| Resource Perspective diplays nothing... [message #450313] |
Thu, 01 June 2006 11:24  |
Originally posted by: cboudjennah.hotmail.com
Hi everybody!Im developing a RCP application which uses workspaces and I
have a problems: the clients may use the resources perspective (they used
it when we gave them the plug in version of the application
) and now, in
RCP mode, the resource perspective displays NOTHING!!!I dont understand
why
LCould someone please help me?Thanks by advance!!!
| Re: Resource Perspective diplays nothing... [message #450455 is a reply to message #450404] |
Fri, 02 June 2006 13:53   |
Originally posted by: liana_bl.yahoo.com.br
Paul Webster wrote:
> Ah, so first of all you have to make sure you have a workspace? Do you
> have access to ResourcesPlugin.getWorkspace().getRoot()?
> Secondly, you have to update your defaultPageInput() on one of the
> advisors to return ResourcesPlugin.getWorkspace().getRoot()
> I was told the default input to those kinds of navigators is the
> page.getInput(), which is set upon workbench window/page creation time.
> Later,
> PW
Hi Paul,
I have this same problem... I did what you said, and now its appearing the
dots (...) in the navigator view, like when a folder would be visualized.
But instead of the folder I get the error "!MESSAGE Problems occurred when
invoking code from plug-in: "org.eclipse.jface".!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:", and no
image or text is shown.
the .log file is attached bellow.
Do you know why?
Thanks in advance,
Liana
!SESSION 2006-06-02 14:49:25.691
eclipse.buildId=unknown
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Framework arguments: -product org.rise.prototipo -pdelaunch
Command-line arguments: -product org.rise.prototipo -data
D:\eclipseRC6\workspace/../runtime-EclipseApplication -dev
file:D:/eclipseRC6/workspace/.metadata/.plugins/org.eclipse. pde.core/Eclipse
Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2006-06-02 14:49:29.598
!MESSAGE A workspace crash was detected. The previous session did not exit
normally.
!ENTRY org.eclipse.jface 4 2 2006-06-02 14:49:32.973
!MESSAGE Problems occurred when invoking code from plug-in:
!STACK 0
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
at
org.eclipse.ui.internal.navigator.extensions.NavigatorConten tExtension. <init>(NavigatorContentExtension.java:87)
at
org.eclipse.ui.internal.navigator.NavigatorContentService.ge tExtension(NavigatorContentService.java:842)
at
org.eclipse.ui.internal.navigator.NavigatorContentService.ge tExtension(NavigatorContentService.java:812)
at
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.findUpdateLabel(NavigatorContentServiceLabelProvi der.java:330)
at
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.updateLabel(NavigatorContentServiceLabelProvider. java:307)
at
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:345)
at
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:2077)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:247)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:95)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:465)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1955)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:744)
at
org.eclipse.ui.navigator.CommonViewer.createTreeItem(CommonV iewer.java:116)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:722)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:696)
at
org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:872)
at
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1277)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1323)
at
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1266)
at
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:250)
at
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1542)
at
org.eclipse.ui.navigator.CommonNavigator.createPartControl(C ommonNavigator.java:156)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 0)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 5)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1144)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1097)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 11)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:601)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:532)
at
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:562)
at
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:244)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:815)
at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2429)
at
org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:2616)
at
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2597)
at
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:658)
at
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:795)
at
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1437)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1388)
at
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:708)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.rise.prototipo.toolday.intro.Application.run(Application .java:18)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.691
!MESSAGE Invalid Menu Extension (Path is invalid): converstLineDelimitersTo
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.801
org.eclipse.ui.edit.text.delimiter.macOS9
org.eclipse.ui.edit.text.delimiter.unix
org.eclipse.ui.edit.text.delimiter.windows
org.eclipse.ui.edit.text.openExternalFile
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.816
!MESSAGE Invalid Menu Extension (Path is invalid): selectWorkingSets
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.832
org.eclipse.ui.edit.text.gotoLastEditPosition
| Re: Resource Perspective diplays nothing... [message #450664 is a reply to message #450570] |
Tue, 06 June 2006 15:43  |
Paul Webster wrote:
> you probably need to override WorkbenchAdvisor#initialize(*) and add:
> WorkbenchAdapterBuilder.registerAdapters();
> WorkbenchAdvisor is also where you override getDefaultPageInput().
> Check out IDEWorkbenchAdvisor in the org.eclipse.ui.ide plugin.
> Later,
> PW
Hi Paul,
Thanks it works...
however the project icon doesn't appear.
I looked the IDEWorkbenchAdvisor and tried to refer the same icon it does
for the project, but it is not possible because is a internal class.
Do know another way?
Thanks again,
Liana
FUDForum. Page generated in 0.05004 seconds
