Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Mac button layout
Mac button layout [message #452289] Wed, 16 March 2005 20:32 Go to next message
I'm working on a plug-in for Eclipse 3.0.1 on Windows and Mac, and I'm
having a few problems getting dialog layout to look good across both
platforms. One specific problem is that on the Mac, it seems like there's
extra space around buttons, even with SWT.FLAT set, compared to Windows.
For example, if I put a button in a FormLayout, and set its top/left to 0,
0, it actually appears a few pixels in from the corner on the Mac, whereas
it's flush with the corner on Windows.
Is there any way to get around this? Is it a bug in SWT, or is there a
reason for it?
nj
Re: Mac button layout [message #452300 is a reply to message #452289] Thu, 17 March 2005 03:29 Go to previous messageGo to next message
Originally posted by: markusr.itee.uq.edu.au
Hi Narciso,
I encountered the same problem and used TollBar/ToolItems as a
workaround. ToolItems seem to appear without the extra space.
Cheers, Markus
Narciso Jaramillo wrote:
> there's extra space around buttons, even with SWT.FLAT set, compared to
> Windows. For example, if I put a button in a FormLayout, and set its
> top/left to 0, 0, it actually appears a few pixels in from the corner on
> the Mac, whereas it's flush with the corner on Windows.
> reason for it?
> nj
Re: Mac button layout [message #453004 is a reply to message #452300] Tue, 29 March 2005 11:43 Go to previous messageGo to next message
Yes, the Mac draws the button a few pixels inside the bounds. Do you have a
snippet that shows the problem?
"Markus Rittenbruch" <markusr@itee.uq.edu.au> wrote in message
news:d1bf11$fgt$1@www.eclipse.org...
> Hi Narciso,
> Cheers, Markus
> > Hi,
> > reason for it?
> > Thanks,
> > nj
Re: Mac button layout [message #453014 is a reply to message #453004] Tue, 29 March 2005 18:04 Go to previous message
Try Snippet111 on the Mac.
Bob
Previous Topic:using AbstractTextEditor in an SWT Application
Next Topic:Howto: Edit the text of a tree item (in place, fancy)
Current Time: Sun Jul 27 14:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.03818 seconds
