Home » Eclipse Projects » Standard Widget Toolkit (SWT) » scrolling behaviour of scrolledcomposite within scrolledcomposite
scrolling behaviour of scrolledcomposite within scrolledcomposite [message #454081] Fri, 15 April 2005 09:39 Go to next message
i've a scrolledcomposite whose parent is also a scrolledcomposite.
Right now, whenever I add controls to the inner scrolledcomposite so
its conent height extends the available height, the inner
scrolledcomposite's height increase and the scrollbars of the outer
scrolledcomposite appear. How can I change this behaviour so that the
inner scrolledcomposite's scrollbars appear whenever the content
becomes to large? the inner scrolledcomposite should layouts itself
according to the layout manager of the outer composite. so for example
have a 5 pixel margin on each side.
Re: scrolling behaviour of scrolledcomposite within scrolledcomposite [message #454082 is a reply to message #454081] Fri, 15 April 2005 12:01 Go to previous messageGo to next message
You need to use layouts to manage the size and growth of your children.
For example:
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
final ScrolledComposite outer = new ScrolledComposite(shell,
SWT.V_SCROLL | SWT.H_SCROLL);
final Composite contentOuter = new Composite(outer, SWT.NONE);
contentOuter.setLayout(new GridLayout(2, false));
contentOuter.setBackground(display.getSystemColor(SWT.COLOR_ BLUE));
final ScrolledComposite inner = new ScrolledComposite(contentOuter,
GridData data = new GridData(SWT.FILL, SWT.FILL, true, true, 1, 6);
data.widthHint = 323;
data.heightHint = 200;
inner.setLayoutData(data);
for (int i = 0; i < 5; i++) {
Button b = new Button(contentOuter, SWT.PUSH);
b.setText("Outer Button "+i);
final Composite contentInner = new Composite(inner, SWT.NONE);
contentInner.setLayout(new GridLayout(3, false));
contentInner.setBackground(display.getSystemColor(SWT.COLOR_ RED));
Button doit = new Button(contentInner, SWT.PUSH);
doit.setText("add more children");
doit.addListener(SWT.Selection, new Listener() {
int index = 0;
public void handleEvent(Event e) {
Button b = new Button(contentInner, SWT.PUSH);
b.setText("New Button "+index++);
Point size = contentInner.computeSize(SWT.DEFAULT,
SWT.DEFAULT);
inner.setMinSize(size);
contentInner.layout(false);
b.setText("Inner Button "+i);
inner.setContent(contentInner);
inner.setExpandHorizontal(true);
inner.setExpandVertical(true);
Point size = contentInner.computeSize(SWT.DEFAULT, SWT.DEFAULT);
outer.setContent(contentOuter);
outer.setExpandHorizontal(true);
outer.setExpandVertical(true);
outer.setMinSize(contentOuter.computeSize(SWT.DEFAULT,
SWT.DEFAULT));
shell.pack();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Rudolf Traunm
Re: scrolling behaviour of scrolledcomposite within scrolledcomposite [message #454087 is a reply to message #454082] Fri, 15 April 2005 16:56 Go to previous messageGo to next message
thx for the answer, this is really useful!
However, I've a similar problem in the IDetailsPart of a
MasterDetailsBlock -> i've a table with many items in my detailpart.
The problem is that the scrollbars appear on the form, not on the the
table, so both, the table and the form, are very large. How can I fix
this behaviour?
On Fri, 15 Apr 2005 12:01:48 -0400, "Veronika Irvine"
>For example:
> int index = 0;
>SWT.DEFAULT);
>SWT.DEFAULT));
> shell.pack();
> shell.open ();
> display.dispose ();
>"Rudolf Traunmüller" <rudolf.traunmueller.privat@maat.at> wrote in message
>news:tlgv515sponaga3cni748utm11np35kush@4ax.com...
Re: scrolling behaviour of scrolledcomposite within scrolledcomposite [message #454088 is a reply to message #454087] Fri, 15 April 2005 19:49 Go to previous message
solved. you have to add a widthHint and heightHint on the GridData of
the table.
On Fri, 15 Apr 2005 22:56:46 +0200, Rudolf Traunmüller
>this behaviour?
>>For example:
>> int index = 0;
>>SWT.DEFAULT);
>>SWT.DEFAULT));
>> shell.pack();
>> shell.open ();
>> display.dispose ();
Previous Topic:Launching the system mail reader
Next Topic:Changing the size of a Tables rows
Current Time: Mon Jul 28 11:33:12 EDT 2025
Powered by FUDForum. Page generated in 0.03858 seconds
