Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shortcuts in SWT? (accelerators)
Shortcuts in SWT? (accelerators) [message #449470] Tue, 25 January 2005 04:20 Go to next message
Originally posted by: olivier.larivain.criltechnology.com
I'm actually trying to add shortcuts to my standalone SWT application.
The only I found about shortcuts in the documentations seems to refer to
Menu and MenuItem, but I just couldn't get any
confirmation about this.
I'm not using menus, but toolbars instead.
Though, I tried the following in the actions added to the toolbar
(AbstractAction being some kind of convenience superclass, subclassing
org.eclipse.jface.action.Action :
public class DisconnectAction extends AbstractAction {
public DisconnectAction(ApplicationWindow mainWindow) {
super(mainWindow);
setText(TEXT);
setToolTipText(TOOL_TIP_TEXT);
setImageDescriptor(ImageProvider.getInstance(GuiProperties.I MAGES_DIR).getIm
ageDescriptor(IMAGE_NAME));
setEnabled(true);
setAccelerator(convertAccelerator("Ctrl+q"));
All actions look the same, and are added to a ToolBarManager.
Of course, this doesn't work.. :( Nothing happens when I press Ctrl+q
I googlized the more i could, I still don't understand how shortcuts works
in SWT.
Could anyone please help me out?
Re: Shortcuts in SWT? (accelerators) [message #449510 is a reply to message #449470] Tue, 25 January 2005 10:17 Go to previous messageGo to next message
Shortcuts (called Accelerators in SWT) are always properties of MenuItems.
They are global to a window in the same way that a menu bar is global. If
you want accelerators without MenuItems, then you need to either hook
SWT.KeyDown or filter key events these events in Display. The later is what
Eclipse does to implement accelerators.
"Larivain Olivier" <olivier.larivain@criltechnology.com> wrote in message
news:ct531n$asd$1@www.eclipse.org...
> super(mainWindow);
> setText(TEXT);
> setEnabled(true);
> in SWT.
Re: Shortcuts in SWT? (accelerators) [message #449519 is a reply to message #449510] Tue, 25 January 2005 11:18 Go to previous messageGo to next message
Thank you very much!!!
I spent a lot of time on this, and I was starting to think that there there
was no issue to this problem.
while i'm here, i'll ask a few more questions about this :
Why this choice has been made?
How come toolbars can't have accelerators?
They work roughly the same as menus do, so have this difference?
"Steve Northover" <steve_northover@ca.ibm.com> a
Re: Shortcuts in SWT? (accelerators) [message #449686 is a reply to message #449519] Thu, 27 January 2005 19:42 Go to previous message
This decision was force by the operating systems. You can use mnemonics in
toolbars with text.
news:ct5rh7$km2$1@www.eclipse.org...
there
Previous Topic:How to handle window closing event?
Next Topic:Double click activates other app?
Current Time: Fri Jul 18 07:11:35 EDT 2025
Powered by FUDForum. Page generated in 0.08577 seconds
