Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Custom Control Traversal
Custom Control Traversal [message #450513] Mon, 14 February 2005 14:30 Go to next message
I am having trouble understanding focus traversal in a custom control. I
have a custom control that extends composite. My custom control contains
three other custom controls. I want to traverse these custom controls in
order as a tab group.
I have played around with the few things I have found in this forum
(archive) to help me get a grasp on understanding traversal.... however I
am coming up more confused than when I began.
Do I need to implement traversal on my own (simply setting the tab list
does not do the trick)? If so, do I do this in a traverse listener for
each control in my composite or in a traverse listener for for my custom
control (composite)? Do I do this using the traverse() method or is the
setFocus() method prefered?
Re: Custom Control Traversal [message #450554 is a reply to message #450513] Tue, 15 February 2005 10:04 Go to previous messageGo to next message
Is focus ever supposed to go to the parent of the three other custom
controls?
Have you seen Snippet21? It might be exactly what you are looking for to
use with the three controls.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet21.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
If you could post a small stand alone snippet, we could probably help you
more.
"Scott Pelton" <scottp@worldpac.com> wrote in message
news:cuqu80$am1$1@www.eclipse.org...
Re: Custom Control Traversal [message #450588 is a reply to message #450554] Tue, 15 February 2005 13:42 Go to previous messageGo to next message
> controls?
No, just the custom child controls.
Here is the design of my custom control:
Composite comp0 - is the parent.
Composite comp1 - is a child of comp0.
Composite comp2 - is a child of comp0.
Composite comp3 - is a child of comp0.
comp1 contains 2 Labels
comp2 contains n Canvas (where n >= 1; generally 1 to 3)
comp3 contains 1 Button
I want focus order to be:
comp1, comp2(canvas[0]), comp2(canvas[1]), ..., comp2(canvas[n]),
comp2(Button);
Yes, this is where I started.
> more.
I will work on getting one posted. BTW, I am developing for PPC.
Re: Custom Control Traversal [message #450642 is a reply to message #450588] Wed, 16 February 2005 08:58 Go to previous messageGo to next message
Ok, I'll wait for the snippet.
news:cutfrd$bmn$1@www.eclipse.org...
> > controls?
> comp2(Button);
to
you
> > more.
I
contains
in
I
custom
Re: Custom Control Traversal [message #450722 is a reply to message #450642] Wed, 16 February 2005 19:34 Go to previous messageGo to next message
Here is the snippet.....it is quite long...
the main class "snippet_DPPanel" plus five classes (1 inner and 1 inner
inner)
import java.util.*;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
* @author spelton Feb 16, 2005
* Snippet to test custom control (DPPanel)
* I am having trouble getting tabbing to work.
* NOTE1: to be run on pocket pc
* NOTE2: if you pass in an integer n on the command line then n controls
will be created
* (recommend n=5) otherwise two controls are created.
* NOTE3: there is no functionality in this snippet
* (except for a popup menu appearing upon clicking down arrow button)
public class snippet_DPPanel
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display, SWT.NONE);
shell.setLayout(new GridLayout());
Menu bar = new Menu(shell, SWT.BAR);
shell.setMenuBar(bar);
int cnt = 2;
try
cnt = Integer.parseInt(args[0]);
catch(Exception e)
//just test data
DPPanel[] dpp = new DPPanel[cnt];
for(int i = 0; i < cnt; i++)
dpp[i] = new DPPanel(shell, "test"+i, i+1);
dpp[i].setLayoutData(new GridData(GridData.FILL_BOTH));
dpp[0].setFocus();
shell.open();
while(!shell.isDisposed())
if(!display.readAndDispatch ()) display.sleep();
display.dispose();
class DPPanel extends Composite
ImageLabel imglblIdentifier;
Label lblStatus;
BoxesPanel boxesPanel;
FormData fd1;
ArrowButtonPanel abPanel;
Menu popupMenu;
MenuItem itemPartial, itemLater, itemCancel, itemReset;
int iBoxes;
* Constructor for DPPanel.
* @param arg0 - Composite to which this DPPanel is a child of.
