Home » Eclipse Projects » Rich Client Platform (RCP) » Why "Switch workspace" fail?
Why "Switch workspace" fail? [message #433390] Tue, 05 July 2005 03:22 Go to next message
I complete a rcp application based on eclipse 3.1. The subclass of
ActionBarAdvisor is similar to WorkbenchActionBuilder.
Everything is okey, but "Switch workspace" fail. The workspace is always the
first. I debug the OpenWorkspaceAction and find the command line includes
the new workspace path. Why does the workspace not change after restart?
Thanks!
Re: Why "Switch workspace" fail? [message #449785 is a reply to message #433390] Fri, 19 May 2006 08:15 Go to previous messageGo to next message
Originally posted by: cboudjennah.hotmail.com
I have the same problem... :-/
Does anybody know from where it could come from???
Re: Why "Switch workspace" fail? [message #449906 is a reply to message #449785] Wed, 24 May 2006 11:42 Go to previous messageGo to next message
I watched the eclipse sources, and especially org.eclipse.ui.internal.ide. IDEApplication and I modified my class which implements Runnable in order to let her know about the “EXIT_RELAUNCH” constant:
if (returnCode != PlatformUI.RETURN_RESTART)                return EXIT_OK;
// if the exit code property has been set to the relaunch //code, then
// return that code now, otherwise this is a normal restart
return EXIT_RELAUNCH.equals(Integer.getInteger(PROP_EXIT_CODE)) ? EXIT_RELAUNCH                    : EXIT_RESTART;
After that, the switch workspace action seems to lead to a simple stop of the application… :-/Then, I tried to debug Eclipse in order to know what was going on…And when I came to the org.eclipse.core.launcher.Main class, I could see that it seems that the setExitData() method needs a command line argument “-exitdata” and that if this one isn’t there, the program simply returns:
 private void setExitData() {
String data = System.getProperty(PROP_EXITDATA);
if (exitData == null || data == null)
return;
// sync call to the launcher
runCommand(true, new String[] {EXITDATA, exitData, data}); //$NON-NLS-1$    }
So I have 2 questions:->Am I on the good way??->Does anybody know anything about this “exitdata” argument?
Thanks by advance!
Re: Why "Switch workspace" fail? [message #450189 is a reply to message #449906] Tue, 30 May 2006 06:50 Go to previous messageGo to next message
Well, I tried something this morning: I launched an instance of Eclipse
from Eclipse itself to see if the switch workspace worked: it didn’t!!!
Same behavior as my application since I added references to
“EXIT_RELAUNCH” into my IplatformRunnable: it ended without launching any
new process….So I tried again to export my product and to use the “switch
workspace” and it worked!!!So, in conclusion, you need to add the
IDEActionFactory.OPEN_WORKSPACE action, and you have to modify your
IplatformRunnable implementing class this way:
    if (returnCode !=
PlatformUI.RETURN_RESTART)                return EXIT_OK;            // if
the exit code property has been set to the relaunch code, then
and it should work,
but not if you launch your product from Eclipse!
icon14.gif  Re: Why "Switch workspace" fail? [message #817519 is a reply to message #450189] Sat, 10 March 2012 02:05 Go to previous message
The way to resolve "Switch workspace" problem is helpful. Thanks!
Previous Topic:Popup menu, objectContribution
Next Topic:[Solved] List every available perspective by default
Current Time: Thu Jul 24 22:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.03045 seconds
