problem with dependencies [message #453578] |
Thu, 03 August 2006 10:36  |
Hi!
I have a problem with my plugin dependencies.
I have one RCP-app with the id
(1) "com.dvelop.ecm.basic"
and two seperate plug-ins with the ids
(2) "com.dvelop.ecm.runtime" and
(3) "com.dvelop.ecm.test"
(3) depends on (2) and (1) depends on (3). But when I want to start the
RCP-App (1) I get the following error message:
!SESSION 2006-08-03
16:32:43.116 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application com.dvelop.ecm.basic.application
Command-line arguments: -application com.dvelop.ecm.basic.application -data
E:\workspace/../runtime-EclipseApplication(3) -dev
file:E:/workspace/.metadata/.plugins/org.eclipse.pde.core/Ec lipse
Application (3)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 0 2006-08-03 16:32:44.428
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-08-03 16:32:44.444
!MESSAGE Bundle update@E:/workspace/com.dvelop.ecm.test/ was not resolved.
!SUBENTRY 2 com.dvelop.ecm.test 2 0 2006-08-03 16:32:44.444
!MESSAGE Missing required bundle com.dvelop.ecm.runtime_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2006-08-03 16:32:44.444
!MESSAGE The following is a complete list of bundles which are not resolved,
see the prior log entry for the root cause if it exists:
!MESSAGE Bundle update@E:/workspace/com.dvelop.ecm.test/ [134] was not
resolved.
!MESSAGE Bundle update@E:/workspace/com.dvelop.ecm.basic/ [144] was not
resolved.
!SUBENTRY 2 com.dvelop.ecm.basic 2 0 2006-08-03 16:32:44.444
!MESSAGE Missing required bundle com.dvelop.ecm.test_0.0.0.
!ENTRY org.eclipse.osgi 4 0 2006-08-03 16:32:44.459
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.dvelop.ecm.basic.application"
could not be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner, org.eclipse.ui.ide.workbench,
org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:68)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2006-08-03 16:32:44.459
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-08-03 16:32:44.459
!SUBENTRY 2 com.dvelop.ecm.test 2 0 2006-08-03 16:32:44.459
resolved.
resolved.
!SUBENTRY 2 com.dvelop.ecm.basic 2 0 2006-08-03 16:32:44.459
Can anyone help me, please?!
Thanks a lot!
Greetz,
Carsten
Re: problem with dependencies [message #453583 is a reply to message #453578] |
Thu, 03 August 2006 11:46   |
Originally posted by: dittmar.steiner.web.de
open the .product file, go to "Configuration" and press the button "Add Required Plug-ins".
May be this could help.
Dittmar
Carsten Spieker schrieb:
> Hi!
> !SESSION 2006-08-03
> resolved.
> resolved.
> !STACK 1
> at
> at
> at
> at
> at
> resolved.
> resolved.
> Thanks a lot!
> Greetz,
> Carsten
Re: problem with dependencies [message #453599 is a reply to message #453583] |
Fri, 04 August 2006 02:46   |
Thanks a lot, that?s it.
Carsten
"Dittmar Steiner" <dittmar.steiner@web.de> schrieb im Newsbeitrag
news:eat5ob$lu0$1@utils.eclipse.org...
> Required Plug-ins".
> Dittmar
>> Hi!
>> !SESSION 2006-08-03
>> resolved.
>> resolved, see the prior log entry for the root cause if it exists:
>> resolved.
>> resolved.
>> !STACK 1
>> "com.dvelop.ecm.basic.application" could not be found in the registry.
>> The applications available are: org.eclipse.ant.core.antRunner,
>> org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> resolved.
>> resolved.
>> resolved.
>> Thanks a lot!
>> Greetz,
>> Carsten
FUDForum. Page generated in 0.06914 seconds
