Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Why doesn't grab grab?
Why doesn't grab grab? [message #452199] |
Tue, 15 March 2005 03:31  |
Originally posted by: bob.objfac.com
Can somebody please explain to me why the tree in this slightly modified
Snippet15 doesn't fill the entire shell?
public class Snipped15Layout {
Display display = new Display ();
Shell shell = new Shell (display);
GridLayout layout = new GridLayout();
layout.numColumns = 1;
shell.setLayout(layout);
Tree tree = new Tree (shell, SWT.BORDER);
GridData data = new GridData(SWT.LEFT, SWT.TOP, true, true);
data.horizontalSpan = 1;
tree.setLayoutData(data);
for (int i=0; i<4; i++) {
TreeItem iItem = new TreeItem (tree, 0);
iItem.setText ("TreeItem (0) -" + i);
for (int j=0; j<4; j++) {
TreeItem jItem = new TreeItem (iItem, 0);
jItem.setText ("TreeItem (1) -" + j);
for (int k=0; k<4; k++) {
TreeItem kItem = new TreeItem (jItem, 0);
kItem.setText ("TreeItem (2) -" + k);
for (int l=0; l<4; l++) {
TreeItem lItem = new TreeItem (kItem, 0);
lItem.setText ("TreeItem (3) -" + l);
shell.open ();
while (!shell.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Thanks!
Bob
Re: Why doesn't grab grab? [message #452205 is a reply to message #452199] |
Tue, 15 March 2005 08:01   |
It is grabbing, it is just not filling.
You have:
which means the cell in the grid will grab any excess vertical or horizontal
space, however, the widget will be aligned in the cell at its top left
corner. If the cell is bigger than the preferred size of the widget, the
widget will be smaller than the cell.
If you change this to
GridData data = new GridData(SWT.FILL, SWT.FILL, true, true);
the cell will grab any excess vertical or horizontal space and the widget
will be stretched (or shrunk as the case may be) to fill the cell
horizontally and vertically.
"Bob Foster" <bob@objfac.com> wrote in message
news:d166go$607$1@www.eclipse.org...
> public static void main(String[] args) {
> shell.open ();
> display.dispose ();
> Thanks!
> Bob
Re: Why doesn't grab grab? [message #452207 is a reply to message #452199] |
Tue, 15 March 2005 08:07   |
My understanding is that grab just allocates the space. In order to
fill it you have to specify that you want the control to fill the space
as well. If you add another widget to the shell you'll see that it's
added at the bottom of the shell because the layout allocated all the
space it could to the tree, it just didn't fill the space. Grab is more
for allocation, fill actually takes care of consuming the allocated space.
GridData data = new GridData(GridData.FILL_BOTH);
//Widget to show what grab does.
Text text = new Text(shell, SWT.BORDER);
shell.open ();
display.dispose ();
Brad
> shell.open ();
> display.dispose ();
> Thanks!
> Bob
Re: Why doesn't grab grab? [message #452254 is a reply to message #452205] |
Tue, 15 March 2005 20:48  |
Thanks!
Bob
> You have:
>> shell.open ();
>> display.dispose ();
>>Thanks!
>>Bob
Current Time: Sun Jul 27 10:08:04 EDT 2025
Powered by FUDForum. Page generated in 0.05466 seconds