* @param sID - identifies this delivery/pickup (i.e. Pick Ticket #)
* @param iBoxes - number of packages
* Generic constructor
public DPPanel(Composite arg0, String sID, int iBoxes)
super(arg0, SWT.NONE);
this.iBoxes = iBoxes;
//creat layout stuff
FormLayout fl = new FormLayout();
fl.marginWidth = 2;
fl.marginHeight = 2;
this.setLayout(fl);
FormData fd0 = new FormData();
fd0.left = new FormAttachment(0 ,2);
fd0.top = new FormAttachment(0 ,2);
//add identifier label
imglblIdentifier = new ImageLabel(this, SWT.LEFT);
imglblIdentifier.setImage(null);
imglblIdentifier.setText(sID);
imglblIdentifier.setLayoutData(fd0);
FormData fd2 = new FormData();
fd2.top = new FormAttachment(0,-4);
fd2.right = new FormAttachment(100, 0);
//add arrow button
abPanel = new ArrowButtonPanel(this);
abPanel.setLayoutData(fd2);
//do popup menu stuff
popupMenu = new Menu(this);
itemPartial = new MenuItem(popupMenu, SWT.PUSH);
itemPartial.setText("Partial");
itemLater = new MenuItem(popupMenu, SWT.PUSH);
itemLater.setText("Later");
itemCancel = new MenuItem(popupMenu, SWT.PUSH);
itemCancel.setText("Cancel");
itemReset = new MenuItem(popupMenu, SWT.PUSH);
itemReset.setText("Reset");
fd1 = new FormData();
fd1.top = new FormAttachment(0,-4);
fd1.left = new FormAttachment(30, 2);
fd1.right = new FormAttachment(90, 0);
boxesPanel = new BoxesPanel(this, iBoxes, 0);
boxesPanel.setLayoutData(fd1);
//add listeners
addListeners();
public void setBackground(Color clr)
super.setBackground(clr);
imglblIdentifier.setBackground(clr);
abPanel.setBackground(clr);
boxesPanel.setBackground(clr);
void addListeners()
this.addDisposeListener(new DisposeListener()
public void widgetDisposed(DisposeEvent e)
this.addListener(SWT.Traverse, new Listener()
public void handleEvent(Event e)
switch(e.detail)
/* Do tab group traversal */
case SWT.TRAVERSE_ESCAPE:
case SWT.TRAVERSE_RETURN:
case SWT.TRAVERSE_TAB_NEXT:
case SWT.TRAVERSE_TAB_PREVIOUS:
case SWT.TRAVERSE_PAGE_NEXT:
case SWT.TRAVERSE_PAGE_PREVIOUS:
e.doit = true;
break;
this.addListener(SWT.FocusIn, new Listener()
DPPanel.this.redraw();
this.addListener(SWT.FocusOut, new Listener()
abPanel.ab.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
showPopupMenu();
abPanel.ab.addKeyListener(new KeyAdapter()
public void keyDown(KeyEvent e)
if(e.character == SWT.CR) showPopupMenu();
void showPopupMenu()
if(popupMenu.isVisible()) return;
Rectangle rect = abPanel.ab.getBounds();
rect = Display.getCurrent().map(abPanel.ab.getParent(), null, rect);
int x = rect.x;
int y = rect.y + rect.height;
//note: menu.getSize() will be available in SWT3.0 M8
//which may not help here if it only returns size of a visible menu
//see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=48341
//show popup menu
int xAlign =54;
popupMenu.setLocation(x-xAlign, y-1);
popupMenu.setVisible(true);
* INNER class
* control that represents the number of pkgs
class BoxesPanel extends Composite
BoxButton[] bbArray;
int iBoxes;
* @author spelton Nov 24, 2003
* CONSTR
public BoxesPanel(Composite arg0, int iB, int iL)
RowLayout rl = new RowLayout(SWT.HORIZONTAL);
rl.marginWidth = 2;
rl.marginHeight = 2;
this.setLayout(rl);
this.iBoxes = iB;
int n = 0;
if(iL > iB) n = iL - iB;
bbArray = new BoxButton[iBoxes+n];
//do boxes up to pkg count
int i = 0;
for(; i < iBoxes; i++)
bbArray[i] = new BoxButton(this, i);
bbArray[i].setLayoutData(new RowData(17,17));
switch(e.detail)
e.doit = true;
break;
BoxesPanel.this.redraw();
public void setEnabled(boolean b)
super.setEnabled(b);
for (int i = 0; i < bbArray.length; i++)
bbArray[i].setEnabled(b);
* INNER INNER class
class BoxButton extends Canvas
final static int PKG_NOT_LOADED = 20;
int iState = PKG_NOT_LOADED;
String sID;
private boolean bEnabled = true;
Color clrTopTri;//previous bckgrnd color
* @author spelton Nov 26, 2003
* CONSTR
public BoxButton(Composite parent, int idx)
super(parent, SWT.NO_BACKGROUND);
this.sID = Integer.toString(idx+1);
clrTopTri = getBackground();
addListeners();
* @author spelton Feb 9, 2005
void addListeners()
this.addPaintListener(new PaintListener()
public void paintControl(PaintEvent e)
paint();
switch(e.detail)
e.doit = true;
break;
BoxButton.this.redraw();
* override setEnabled
bEnabled = b;
paint();
public boolean isEnabled(){ return bEnabled; }
* draw this box button
void paint()
GC gc = new GC(this);
gc.setBackground(getBackground());
gc.setForeground(getForeground());
gc.setLineWidth(this.isFocusControl() ? 3 : 1);
//draw box border
gc.drawRectangle(0, 0, 16, 16);
//draw box id - package number
String fnt_name = gc.getFont().getFontData()[0].getName();
Font f = new Font(Display.getCurrent(), fnt_name, 7, SWT.NORMAL);
gc.setFont(f);
Point pt = gc.stringExtent(sID);
gc.drawString(sID, 8-pt.x/2, 8-pt.y/2, true);
f.dispose();
gc.dispose();
class ArrowButtonPanel extends Composite
Button ab;
* CONSTR
public ArrowButtonPanel(Composite arg0)
rl.marginWidth = 0;
this.setLayout(rl);
ab = new Button(this, SWT.ARROW | SWT.DOWN);
ab.setLayoutData(new RowData(17,17));
addListeners();
this.setTabList(new Control[] {ab});
void addListeners()
switch(e.detail)
e.doit = true;
break;
ArrowButtonPanel.this.redraw();
class ImageLabel extends Composite
Label lblImage, lblText;
* Constructor for ImageLabel.
