Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Expanding a TreeItem in swt.Tree
Expanding a TreeItem in swt.Tree [message #454104] Sun, 17 April 2005 19:37 Go to next message
Hi there,
while coding a method which should expand a treebranch including all its
subitems it appears that actually it's only working for a quite small
amount / limited depth of TreeItems.
Here are the 2 methods I wrote:
a) implementation:
public void expandTreeItem(Tree p0, TreeItem p1, boolean p2){
p0.setRedraw(false);
p1.setExpanded(p2);
expandTreeItem(p1, p2);
p0.setRedraw(true);
p0.redraw();
b) helper method:
private static void expandTreeItem(TreeItem p0, boolean p1){
int c = p0.getItemCount();
for(int i = 0; i < c; i++){
TreeItem s = p0.getItems()[0];
s.setExpanded(p1);
if(s.getItemCount() > 0)
expandTreeItem(s, p1);
c:) usage:
TreeItem[] selection = tree.getSelection();
if(selection.length > 0){
expandTreeItem(tree, selection[0],!selection[0].getExpanded());
What is wrong with my code? Any help would be appreciated.
Kind regards
Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454105 is a reply to message #454104] Sun, 17 April 2005 19:45 Go to previous messageGo to next message
Ooops, just figured it out...
WRONG: TreeItem s = p0.getItems()[0];
CORRECT: TreeItem s = p0.getItems()[i];
s.setExpanded(p1);
Re: Expanding a TreeItem in swt.Tree [message #454107 is a reply to message #454104] Sun, 17 April 2005 19:44 Go to previous messageGo to next message
should be
[i] not [0]
Doug
Boris Munivrana wrote:
> Hi there,
> a) implementation:
> p1.setExpanded(p2);
> p0.setRedraw(true);
> p0.redraw();
> b) helper method:
> s.setExpanded(p1);
> c:) usage:
> Kind regards
> Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454289 is a reply to message #454107] Tue, 19 April 2005 13:33 Go to previous messageGo to next message
Thanks, Doug.
BTW: Do you have any idea how to catch all children of a treebranch in a
fast way, since the swt.widgets.Tree / swt.widgets.TreeItem API does not
handle deep treestructure by default, like
javax.swing.tree.DefaultMutableTreeNode.
Backround: 2 years ago I wrote a swing-based application for my company
which breaks down variant parts lists from database source / Excel,
creates a hierarchic teestructure and with the combination of DND enabling
the user to change the structure (we're providing catalogs with part lists
for our end customers via docware, but our recource lists have to be
modified before they can be displayed, and docware doesn't provide any
functionality / software to do this).
This works quite well with swing, but focusing my interest on swt I now
would like to rewrite it, hoping for swt's capability of providing a more
native user experience, but somehow I haven't got around the tree problem
yet.
With kind regards
Boris Munivrana
> should be
> [i] not [0]
> Doug
>> Hi there,
>> a) implementation:
>> p1.setExpanded(p2);
>> p0.setRedraw(true);
>> p0.redraw();
>> b) helper method:
>> s.setExpanded(p1);
>> c:) usage:
>> Kind regards
>> Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454290 is a reply to message #454289] Tue, 19 April 2005 13:37 Go to previous messageGo to next message
You should look into using a TreeViewer with a ContentProvider and a
LabelProvider if you want to do "detailed" operations on your tree, that way
you can do what you did in Swing, which is defining your own nodes. And if
you have those set up with the usual parent-child get/fetch/add methods,
it's easy to fetch all children starting at a certain leaf. TreeViewers also
allow you to filter and sort your trees, and if you have your LabelProvider
implement IFontProvider, IColorProvider then you have colors and fonts for
your tree too.
IBM has an example in their developerworks section if you want some code
samples: http://www-106.ibm.com/developerworks/java/library/os-ecgui1 /
Emil
"Boris Munivrana" <bmunivrana@web.de> wrote in message
news:cb3c3c02a4e35ef6bacadb1b2cf5a955$1@www.eclipse.org...
> Thanks, Doug.
> functionality / software to do this). This works quite well with swing,
> but focusing my interest on swt I now would like to rewrite it, hoping for
> swt's capability of providing a more native user experience, but somehow I
> haven't got around the tree problem yet.
> With kind regards
> Boris Munivrana
>> should be
>> [i] not [0]
>> Doug
>>> Hi there,
>>> a) implementation:
>>> p1.setExpanded(p2);
>>> p0.setRedraw(true);
>>> p0.redraw();
>>> b) helper method:
>>> s.setExpanded(p1);
>>> c:) usage:
>>> Kind regards
>>> Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454292 is a reply to message #454290] Tue, 19 April 2005 14:46 Go to previous messageGo to next message
Hi, Emil,
That sounds good, so far. But does all this perform decently? The parts
lists I'm dealing with may consist of a several hundred items. Swing does
this very fast, but, since I suggest that a TreeViewer encapsulates an SWT
Tree widget, I think I would only be facing the poor performance I
experienced with the SWT Tree?
> TreeViewers also allow you to filter and sort your trees, and if you have
Neat-
> your LabelProvider
> your tree too.
I will definetly need these features to indicate dragged-/copied states
of treenodes -
Thanks for the link and for your attention, it is appreciated deeply.
With kind regards,
Boris Munivrana
> Emil
>> Thanks, Doug.
>> With kind regards
>> Boris Munivrana
>>> should be
>>> [i] not [0]
>>> Doug
>>>> Hi there,
>>>> a) implementation:
>>>> p1.setExpanded(p2);
>>>> p0.setRedraw(true);
>>>> p0.redraw();
>>>> b) helper method:
>>>> s.setExpanded(p1);
>>>> c:) usage:
>>>> Kind regards
>>>> Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454336 is a reply to message #454289] Wed, 20 April 2005 12:49 Go to previous messageGo to next message
For one thing, "getItems() [0]" is a bad thing to do. Call getItems() once,
store the result and then iterate through that. Even if the items were
stored in Java memory (they are not, they are stored in the operating
system), getItems() would need to return a copy of the array to avoid the
application modified the array directly. I hope this is enough to fix your
performance problem.
> Thanks, Doug.
> yet.
> With kind regards
> Boris Munivrana
> > should be
> > [i] not [0]
> > Doug
> >> Hi there,
its
> >> a) implementation:
> >> p1.setExpanded(p2);
> >> p0.setRedraw(true);
> >> p0.redraw();
> >> b) helper method:
> >> s.setExpanded(p1);
> >> c:) usage:
> >> Kind regards
> >> Boris Munivrana
Re: Expanding a TreeItem in swt.Tree [message #454445 is a reply to message #454336] Wed, 20 April 2005 17:31 Go to previous message
Hi Steve,
thanks for pointing this out.
With kind regards
Boris Munivrana
>> Thanks, Doug.
>> yet.
>> With kind regards
>> Boris Munivrana
>> > should be
>> > [i] not [0]
>> > Doug
>> >> Hi there,
> its
>> >> a) implementation:
>> >> p1.setExpanded(p2);
>> >> p0.setRedraw(true);
>> >> p0.redraw();
>> >> b) helper method:
>> >> s.setExpanded(p1);
>> >> c:) usage:
>> >> Kind regards
>> >> Boris Munivrana
Previous Topic:Highlighting Tree Item Selection
Next Topic:Repost - Larger image problems
Current Time: Thu Jul 24 22:58:46 EDT 2025
Powered by FUDForum. Page generated in 0.32258 seconds
