How to make a custom drag and drop tracker image [message #449221] |
Wed, 19 January 2005 13:12  |
I want to drag a tree item to the editor. I want to tracker image showing
the actual size of the object being dropped. Just like when you move a
control, it shows the tracker with the actual size of the object moved.
Could someone tell me how to do it or which classes I should look at?
Kevin
Re: How to make a custom drag and drop tracker image [message #449452 is a reply to message #449314] |
Mon, 24 January 2005 13:04   |
Hi Veronika,
I cannot find the DragDetect function in SWT. Could you tell me which file
I should look at?
Thanks.
Kevin
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:csqr0n$b6k$1@www.eclipse.org...
> You can not do it using DragSource. You must implement your own mouse
event
> handlers to simulate drag and drop. This is how Eclipse allows you to
drag
> views around the workbench. It does not use DragSource and DropTarget, it
> uses DragDetect, MouseEnter, MouseMove, MouseExit events etc.
> "Kevin" <kevinlouisnospam@hotmail.com> wrote in message
> news:cspl82$v4g$1@www.eclipse.org...
> > Could you tell me how it can be done? I look at the DragSource.drag
> > function, it uses the COM.DoDragDrop to do the drag drop. I don't know
> > where I can set the Tracker.
> > Thanks.
> > news:csoir4$3so$1@www.eclipse.org...
> >> This is not currently supported with DragSource/DropTarget. This is a
> >> requirement that I am investigating but I can not give a date when this
> > will
> >> be available.
> >> You could use org.eclipse.swt.widgets.Tracker and implement your own
> >> DragDetect listener.
> >> news:csm7vb$8mq$1@www.eclipse.org...
> >> > Hi,
> > showing
a
moved.
> >> > Thanks,
> >> > Kevin
Re: How to make a custom drag and drop tracker image [message #449479 is a reply to message #449452] |
Tue, 25 January 2005 07:50  |
control.addListener(SWT.DragDetect, new Listener() {
public void handleEvent(Event e) {
// code to start using Tracker.
news:ct3dc4$mea$1@www.eclipse.org...
> Hi Veronika,
> file
> I should look at?
> Thanks.
> Kevin
> event
> drag
>> it
>> > Thanks.
>> >> this
>> > will
>> >> be available.
>> >> > Hi,
>> > showing
>> >> > move
> a
> moved.
>> >> > at?
>> >> > Thanks,
>> >> > Kevin
FUDForum. Page generated in 0.05002 seconds
