Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT over Swing
SWT over Swing [message #452383] |
Fri, 18 March 2005 15:18  |
Hi, I have just recently heard of SWT, and i would like to know -
essentially - why I should use it above the java Swing framework?
Re: SWT over Swing [message #452394 is a reply to message #452383] |
Sat, 19 March 2005 05:56   |
Ideally we should have Swing implemented in the way SWT is implemened.
Unfortunately, the quality of Swing is not up for the expectation of average
Windows or Mac users. It might OK for Unix or Linux users. You don't expect
to develop commercially viable GUI intensive applications targeted for
Windows users using AWT or Swing. For exmple, if you use Swing, you cannot
use the basic copy & paste, or scrollers on your laptop, etc. Graphics are
shoddy.
Simply not feasible to write maketable s/w using Java. Your best bet with
Java is
server side where your Java hide behind good looking Windows browsers! So is
the problem for Java in desktop applications! Because of this, you will
hardly find
well-known Java-based commercial desktop applications!
I have 150,000-line Java application written in AWT. I did converted into
Swing, then
found that version was complete crap because Swing is crap. So I had to go
back to
AWT and develop custom widgets not provided by AWT such as combobox etc.
I have been researching SWT to migrate my application from AWT to SWT.
I migrated to Swing using adaptors. However it's not possible to develop
adaptors for
SWT. So if I migrate to SWT, virtually I have to rewrite almost everything!
So is my dilema. I really don't think I will rewrite this in another Java.
GUI presentation of SWT is far better than Swing and AWT. But it still has
serious shortcommings. If I rewrite, I may have to use Visual Basic that
I used to hate to use. I really hope that Sun should have done better job
in this aspect.
So you got the story!
"robert" <robert.cleary@ul.ie> wrote in message
news:d1fd28$unc$1@www.eclipse.org...
Re: SWT over Swing [message #452401 is a reply to message #452394] |
Sat, 19 March 2005 17:57   |
Originally posted by: bob.objfac.com
So you're essentially saying in order to have a UI up to the expectation
of average Windows or Mac users you have to give up platform-independence?
I'm also curious about the reference to Mac users, since Apple maintains
the AWT/Swing implementation on that platform and they at least think
they're providing as close to a native l&f as they can. In fact, I
talked to an Apple representative at EclipseCon who told me they were
looking to hire an SWT/Cocoa expert so they could do a Cocoa port of
SWT. I guess this is a long way to ask, what's so bad about AWT/Swing on
windows? Is it better or worse than the SWT/Carbon port?
Bob Foster
> shoddy.
> Java is
> hardly find
> Swing, then
> back to
> adaptors for
> in this aspect.
Re: SWT over Swing [message #452402 is a reply to message #452401] |
Sat, 19 March 2005 19:14   |
I meant, of course, "what's so bad about AWT/Swing on MacOSX?" :(
Bob
> Bob Foster
>> average
>> expect
>> cannot
>> are
>> shoddy.
>> Java is
>> So is
>> hardly find
>> Swing, then
>> to go
>> back to
>> adaptors for
>> everything!
>> Java.
>> has
>> in this aspect.
Re: SWT over Swing [message #452403 is a reply to message #452394] |
Sat, 19 March 2005 19:19   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
This is preposterous. Swing performs perfectly fine. I was just fine
for me in the days of 233MHz AMD K6, its certainly fine in the days of
2GHz. Something wrong with your implementation.
And to say that SWT is better implemented that Swing is equally as
preposterous. SWT is promising and is up and comming. But Swing is
fully established.
CL
> shoddy.
> Java is
> hardly find
> Swing, then
> back to
> adaptors for
> in this aspect.
Re: SWT over Swing [message #453242 is a reply to message #452383] |
Fri, 01 April 2005 13:40   |
You will find very heated arguments/debates on Swing versus SWT all over
the net.
I use both, each and every day. I am involved with two projects at work.
One uses Swing, the other SWT.
Each project has its own reasons for using Swing/SWT.
The project that uses Swing, has two main reasons for doing so
1 - For the most part the project outdates SWT.
2 - It uses OpenMap, which is a Swing based mapping component
The second application is written in SWT. I was hired to take a R&D
project written in C++/MFC, convert it to Java and make it a
"production' quality product.
The reason we went with SWT over Swing are numerous but here are a few:
1 - It is supposed to be a production/commercial quality product. To me,
that meant it should look and behave like a native application would. in
this area, Swing didn't cut it.
2 - Ease of development. I can create a better looking application
faster, and more reliably with SWT/JFace than Swing.
3 - Eclipse RCP. The Eclispe RCP makes it very easy to make a
professional looking application quickly. It also allowed us to take
advantage of the Elcipse plugin archeticture.
Having built large GUI systems on both, I will always try to use SWT in
the future.
Re: SWT over Swing [message #453275 is a reply to message #453242] |
Sun, 03 April 2005 13:14   |
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
<font face="serif">Brian is right on, I think. There are significant
reasons to use both. I don't think either one is the catch all
solution for every situation. Just as a rather glaring example, SWT
doesn't support applets.<br>
<br>
The ultimate solution, really, would be if Sun would bundle a
distribution of SWT with Java. This would definitely ease all
developer's headaches. I'm aware of both the logistical, and the
business reasons not to do this, but it still stands as the best
solution on the developer side. Sun can't simply continue to ignore
SWT. And this goes for every Java developer: Like it or not, SWT is
here to stay. Try as you might to discount / discredit it, SWT is and
will continue to become a major force in client side Java. I'm not
saying that it will ever fully replace Swing, it probably won't. But I
am saying that it's earned a place in the Java distro.<br>
<br>
Daniel<br>
</font><br>
Brian Hudson wrote:
<blockquote cite="midd2k4lv$2oo$1@news.eclipse.org" type="cite">You
the net.
<br>
<br>
work. One uses Swing, the other SWT.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
me, that meant it should look and behave like a native application
would. in this area, Swing didn't cut it.
<br>
<br>
<br>
<br>
<br>
<br>
the future.
<br>
<br>
robert wrote:
<br>
<blockquote type="cite">Hi, I have just recently heard of SWT, and i
would like to know - essentially - why I should use it above the java
Swing framework?
<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
Re: SWT over Swing [message #453964 is a reply to message #452383] |
Thu, 14 April 2005 18:57  |
If you develop commercial s/w aiming Windows users as main users,
you have no other choice than not to use Swing. Your product will never
be attractive to Windows user!
Alternative might be SWT. If SWT still not good enough, then
Visual Basic/C++ will be the options.
I struggled many years with the graphical quality of Swing. SWT can
make your system look a lot better. So choice is if you write systems
aiming for Windows users commercially, never put your money on Swing!
Current Time: Sat Jul 26 12:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.10246 seconds
