vp5$of0$1@news.eclipse.org...
the
So
> on the path at all?
> Stef
> > cab files.
> > Intel(R) PXA255
> > I have downloaded:
> > which contains:
> > \install
> > (W)EXEL0051
> > Personal Profile.
again.
Re: SWT startup problem [message #454204 is a reply to message #453616] |
Mon, 18 April 2005 21:04  |
Originally posted by: socrel.gmail.com
William wrote:
> Hi.
> It workes now and what I had to do was to unpack the jar file(swt.jar) to a
> directory and include that directory in the classpath.
Tried unziping swt.jar and adding dir to classpath, but this did not work.
Added dir for swt dlls to Windows system path and restarted Eclipse -
worked.
FUDForum. Page generated in 0.12179 seconds
