Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Listening to events from a swing element embedded in an SWT composite
Listening to events from a swing element embedded in an SWT composite [message #449499] Tue, 25 January 2005 09:51 Go to next message
I am embedding a swing JEditorPane within an SWT Composite, which is nested
in a JFace dialog. I would like to listen to events that occur in the
JEditorPane, and according to them, to either enable/disable the OK button
of the dialog. I tried to access the JFace code from my swing listener, and
got an exception that says that the SWT code is running from the wrong
thread. Does anyone knows if swing opens its own thread, and if so, how can
i still access JFace/SWT elements from swing code.
thanks
Maya and Yoav
Re: Listening to events from a swing element embedded in an SWT composite [message #449521 is a reply to message #449499] Tue, 25 January 2005 11:29 Go to previous message
Originally posted by: no.ddress.here
In article <ct5mhn$t0k$1@www.eclipse.org>, yoav@il.ibm.com says...
> Hi
> thanks
> Maya and Yoav
Look at:
Display.getDefault().asyncExec(
new Runnable() {
public void run() {
// SWT UI code here
Also, the .syncExec() method for in-line execution.
Gerald
Previous Topic:How to make SWT application appear in task bar on Windows XP
Next Topic:Crystal reports in eclipse..anyone doing this
Current Time: Sat Jul 26 03:19:28 EDT 2025
Powered by FUDForum. Page generated in 0.05136 seconds
