Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Text validation and setting focus
Text validation and setting focus [message #453863] Tue, 12 April 2005 15:46 Go to next message
I am implementating a wizard page which has bunch of text controls. I need
to do application specific validation on text controls, display an error
message if validation fails and set control/focus back to that text
control. I tried focusListener as well as TraverseListener. In case of
traverselistener, user can tab out and I can catch those events, which is
fine. But user can also use mouse to go to next field. So ideal is using
focusListener but I don't know how to set focus back to that field
control.setFocus doesn't work as I expected. It keeps popping up error
message depending on how many controls I have on that page. Any help is
greatly appreciated...
Here is sample code
ctrl_name.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
if (e.detail == SWT.TRAVERSE_TAB_NEXT || e.detail ==
SWT.TRAVERSE_TAB_PREVIOUS ) {
String msg = doValidation(); if (msg == null)
e.doit = true;
else
MsgBox.showError(msg);
e.doit = false;
OR
ctrl_name.addFocusListener(new FocusAdapter() {
public void focusLost(FocusEvent e) {
// do nothing
else
ctrl_name.setFocus();
Re: Text validation and setting focus [message #453864 is a reply to message #453863] Tue, 12 April 2005 16:11 Go to previous messageGo to next message
Take a look at this:
http://www.swtworkbench.com/devzone/edwiki.cgi/ProjectDocume ntation#Installation%20and%20Quick%20Start
> need to do application specific validation on text controls, display an
> error message if validation fails and set control/focus back to that
> text control. I tried focusListener as well as TraverseListener. In case
> of traverselistener, user can tab out and I can catch those events,
> which is fine. But user can also use mouse to go to next field. So ideal
> is using focusListener but I don't know how to set focus back to that
> field control.setFocus doesn't work as I expected. It keeps popping up
> error message depending on how many controls I have on that page. Any
> help is greatly appreciated...
> Here is sample code
> == null)
> e.doit = true;
> else
> e.doit = false;
> OR
> if (msg == null)
> // do nothing
> else
Re: Text validation and setting focus [message #453865 is a reply to message #453864] Tue, 12 April 2005 17:15 Go to previous messageGo to next message
I don't think I got my question answered, I should have mentioned that I
want to use only standard Eclipse APIs.
Re: Text validation and setting focus [message #453873 is a reply to message #453863] Wed, 13 April 2005 09:45 Go to previous messageGo to next message
I would be interested in finding a way to do this as well. I
experemented like you did and found the focus lost method almost works.
If you show the message box then set focus back on the failing component
this way:
final Control c = control;
control.getDisplay().asyncExec (new Runnable () {
public void run () {
c.setFocus();
This worked for most cases except when clicking on the window X button
to close the window when it gets stuck in an infinite loop showing the
same error message. I debugged this some and could't figure out a way
around it.
Andy Arhelger
> Here is sample code
> == null)
> e.doit = true;
> else
> e.doit = false;
> OR
> if (msg == null)
> // do nothing
> else
Re: Text validation and setting focus [message #453906 is a reply to message #453873] Wed, 13 April 2005 13:33 Go to previous messageGo to next message
Actually I tried some more on this and got it working.
I ended up doing the validity checking on the focusGained method. In the
focusLost I just save the control which lost focus for later use.
I also needed to display the message dialog in an asyncExec. I haven't
tried all cases but it appears to work.
Andy Arhelger
> this way:
> c.setFocus();
> around it.
> Andy Arhelger
>> an error message if validation fails and set control/focus back to
>> that text control. I tried focusListener as well as TraverseListener.
>> In case of traverselistener, user can tab out and I can catch those
>> events, which is fine. But user can also use mouse to go to next
>> field. So ideal is using focusListener but I don't know how to set
>> focus back to that field control.setFocus doesn't work as I expected.
>> It keeps popping up error message depending on how many controls I
>> have on that page. Any help is greatly appreciated...
>> Here is sample code
>> (msg == null)
>> e.doit = true;
>> else
>> e.doit = false;
>> OR
>> String msg =
>> // do nothing
>> else
Re: Text validation and setting focus [message #453918 is a reply to message #453906] Wed, 13 April 2005 17:41 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
I'm a little dubious one could get validity checking working properly by
checking on focus gained. The problem you had with clicking on the
window X button should be easy enough to deal with by setting up a
ShellListener to listen for the close event, set a "closing" flag for
your validation method so it doesn't try to setFocus() in this case.
Bob Foster
> Andy Arhelger
>> works. If you show the message box then set focus back on the failing
>> component this way:
>> c.setFocus();
>> around it.
>> Andy Arhelger
>>> Here is sample code
>>> (msg == null)
>>> e.doit = true;
>>> else
>>> e.doit = false;
>>> OR
>>> String msg =
>>> // do nothing
>>> else
Re: Text validation and setting focus [message #453922 is a reply to message #453918] Wed, 13 April 2005 19:25 Go to previous messageGo to next message
Actually by setting focusListener may be a bad idea, since
ALT+TAB(switching to another application) will also cause focusLost event
and will display error message box. I think TraverseListener is much
better way to go. But I still need to figure out how to capture if user
uses mouse to move out of that text box.
Re: Text validation and setting focus [message #453966 is a reply to message #453922] Thu, 14 April 2005 21:45 Go to previous messageGo to next message
> event and will display error message box. I think TraverseListener is
> much better way to go. But I still need to figure out how to capture if
> user uses mouse to move out of that text box.
I think it's a bad idea to let the user leave invalid data in a text
box. Then when do you check it? Better to display the error dialog,
which will be modal but not across applications and will be in front of
the parent shell when the user switches back.
Bob Foster
Re: Text validation and setting focus [message #454176 is a reply to message #453966] Mon, 18 April 2005 15:46 Go to previous message
1) Actually focusgained works well, at least so far in my testing. I
also need the item that focus is moving to so I can know when to ingnor
the validity checking. Like clicking on a Cancel button. At focusLost
time you get way to many events. Even showing another window on your
desktop generates the focusLost, like ALT-TAB. You really don't want to
do validity checking in this case.
2) You have to use a focusListener becase traverseListener doesn't
doesn't get called for mouse clicks.
3) For the ALT-TAB case the focus remains in the control you were
editing so when you come back later to that window the focus hasn't moved.
Andy Arhelger
>> if user uses mouse to move out of that text box.
> Bob Foster
Previous Topic:prevent Exit Event from Text
Next Topic:Strange Shell behaviour
Current Time: Fri Jul 25 22:20:45 EDT 2025
Powered by FUDForum. Page generated in 0.27700 seconds