* @param arg0
* @param arg1
public ImageLabel(Composite arg0, int arg1)
super(arg0, arg1);
fl.marginWidth = 1;
fl.marginHeight = 1;
this.setLayout(fl);
FormData fd00 = new FormData();
fd00.left = new FormAttachment(0,0);
fd00.top = new FormAttachment(0,0);
//add image label
lblImage = new Label(this, SWT.CENTER | SWT.NO_FOCUS);
lblImage.setLayoutData(fd00);
fd0.left = new FormAttachment(lblImage, 2);
fd0.top = new FormAttachment(0,0);
//add text label
lblText = new Label(this, SWT.LEFT | SWT.NO_FOCUS);
lblText.setLayoutData(fd0);
addListeners();
* @author spelton Dec 17, 2004
void addListeners()
//underline text
lblText.addPaintListener(new PaintListener()
Point p = e.gc.textExtent(lblText.getText());
e.gc.drawLine(0, p.y-1, p.x, p.y-1);
switch(e.detail)
e.doit = true;
break;
ImageLabel.this.redraw();
//draw focus border
paint();
* @author spelton Feb 8, 2005
void paint()
if(isFocusControl())
Rectangle r = getBounds();
gc.drawFocus(0,0,r.width,r.height);
else
gc.setForeground(getBackground());
gc.drawRectangle(0,0,r.width,r.height);
gc.dispose();
* @author spelton May 27, 2004
public void setImage(Image img)
lblImage.setImage(img);
public void setText(String s)
lblText.setText(s);
lblImage.setBackground(clr);
lblText.setBackground(clr);
>> > controls?
>> comp2(Button);
> to
> you
>> > more.
> I
> contains
> in
> I
> custom
Re: Custom Control Traversal [message #450756 is a reply to message #450722] Thu, 17 February 2005 13:25 Go to previous message
Yikes ... that's a lot of code. Ok, it was impossible for me to know if it
was working but when I added key listeners to the various components, I was
able to tab around. You need to add a key listener to a control or it won't
get focus (because there is nobody processing keys).
news:cv0org$n87$1@www.eclipse.org...
> inner)
> import java.util.*;
> will be created
> int cnt = 2;
> try
> catch(Exception e)
> //just test data
> dpp[0].setFocus();
> shell.open();
> display.dispose();
> Label lblStatus;
> FormData fd1;
> Menu popupMenu;
> int iBoxes;
> fl.marginWidth = 2;
> this.setLayout(fl);
> //add arrow button
> //add listeners
> addListeners();
> void addListeners()
> switch(e.detail)
> e.doit = true;
> break;
> showPopupMenu();
> int x = rect.x;
> //show popup menu
> int xAlign =54;
> * INNER class
> int iBoxes;
> * CONSTR
> rl.marginWidth = 2;
> this.setLayout(rl);
> this.iBoxes = iB;
> int n = 0;
> int i = 0;
> switch(e.detail)
> e.doit = true;
> break;
> * INNER INNER class
> String sID;
> * CONSTR
> addListeners();
> void addListeners()
> paint();
> switch(e.detail)
> e.doit = true;
> break;
> bEnabled = b;
> paint();
> void paint()
> //draw box border
> gc.setFont(f);
> f.dispose();
> gc.dispose();
> Button ab;
> * CONSTR
> rl.marginWidth = 0;
> this.setLayout(rl);
> addListeners();
> void addListeners()
> switch(e.detail)
> e.doit = true;
> break;
> * @param arg0
> * @param arg1
> super(arg0, arg1);
> fl.marginWidth = 1;
> this.setLayout(fl);
> //add image label
> //add text label
> addListeners();
> void addListeners()
> //underline text
> switch(e.detail)
> e.doit = true;
> break;
> //draw focus border
> paint();
> void paint()
> else
> gc.dispose();
> lblText.setText(s);
> >> > controls?
> >> comp2(Button);
for
> > to
> > you
> >> > more.
control.
> > I
> > contains
controls
> > in
however
> > I
list
for
> > custom
the
Previous Topic:swt-gdip-win32.dll in latest SWT ?
Next Topic:Eclipse Windows Properties
Current Time: Thu Sep 18 04:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.07428 seconds
