Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How do I change a button background color ???
How do I change a button background color ??? [message #449543] Wed, 26 January 2005 04:17 Go to next message
Originally posted by: gilblais.yahoo.com
I cannot seem to display anything but a gray button with black lettering -
any help is well appreciated. Thanks, Gil Blias
Re: How do I change a button background color ??? [message #449544 is a reply to message #449543] Wed, 26 January 2005 04:24 Go to previous messageGo to next message
Originally posted by: matthew1801.hotmail.com
Button is inherited from Control, so you can use the setBackground(Color
color) function - under Control - to change the background color of the
button.
Matthew
"Gil Blais" <gilblais@yahoo.com> wrote in message
news:ct7n84$sms$1@www.eclipse.org...
Re: How do I change a button background color ??? [message #449550 is a reply to message #449544] Wed, 26 January 2005 05:14 Go to previous messageGo to next message
Matt - thank you, but when I do that I end up with the entire display having
its color changed instead of just the button. Here are the lines of code:
final Button btnCAS = new Button(shell, SWT.NONE);
btnCAS.setSelection(true);
btnCAS.getParent().setBackground(Display.getCurrent().getSys temColor(SWT.COLOR_RED));
"Matthew Ma" <matthew1801@hotmail.com> wrote in message
news:ct7nqn$v56$1@www.eclipse.org...
> button.
> Matthew
>> lettering -
Re: How do I change a button background color ??? [message #449552 is a reply to message #449550] Wed, 26 January 2005 07:55 Go to previous messageGo to next message
Originally posted by: armin.roth.visana.ch
Hi Gil
Use this instead:
btnCAS.setBackground(Display.getCurrent().getSystemColor(SWT .COLOR_RED));
the .getParent() made you change the buttons parent (the shell you used
for constructing the button) background color.
Be aware of that Display.getCurrent() may deliver null if this code is
running outside of the SWT-Thread.
Kind regards,
Armin Roth
>> button.
>> Matthew
>>> lettering -
Re: How do I change a button background color ??? [message #449709 is a reply to message #449543] Thu, 27 January 2005 19:49 Go to previous messageGo to next message
You can't on Windows. Nobody can. The operating system doesn't support it.
Re: How do I change a button background color ??? [message #449720 is a reply to message #449552] Fri, 28 January 2005 03:41 Go to previous message
Hi Armin - thank you, but that result was the same. Here is the code snippet
I am using.
--- cut here ---
package UI;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
public class PB_xxx implements INTERFACES.IF {
new PB_xxx().runTHIS(new String[] { });
void runTHIS(String[] args) {
Display display = new Display();
final Shell shell = new Shell(display);
shell.setSize(395,80);
btnCAS.setText("Contracting Administration Screen");
btnCAS.setForeground(Display.getCurrent().getSystemColor(SWT .COLOR_RED));
// left,top,width,height
btnCAS.setBounds(10, 10, 360, 30);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
--- end ---
"Armin Roth" <armin.roth@visana.ch> wrote in message
news:ct83vh$jdu$1@www.eclipse.org...
> Hi Gil
> Use this instead:
> Kind regards,
> Armin Roth
>> having its color changed instead of just the button. Here are the lines
>> of code:
>>> button.
>>> Matthew
>>>> lettering -
Previous Topic:DnD: Outlook email to SWT table
Next Topic:How to undo from a Text??
Current Time: Sat Jul 26 16:06:14 EDT 2025
Powered by FUDForum. Page generated in 0.06012 seconds
