Home » Eclipse Projects » Rich Client Platform (RCP) » How to disable actions in an context menu?
How to disable actions in an context menu? [message #451481] Wed, 21 June 2006 07:27 Go to next message
Originally posted by: dordepozega.amdosoft.com
Hi!
I would like to know how to disable lets say an
erase action on an selection where this action shouldnt
be possible. In short how to turn an action in an context
menu to gray.
Re: How to disable actions in an context menu? [message #451484 is a reply to message #451481] Wed, 21 June 2006 08:30 Go to previous messageGo to next message
Dorde Pozega wrote:
> Hi!
> menu to gray.
You can update the IAction on selection change within your action delegate.
Or, depending on the extension, you can add an <enabledment/> element to
each action. Check out the extension point description that you are
using (I assume it's org.eclipse.ui.popupMenus)
Later,
PW
Re: How to disable actions in an context menu? [message #451485 is a reply to message #451481] Wed, 21 June 2006 08:59 Go to previous message
I solved it .... the Action class has a method called setEnabled(boolean) ,
set as false and voila it disabled.
I tryed to solve this some time ago and really readed the hole API for
Action and didnt seen this method.
Thank you for the fast answer.
Regards.
"Dorde Pozega" <dordepozega@amdosoft.com> wrote in message
news:e7bafk$lqq$1@utils.eclipse.org...
> Hi!
> menu to gray.
> Regards
Previous Topic:How to show a splash image by launching RCP in the console?
Next Topic:IAction Text in CoolBar
Current Time: Mon Nov 03 01:48:56 EST 2025
Powered by FUDForum. Page generated in 0.05032 seconds
