Home » Eclipse Projects » Rich Client Platform (RCP) » Open View with an Action
Open View with an Action [message #452786] Fri, 14 July 2006 12:21 Go to next message
Originally posted by: mgervais.signaturegenetics.com
I'd like to open a view with an Action and the method :
IWorkbenchPage.showView(String viewId, String secondaryId, int mode)
but to use this method the view has to be in the View Registry using the
extension point org.eclipse.ui.views, so it means that's the view will
appear in the Show View Dialog and I don't want that. Is there a way to
prevent a view appearing in the Show view Dialog? Or a workaround?
Mickael
Re: Open View with an Action [message #452839 is a reply to message #452786] Mon, 17 July 2006 19:05 Go to previous messageGo to next message
does somebody has an idea for my question?
I cannot make it working....
Any help should be apprecitated.
Thanks again
Micakel
"Gervais Mickael" <mgervais@signaturegenetics.com> wrote in message
news:e98fp7$v7g$1@utils.eclipse.org...
> Thanks
> Mickael
Re: Open View with an Action [message #452842 is a reply to message #452839] Mon, 17 July 2006 19:36 Go to previous messageGo to next message
I guess one thing you can do is don't use show view dialog to display
views instead create your menu item actions for the views you like to
display
in short don't use e.g
IContributionItem viewList =
ContributionItemFactory.VIEWS_SHORTLIST.create(window);
Re: Open View with an Action [message #452885 is a reply to message #452842] Tue, 18 July 2006 09:31 Go to previous messageGo to next message
But if I do that I don't have my show view dialog anymore, and other view
have to be opened with this view... So you can? Have my show view dialog
without View A , and open the view A with an action?
Thanks again for your answer
Mickael
"dhiresh patel" <dhiruster@gmail.com> wrote in message
news:8699b335787b76fb7e6ae0849938e521$1@www.eclipse.org...
>I guess one thing you can do is don't use show view dialog to display views
>instead create your menu item actions for the views you like to display
Re: Open View with an Action [message #452942 is a reply to message #452885] Wed, 19 July 2006 06:27 Go to previous messageGo to next message
Well i think every view that you create will be registered in the view
registry which gets reflected in the Window --> ShowView menu. I doubt
whether you could ever do that.
Re: Open View with an Action [message #453001 is a reply to message #452786] Wed, 19 July 2006 21:46 Go to previous message
Originally posted by: lamont_gilbert.rigidsoftware.com
Gervais Mickael wrote:
> Thanks
> Mickael
Don't fight the architecture. Things just get ugly.
Why can't you instantiate your view programmatically, and pass it to the
page or something?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into the
sheepfold{}, but climbeth up some other *way, the same is a thief and a
robber."
Previous Topic:Help Displaying Filesystem in View
Next Topic:Showing a Dialog Whilst Running a Job
Current Time: Fri Jul 18 20:55:48 EDT 2025
Powered by FUDForum. Page generated in 0.03868 seconds
