Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to load an image from a JAR
How to load an image from a JAR [message #451134] Wed, 23 February 2005 23:32 Go to next message
I am simply trying to get an icon in my title bar which I have done
successfully, but it only works with an absolute path. I want to make it
relative to the project, or better yet, relative to the JAR file that it
will be exported to. Is there some way to reference the image by package,
like com.images.myimage.gif?
This is my current code.
Image icon = new Image(display, "F:\\some_image.gif");
parent.setImage(icon);
Thanks for any advice on this
Matt
Re: How to load an image from a JAR [message #451140 is a reply to message #451134] Thu, 24 February 2005 06:40 Go to previous messageGo to next message
Something like this should work
InputStream is =
this.getCalss().getClassLoader().getResourceAsStream("com/images/myimage.gif ");
Image icon = new Image(display, is);
Matt Rossner wrote:
> Matt
Re: How to load an image from a JAR [message #451188 is a reply to message #451140] Thu, 24 February 2005 08:11 Go to previous messageGo to next message
Don't forget to close the stream.
"Philippe Marschall" <kustos@gmx.net> wrote in message
news:cvkefp$tjh$1@www.eclipse.org...
> InputStream is =
> Matt Rossner wrote:
> > Hi,
package,
> > Matt
Re: How to load an image from a JAR [message #451194 is a reply to message #451188] Thu, 24 February 2005 09:26 Go to previous messageGo to next message
Uhm, I was thinking the new Image would manage to close the stream?
Now looking at the API, on the one hand it is told "Application code
is still responsible for closing the input stream" on the other hand
an example is given with
"This constructor may be used to load a resource as follows:
new Image(device, clazz.getResourceAsStream("file.gif"));"
which does not allow to close the stream since it is created inside
the Image-constructor
Ben
>>InputStream is =
>>Matt Rossner wrote:
>>>Hi,
>package,
>>>Matt
Re: How to load an image from a JAR [message #451199 is a reply to message #451194] Thu, 24 February 2005 09:43 Go to previous messageGo to next message
Originally posted by: broussea.irisa.fr
I have exactly the same issue.
The following SWT code:
Menu menuNew = new Menu(shell , SWT.DROP_DOWN);
MenuItem itemNew = new MenuItem(menuFile , SWT.CASCADE);
itemNew.setText("&New");
itemNew.setMenu(menuNew);
Image img = new Image(display, "images/new.gif");
itemNew.setImage(img);
generates a org.eclipse.swt.SWTException: i/o error
(java.io.FileNotFoundException: images/xml.gif (No such file or directory))
while executing the jar.
I have tried your solution of using an InputStream but it crashes the
application all together.
Also, using the full path to this image generates the
FileNotFoundException again.
Any ideas what can I do?
Cheers.
> Ben
>>> InputStream is =
>>> Matt Rossner wrote:
>>>> Hi,
>>>> make it
>>>> that it
>> package,
>>>> Matt
Re: How to load an image from a JAR [message #451204 is a reply to message #451199] Thu, 24 February 2005 10:03 Go to previous messageGo to next message
For this to work it can't be in a jar. This expects only local files.
If you don't mind bring JFace in, you can do:
Image i =
ImageDescriptor.createFromURL(this.getClass().getResource("/dir/file.gif ");
Here "dir" directory must be at the root of some jar in your classpath.
The leading slash "/" is very important. It tells getResource() to look
for the file starting from the root of the jars. If you did not have the
leading slash, it would add your this.getClass()'s package name in front
(after converting "." or "/"). So for example if your class was
a.b.MyClass, then this.getClass().getResource("dir/file.gif") would
actually look in your jars for "/a/b/dir/file.gif".
Or if you don't want JFace, then you will need to do:
Image i = null;
InputStream is = this.getClass().getResourceAsStream("/dir/file.gif");
if (is != null) {
try {
i = new Image(display, is);
} finally {
try {
is.close();
} catch (IOException e) {
Rich Kulp
Re: How to load an image from a JAR [message #451289 is a reply to message #451204] Thu, 24 February 2005 11:44 Go to previous messageGo to next message
Thanks for all the suggestions, I have what to try now
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:cvkqca$qk3$1@www.eclipse.org...
> Image i =
> Image i = null;
> if (is != null) {
> try {
> } finally {
> try {
> is.close();
> Rich Kulp
Re: How to load an image from a JAR [message #451319 is a reply to message #451194] Fri, 25 February 2005 09:56 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=86631
"Benjamin Pasero" <bpasero@rssowl.org> wrote in message
news:cvko7e$ere$1@www.eclipse.org...
> Ben
> >>InputStream is =
f
> >>Matt Rossner wrote:
> >>>Hi,
it
it
> >package,
> >>>Matt
Previous Topic:How to get local file icons?
Next Topic:Browser (IE) not generating WindowClosing event?
Current Time: Sat Jul 19 02:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.27239 seconds
