Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TreeItem Listener
TreeItem Listener [message #453811] Sun, 10 April 2005 17:40 Go to next message
What is the secret with TreeItem listener?. Whatever i try, i cannot seem to
get them going. I know it is me and that frustrates me more. Been spending
some time searching but can not find an answer, nore a snippet that
implements the treeitem listener.
Thanks for your help,
Wim Jongman
// Applications filter
TreeItem appFilterNode = new TreeItem(appNode, SWT.MULTI | SWT.CHECK);
appFilterNode.setText("Select Applications");
appFilterNode.setImage(new Image(shell.getDisplay(), this.getClass()
.getResourceAsStream("filter.gif")));
appFilterNode.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
System.out.println("Boem");
Re: TreeItem Listener [message #453833 is a reply to message #453811] Mon, 11 April 2005 13:53 Go to previous messageGo to next message
The only event that TreeItem fires is Dispose; other types of listeners must
be hooked to the parent Tree (hint: see a widget class's javadoc for a list
of the events that it fires). Example snippet:
Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10,10,200,200);
Tree tree = new Tree(shell, SWT.NONE);
tree.setBounds(10,10,150,150);
tree.addTreeListener(new TreeListener() {
public void treeExpanded(TreeEvent e) {
System.out.println("expanded: " + ((TreeItem)e.item).getText());
public void treeCollapsed(TreeEvent e) {
System.out.println("collapsed: " +
tree.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent e) {
System.out.println("selected: " + ((TreeItem)e.item).getText());
public void widgetDefaultSelected(SelectionEvent e) {
System.out.println("default selected: " +
TreeItem rootItem = new TreeItem(tree, SWT.NONE);
rootItem.setText("root item");
new TreeItem(rootItem, SWT.NONE).setText("child item");
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Wim Jongman" <wim@nospam.org> wrote in message
news:d3c6o6$mss$1@news.eclipse.org...
to
> Wim Jongman
Re: TreeItem Listener [message #453836 is a reply to message #453833] Mon, 11 April 2005 15:39 Go to previous messageGo to next message
Hi Grant,
Thanks for your response, however, it still bothers me.
First i tried to look up te latest copy of the javadoc that you have but i
have not (which in itself is extremely difficult to find (supposedly, the
location of the javadoc is in the faq, but where is the faq. In general it
is difficult to find basic info like javadocs on the eclipse site but i will
save this for later)) I cannot find it.
There is no mention at-all in the widget on the type of event that is fired.
Supposedly, the addListener method is inherited from Item. TreeItem also
inherits addDisposeListener. Now, why would there be two methods for just
dispose?
Further more, the documentation as you suggest does not mention the event
that triggers the listener.
So, who can back Grant and/or point me to the correct javadoc for SWT where
eventType is explained for addListener
Wim
javadoc for Item:
addListener
public void addListener(int eventType,
Listener listener)Adds the listener to the
collection of listeners who will be notifed when an event of the given type
occurs. When the event does occur in the widget, the listener is notified by
sending it the handleEvent() message.
Parameters:
eventType - the type of event to listen for
listener - the listener which should be notified when the event occurs
Throws:
IllegalArgumentException -
a.. ERROR_NULL_ARGUMENT - if the listener is null
SWTException -
a.. ERROR_WIDGET_DISPOSED - if the receiver has been disposed
b.. ERROR_THREAD_INVALID_ACCESS - if not called from the thread that
created the receiver
See Also:
Listener, removeListener(int, org.eclipse.swt.widgets.Listener)
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:d3edtn$i5k$1@news.eclipse.org...
> must
> list
> public static void main(String[] args) {
> shell.open();
> display.dispose();
> Grant
>> Hi,
> to
>> spending
>> Wim Jongman
Re: TreeItem Listener [message #453845 is a reply to message #453836] Mon, 11 April 2005 18:12 Go to previous message
Originally posted by: bob.objfac.com
If Grant says so, it's so.
The javadoc is part of Help. Platform Plug-in Developer Guide >
Reference > API Reference.
There are two different types of events in SWT, low-level and
high-level, and two different types of listeners. High-level listeners
are set using addXXXListener() where XXX is, e.g., Dispose, Selection,
Tree, etc. These are the listeners you are intended to use. Low-level
events are used to implement high-level events; they are intended for
internal use. addListener() is the man behind the curtain you are
supposed to ignore.
If you look at the javadoc or the code you will see that TreeItem
inherits only addDisposeListener() and defines no additional high-level
events. Tree, on the other hand, inherits addDisposeListener() and
defines two more: addTreeListener() and addSelectionListener().
Bob
Wim Jongman wrote:
> Hi Grant,
> dispose?
> Regards,
> Wim
> javadoc for Item:
> addListener
> Parameters:
> Throws:
> SWTException -
> See Also:
>>must
>>list
>> shell.open();
>> display.dispose();
>>Grant
>>>Hi,
>>to
>>>spending
>>>Wim Jongman
Previous Topic:How to find out absolute index of an item in a Tree?
Next Topic:How to change color of image using code?
Current Time: Mon Jul 28 11:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.04300 seconds
