Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Double click activates other app?
Double click activates other app? [message #449525] |
Tue, 25 January 2005 13:08  |
Originally posted by: fangsh.appliedbiosystems.com
I am developing a Windows application with RCP architecture on Eclipse
3.0+. We have views that are supposed to react to double click actions.
However, the double click event sometimes activates another application
that sits in the background. I understand this might be a windows
"feature" from the Eclipse source code comments:
* Feature in Windows. When multiple shells are
* disabled and one of the shells has an enabled
* dialog child and the user selects a disabled
* shell that does not have the enabled dialog
* child using the Task bar, Windows brings the
* disabled shell to the front. As soon as the
* user clicks on the disabled shell, the enabled
* dialog child comes to the front. This behavior
* is unspecified and seems strange. Normally, a
* disabled shell is frozen on the screen and the
* user cannot change the z-order by clicking with
* the mouse. The fix is to look for WM_ACTIVATEAPP
* and force the enabled dialog child to the front.
* This is typically what the user is expecting.
I tried, after the mouse down event, calling
OS.SetActiveWindow(parent.getShell().handle);
parent.getShell().forceActive();
it didn't work.
I tried,
int flags = OS.SWP_NOSIZE | OS.SWP_NOMOVE | OS.SWP_NOACTIVATE;
OS.SetWindowPos(parent.getShell().handle,
OS.HWND_TOPMOST, 0, 0, 0, 0,flags);
Re: Double click activates other app? [message #449526 is a reply to message #449525] |
Tue, 25 January 2005 13:11   |
Sylvia wrote:
> it didn't work.
> I tried,
but it has the side effect that the application now stays on the
foreground even when it deactivates.
What's the proper way to fix this issue? since I don't see it with Eclipse
IDE, There must be something I missed.
Re: Double click activates other app? [message #449708 is a reply to message #449526] |
Thu, 27 January 2005 19:47  |
The proper way is to enter a bug report with a stand alone snippet that
shows the problem. Without this, we have no idea if the work around that
you are quoting is even causing your problem. If we change code, we have no
idea if the code changes fix your problem.
"Sylvia" <fangsh@appliedbiosystems.com> wrote in message
news:ct624h$pgc$1@www.eclipse.org...
> Sylvia wrote:
> > Hi,
> > it didn't work.
> > I tried,
Current Time: Sun Jul 27 03:25:05 EDT 2025
Powered by FUDForum. Page generated in 1.05568 seconds
