Home » Eclipse Projects » Standard Widget Toolkit (SWT) » FileDialog as Save As dialog
FileDialog as Save As dialog [message #450890] Sat, 19 February 2005 19:06 Go to next message
Originally posted by: bob.objfac.com
This came up in the rcp group. Thought someone here might have some advice.
David Beers wrote:
> What about using org.eclipse.swt.widgets.FileDialog?
A great suggestion. The only problem with FileDialog when used for Save
As is it doesn't complain if the file already exists, so if you want
confirmation you have to do it when the dialog is dismissed and put it
up again if the user Cancels. Minor, but UI is all about attention to
detail. Anyone know a way to get FileDialog to cooperate?
Bob Foster
Re: FileDialog as Save As dialog [message #451007 is a reply to message #450890] Mon, 21 February 2005 05:45 Go to previous messageGo to next message
> Bob Foster
Hi Bob,
according to MSDN, the behaviour you want is obtained when OPENFILENAME
has the following style set:
OFN_OVERWRITEPROMPT
Causes the Save As dialog box to generate a message box if the selected
file already exists. The user must confirm whether to overwrite the file.
It seems SWT doesn't give you much flexibility here. You have to hack the
FileDialog in a way. Take a look of FileDialog code and choose the better
place to change it...
Tiberiu
Re: FileDialog as Save As dialog [message #451030 is a reply to message #451007] Mon, 21 February 2005 19:43 Go to previous messageGo to next message
Thanks. I guess I should put in a feature request. Hopefully, there is a
way to do this on every platform.
Bob
Tiberiu Caprita wrote:
>> advice.
>> Save As is it doesn't complain if the file already exists, so if you
>> want confirmation you have to do it when the dialog is dismissed and
>> put it up again if the user Cancels. Minor, but UI is all about
>> attention to detail. Anyone know a way to get FileDialog to cooperate?
>> Bob Foster
> Hi Bob,
> OFN_OVERWRITEPROMPT
> the FileDialog in a way. Take a look of FileDialog code and choose the
> better place to change it...
> Regards,
> Tiberiu
Re: FileDialog as Save As dialog [message #451064 is a reply to message #451030] Tue, 22 February 2005 09:04 Go to previous message
It's an old feature request that might need to be revisited.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=4727
"Bob Foster" <bob@objfac.com> wrote in message
news:421A803C.9040109@objfac.com...
> Bob
> >> advice.
> >> Bob Foster
> > Hi Bob,
> > OFN_OVERWRITEPROMPT
file.
> > Regards,
> > Tiberiu
Previous Topic:How to get labels to resize themselves in a composite?
Next Topic:SWT slowing doing after a couple of hour
Current Time: Fri Jul 18 22:20:32 EDT 2025
Powered by FUDForum. Page generated in 0.03337 seconds
