Home » Eclipse Projects » Standard Widget Toolkit (SWT) » no swt-pi-gtk-3128 in java.library.path
no swt-pi-gtk-3128 in java.library.path [message #454101] Sun, 17 April 2005 12:41 Go to next message
I know that similar messages have appeared before but I cannot get any
of their solutions to work. I have recently upgraded to 3.1M6 and my SWT
applications no longer runs. They come up with the following error.
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:992)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:122)
at org.simonsoft.graphics.swt.TestSWTXPM.main(TestSWTXPM.java:1 23)
I have tried attaching the libswt*.so files using the
-Djava.library.path method, I have tried adding the path to
LD_LIBRARY_PATH and into /etc/ld.so.conf (I use Linux dist Fedora Core
3), I linked the files into java/jre/lib as someone suggested and even
tried adding them into the project directory but I always get the same
error. I don't want to return to 3.1M4 unless I need to but I need my
project working again.
Re: no swt-pi-gtk-3128 in java.library.path [message #454340 is a reply to message #454101] Wed, 20 April 2005 15:26 Go to previous messageGo to next message
Unfortunately I had the same problem.
The lastest resort was downgrade to 3.15a.
"Simon Meaden" <simonmeaden@blueyonder.co.uk> wrote in message
news:d3u430$rin$1@news.eclipse.org...
Re: no swt-pi-gtk-3128 in java.library.path [message #454488 is a reply to message #454101] Fri, 22 April 2005 09:28 Go to previous message
I exctracted libswt-pi-gtk-3128.so and libswt-gtk-3128.so from
org.eclipse.swt.gtk-3.1.0.jar into org.eclipse.swt.gtk_3.1.0/os/linux/x86.
Being shared libraries they have to be accessible to the dynamic linker
and must not be hidden in a jar-file.
Klaus Wulff
Previous Topic:SWT control that support HTML text?
Next Topic:ComboBoxCellEditor
Current Time: Sun Jul 27 12:02:49 EDT 2025
Powered by FUDForum. Page generated in 0.03777 seconds
