Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Howto: Edit the text of a tree item (in place, fancy)
Howto: Edit the text of a tree item (in place, fancy) [message #451929] Fri, 11 March 2005 06:19 Go to next message
I am currently using the snippet 111:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet111.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
in order to edit the text of a treeitem in place. But compared to the
"Rename" action
in Eclipse's Navigator (Resource perspective) it behaves a bit differently:
1.) The black-box (edit textfield) has a bigger width in Eclipse's Navigator
2.) The text of the TreeItem that is being edited is not moving to the
left. In the
Snippet I am seeing a movement (~1px) to the left as soon as the
editing begins.
Is Eclipse using a different solution? Maybe someone could point me to
the way Eclipse
is doing it.
Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #451976 is a reply to message #451929] Fri, 11 March 2005 12:57 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
See TreeEditor. That's what the Resource Navigator uses, as well.
(Yes, snippet 111 has a number of problems. The simulated border looks
especially awful on MacOSX, the positions are wrong, etc.)
Bob Foster
Benjamin Pasero wrote:
> "Rename" action
> left. In the
> editing begins.
> the way Eclipse
> is doing it.
> Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452497 is a reply to message #451976] Mon, 21 March 2005 10:24 Go to previous messageGo to next message
For me, using the example from the Snippet makes no difference. I am
still seeing the
two problems I mentioned.
Ben
> Bob Foster
>> Hi,
>> "Rename" action
>> differently:
>> Navigator
>> left. In the
>> editing begins.
>> the way Eclipse
>> is doing it.
>> Thanks,
>> Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452514 is a reply to message #452497] Mon, 21 March 2005 15:10 Go to previous messageGo to next message
> still seeing the
Hmm. I guess you'd have to chase down how Resource Navigator adjusts the
position and size of TreeEditor. I only looked far enough to see that it
used TreeEditor (even that wasn't much fun).
Bob
> Ben
>>Bob Foster
>>>Hi,
>>>"Rename" action
>>>differently:
>>>Navigator
>>>left. In the
>>>editing begins.
>>>the way Eclipse
>>>is doing it.
>>>Thanks,
>>>Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452854 is a reply to message #452514] Fri, 25 March 2005 00:24 Go to previous messageGo to next message
The BIRT Data Explorer view has a nice implementation of this.
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452856 is a reply to message #452514] Fri, 25 March 2005 00:24 Go to previous messageGo to next message
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452861 is a reply to message #452856] Fri, 25 March 2005 06:25 Go to previous messageGo to next message
Hm, what/where is the BIRT Data Explorer?
Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452889 is a reply to message #452861] Sat, 26 March 2005 00:51 Go to previous messageGo to next message
http://www.eclipse.org/birt
They did the click-wait-click again method of renaming and the F2
method. I haven't looked at the code but it runs in 3.0.1 so it's not
relying on any new 3.1 features.
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452891 is a reply to message #452889] Sat, 26 March 2005 03:36 Go to previous messageGo to next message
Ah ok thanks.
But the Navigator in Eclipse is also doing it, somehow different from
the Snippet. Maybe
the snippet could be updated with Eclipse's approach.
Re: Howto: Edit the text of a tree item (in place, fancy) [message #452994 is a reply to message #451976] Tue, 29 March 2005 11:21 Go to previous messageGo to next message
Bob, can you enter a bug report for this?
"Bob Foster" <bob@objfac.com> wrote in message
news:4231DBFC.8070807@objfac.com...
> Bob Foster
> > Hi,
> > "Rename" action
differently:
Navigator
> > left. In the
> > editing begins.
> > the way Eclipse
> > is doing it.
> > Thanks,
> > Ben
Re: Howto: Edit the text of a tree item (in place, fancy) [message #453015 is a reply to message #452994] Tue, 29 March 2005 18:25 Go to previous message
It's https://bugs.eclipse.org/bugs/show_bug.cgi?id=89434.
I'll trade you. I've seen lots of people put links in Bugzilla bug
reports, but <a> doesn't work (as 89434 clearly shows). What's the trick?
Bob
>>Bob Foster
>>>Hi,
>>>"Rename" action
> differently:
> Navigator
>>>left. In the
>>>editing begins.
>>>the way Eclipse
>>>is doing it.
>>>Thanks,
>>>Ben
Previous Topic:Mac button layout
Next Topic:Textfield in a PopUp menu - is it possible?
Current Time: Wed Jul 23 16:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.04669 seconds
