Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shell Control Drag-Move
Shell Control Drag-Move [message #450734] Thu, 17 February 2005 03:43 Go to next message
Because my application's Shell has special style [trim] requirements, I
have had to implement my own method for letting the user drag the window
to a new location on the Display. With the help of many of the
suggestions and samples available I almost have the desired behavior.
There is, however, one difference between my implementation and the
behavior on a Windows platform. On Windows, if you place the pointer in
the Title and press the left mouse button there is a perceptible delay
before the outline of the window appears. Thus, if the user should press
the left mouse button in the Title, but then not perform a dragging
gesture, the result would be a 'non-event'. [On SuSE with KDE, by the
way, there is no such delay -- as soon as you press the mouse, the outline
appears.]
While this is certainly not a life-threatening problem, I would really
like to know whether or not anyone has simulated the Windows behavior by
introducing some delay between the handling of the Mouse Down and the
Mouse Move events. Since there is some non-trivial set-up and tear-down
for handling the window re-location operation, it is, I think, worthwhile
to be able to recognize a 'non-event' if the buttom press turns out not be
be tied to a dragging of the window.
My guess is that there is some sort of 'time-state' machine in the native
Windows implementation. Clearly the low-level event handler takes on some
responsibility for distinguishing between a 'click' and a 'double-click'
and the difference is, I think, merely a question of the delay interval.
But if Mouse Down is never reported to my listener until the
'double-click-time-interval' has been passed, I would think that would be
about the right amount of time for my processing logic. Thus, if it
worked that way, I would know when receiving the Mouse Down event that a
finite delay has already occurred, so doing the set-up is worthwhile. If,
however, the low-level event handler inserts no delay, is it my
resonsibility to sense and handle a 'non-event' in case the user does not
begin dragging the window after a Mouse Down?
Re: Shell Control Drag-Move [message #450851 is a reply to message #450734] Fri, 18 February 2005 10:26 Go to previous messageGo to next message
Ok, without code, it's hard to know whether you are talking about a delay in
the native mouse down and dragging behavior on Windows (ie. when you click
on the title of a shell) or your implementation of dragging. If you had a
small stand alone example that showed the difference, we could determine
whether this is a bug/feature or just platform behavior.
"Terry Corbet" <tcorbet@ix.netcom.com> wrote in message
news:cv1lg7$2u8$1@www.eclipse.org...
> appears.]
Re: Shell Control Drag-Move [message #450865 is a reply to message #450851] Fri, 18 February 2005 13:22 Go to previous messageGo to next message
Thank you for the reply. I was about 20 minutes into an explanation of
my problem with annotations to snippets of the relevant code when I
discovered the answer to my own question. The bottom line is that I
need to 'avoid the overhead of attempting a shell move' if, in fact, no
movement is required. My mistake was that I performed the 'set up' for
the move in the mouseDown callback instead of putting it in the
mouseMovement callback inside a 'first Time' condition. That way if
the user depresses the button in the widget that is acting like the standard
title bar in my application, but then just does a release without having
introduced any motion, the 'outline for movement' will never appear.
The behavior of the 'low-level' event handler in discriminating between
single-click and double-click based on an elapsed interval cannot be
responsible for what I see in a native Windows application and my
simulation with the SWT widgets.
It seems like I ought to make a public apology for wasting the forum's time
with a question that I could have answered with more code review and
testing, but instead of that apology, I just want to add -- for public
view --
my thanks for the availability of the service. Another set of eyes looking
at
code is always good; sometimes just another set of neurons and synapses
asking 'what and why' is just as good. So thanks again for the reply and
questions.
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cv51n9$al8$1@www.eclipse.org...
in
press
outline
> > appears.]
worthwhile
be
native
some
be
If,
not
Re: Shell Control Drag-Move [message #451019 is a reply to message #450865] Mon, 21 February 2005 12:00 Go to previous message
Don't worry about it. The power of the snippet strikes again.
news:cv5bp2$slo$1@www.eclipse.org...
standard
time
> view --
looking
> at
> questions.
delay
> in
click
a
I
window
in
> press
> outline
> > > appears.]
by
tear-down
> worthwhile
not
> be
> native
> some
'double-click'
interval.
> be
a
> If,
> not
Previous Topic:setEnabled in Slider fails!!
Next Topic:Change Label style dynamically ?
Current Time: Fri Jul 18 17:29:48 EDT 2025
Powered by FUDForum. Page generated in 0.06983 seconds
