Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Reproducing Gdesklet look and feel ?
Re: Reproducing Gdesklet look and feel ? [message #451823 is a reply to message #451753] |
Wed, 09 March 2005 10:54   |
Nobody could give me some hints ?
I've started with Snippet180 (emulate transparent shell) but is it
possible to put Label, Text, Button... instances in the generated region ?
hortiz wrote:
> I'm asked to develop particular components in my application (with should
> work both on Linux and Mac).
> These components can be dragged from the main window and dropped onto the
> desktop which will then create a new window having a Gdesklet look and
> feel.
> See different examples at :
> http://adesklets.sourceforge.net/images/weather_screen.jpg
http://www.lynucs.org/index.php?screen_type=1&screen_id= 5235311274028194baaf11&m=screen
> i.e. :
> - rounded corners,
> - transparent images displayed partially outside the window,
> - transparent window background,
> - possibility to display it "always on top",
> - shadowed,
> Please could you give hints about the possibilities offered by SWT ?
> Thanks a lot,
> Helene
Re: Reproducing Gdesklet look and feel ? [message #451825 is a reply to message #451823] |
Wed, 09 March 2005 11:07   |
Yes it is - just create and size the widgets as you would normally. Note
however that events will pass right through and go to whatever is behind the
widget if the widget is over a semi-transparent part of the shell. You
should probably make the shell solid in the area of the button. For a
Label, it is ok to be transparent because Labels don't respond to user
events anyway.
"hortiz" <hortiz@xxx.com> wrote in message
news:d0n67b$e26$1@www.eclipse.org...
> hortiz wrote:
>> Hi,
>> feel.
>> i.e. :
>> - rounded corners,
>> - shadowed,
>> Thanks a lot,
>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451835 is a reply to message #451825] |
Wed, 09 March 2005 11:28   |
Thanks Veronika for your answer.
But how do I make the shell solid in the area of the button ?
And can you give me your thoughts about my question on the Desklet look
and feel ?
Thanks in advance
Helene
> events anyway.
>> hortiz wrote:
>>> Hi,
>>> feel.
>>> i.e. :
>>> - rounded corners,
>>> - shadowed,
>>> Thanks a lot,
>>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451876 is a reply to message #451835] |
Thu, 10 March 2005 09:27   |
You make the button solid by adding all the pixels where the button is
located to the region used by the shell:
Region region = new Region();
Rectangle pixel = new Rectangle(0, 0, 1, 1);
for (int y = 0; y < 200; y+=2) {
for (int x = 0; x < 200; x+=2) {
pixel.x = x;
pixel.y = y;
region.add(pixel);
// make sure button is solid:
Rectangle bounds = button.getBounds();
for (int y = bounds.y; y < bounds.y + bounds.height; y++) {
for (int x = bounds.x; x < bounds.x + bounds.width; x++) {
pixel.x = x;
pixel.y = y;
region.add(pixel);
news:d0n878$pc5$1@www.eclipse.org...
> and feel ?
> Thanks in advance
> Helene
>> the widget if the widget is over a semi-transparent part of the shell.
>> You should probably make the shell solid in the area of the button. For
>> a Label, it is ok to be transparent because Labels don't respond to user
>> events anyway.
>>> hortiz wrote:
>>>> Hi,
>>>> should work both on Linux and Mac).
>>>> the desktop which will then create a new window having a Gdesklet look
>>>> and feel.
>>>> i.e. :
>>>> - rounded corners,
>>>> - shadowed,
>>>> Thanks a lot,
>>>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451878 is a reply to message #451876] |
Thu, 10 March 2005 09:45   |
Thanks a lot for your answer Veronika (and also for that regarding the
tranparent label in a transparent shell).
Regarding the "Desklet look and feel", I suppose it is a little too
ambitious ?!
Helene
> pixel.x = x;
> pixel.y = y;
> region.add(pixel);
> pixel.x = x;
> pixel.y = y;
> region.add(pixel);
>> and feel ?
>> Thanks in advance
>> Helene
>>> events anyway.
>>>> hortiz wrote:
>>>>> Hi,
>>>>> and feel.
>>>>> i.e. :
>>>>> - rounded corners,
>>>>> - shadowed,
>>>>> Thanks a lot,
>>>>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451883 is a reply to message #451878] |
Thu, 10 March 2005 10:48   |
You would be breaking new ground : )
news:d0pmit$ac8$1@www.eclipse.org...
> ambitious ?!
> Helene
>> pixel.x = x;
>> pixel.y = y;
>> region.add(pixel);
>> pixel.x = x;
>> pixel.y = y;
>> region.add(pixel);
>>> and feel ?
>>> Thanks in advance
>>> Helene
>>>> Note however that events will pass right through and go to whatever is
>>>> behind the widget if the widget is over a semi-transparent part of the
>>>> shell. You should probably make the shell solid in the area of the
>>>> button. For a Label, it is ok to be transparent because Labels don't
>>>> respond to user events anyway.
>>>>> region ?
>>>>> hortiz wrote:
>>>>>> Hi,
>>>>>> look and feel.
>>>>>> i.e. :
>>>>>> - rounded corners,
>>>>>> - shadowed,
>>>>>> Thanks a lot,
>>>>>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451888 is a reply to message #451883] |
Thu, 10 March 2005 11:34   |
ok now I get the picture ;-)
Thanks again
>> ambitious ?!
>> Helene
>>> pixel.x = x;
>>> pixel.y = y;
>>> region.add(pixel);
>>> pixel.x = x;
>>> pixel.y = y;
>>> region.add(pixel);
>>>> and feel ?
>>>> Thanks in advance
>>>> Helene
>>>>>> region ?
>>>>>> hortiz wrote:
>>>>>>> Hi,
>>>>>>> look and feel.
>>>>>>> i.e. :
>>>>>>> - rounded corners,
>>>>>>> - shadowed,
>>>>>>> Thanks a lot,
>>>>>>> Helene
Re: Reproducing Gdesklet look and feel ? [message #451889 is a reply to message #451883] |
Thu, 10 March 2005 11:47  |
Thanks again
>> ambitious ?!
>> Helene
>>> pixel.x = x;
>>> pixel.y = y;
>>> region.add(pixel);
>>> pixel.x = x;
>>> pixel.y = y;
>>> region.add(pixel);
>>>> and feel ?
>>>> Thanks in advance
>>>> Helene
>>>>>> region ?
>>>>>> hortiz wrote:
>>>>>>> Hi,
>>>>>>> look and feel.
>>>>>>> i.e. :
>>>>>>> - rounded corners,
>>>>>>> - shadowed,
>>>>>>> Thanks a lot,
>>>>>>> Helene
Current Time: Fri Jul 18 21:02:50 EDT 2025
Powered by FUDForum. Page generated in 0.18186 seconds
