Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » DBGp Debug Commands and Encoding.
DBGp Debug Commands and Encoding. [message #4063] Wed, 16 May 2007 10:16 Go to next message
Reading the DBGp specification, I see it states commands should be sent as ASCII. However that
I think poses a problem. A command may be in ASCII and filenames converted to a URI is convertable
to ASCII, but what about other inserts such as variable names and method names that may not
be in ascii format ? Especially with Java which works with strings, a conversion to ASCII would fail if it contained
codepoints that cannot be represented in ASCII.
I also see in the DBGp specification reference to a feature called encoding which defines the debug session
encoding. This could imply to me that the commands could be sent in this encoding and the xml returned
will be in this encoding, but is not well defined in the documentation.
I was wondering how DLTK handles the issue of commands which could contain non ASCII representable information ?
Dave Kelsey
Re: DBGp Debug Commands and Encoding. [message #4229 is a reply to message #4063] Thu, 17 May 2007 08:43 Go to previous messageGo to next message
Hello Dave,
Of course commands in ASCII encoding are the source of problems. We
understand it and thinking about good general solution for script
languages. Unfortunately DBGp specification doesn't give clear
understanding of usage the 'encoding' feature. I think the problem only
in commands from IDE to debugging engine because xml response already
has encoding in the header "<?xml version="1.0" encoding="UTF-8"?>". So
our possible solution is usage of 'encoding' feature only for commands
for IDE commands. For now we doesn't check this feature and send
commands in plain ASCII encoding.
Dmitriy Kovalev
> names that may not
> Dave Kelsey
Re: DBGp Debug Commands and Encoding. [message #4299 is a reply to message #4229] Thu, 17 May 2007 08:57 Go to previous messageGo to next message
Hi Dmitriy,
I have considered interpreting the feature "encoding" as follows.
1. as the encoding to be used for the XML response (encoding is
a feature that can be set).
2. as the encoding for commands.
With 2, the encoding must be a superset of the ASCII codeset, to allow
for programs which have compiled the commands into their code as ascii
bytes (which is not unreasonable).
What do you think ?
Dave Kelsey
Dmitriy Kovalev wrote:
> Hello Dave,
> Dmitriy Kovalev
>> Dave Kelsey
Re: DBGp Debug Commands and Encoding. [message #4437 is a reply to message #4299] Fri, 18 May 2007 09:29 Go to previous messageGo to next message
Hi Dave,
Thank you for your comments, I think your interpretation of 'encoding'
is right and acceptable. We will implement this scheme for ruby in the
nearest future. UTF-8 is the best choice because it's a superset of
ASCII and encodes unicode symbols.
But there is one small problem: first "init" command from debugging
engine (before feature negotiation) should be sent in the predefined
encoding. "init" xml request has only one problem attribute "fileuri"
and we should decide what to do with it.
Dave Kelsey wrote:
> Hi Dmitriy,
> What do you think ?
> Dave Kelsey
>> Hello Dave,
>> only in commands from IDE to debugging engine because xml response
>> already has encoding in the header "<?xml version="1.0"
>> encoding="UTF-8"?>". So our possible solution is usage of 'encoding'
>> feature only for commands for IDE commands. For now we doesn't check
>> this feature and send commands in plain ASCII encoding.
>> Dmitriy Kovalev
>>> Dave Kelsey
Re: DBGp Debug Commands and Encoding. [message #4507 is a reply to message #4437] Fri, 18 May 2007 10:01 Go to previous message
Hi Dmitriy,
I don't think init is a problem.
As it is XML, it will have an encoding (so an engine may want to use UTF-8
as a default encoding anyway), but I think ascii would also work. A fileuri
comprises of ASCII characters. when a file is converted to a URI, it encodes
non ascii characters to escaped UTF-8 values.
Dave Kelsey
> Hi Dave,
> Dave Kelsey wrote:
>> Hi Dmitriy,
>> What do you think ?
>> Dave Kelsey
>>> Hello Dave,
>>> Dmitriy Kovalev
>>>> Dave Kelsey
Previous Topic:execute arbitrary scripts
Next Topic:parsing performance issues
Current Time: Fri Oct 17 04:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.04039 seconds
