Home » Eclipse Projects » Rich Client Platform (RCP) » A common problem
A common problem [message #449409] Fri, 12 May 2006 04:40 Go to next message
Originally posted by: gsebas27.gmail.com
When I export a plugin as a product, and I try to execute the generated
exe, I have the following log error:
!SESSION 2006-05-12 09:44:51.343
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-05-12 09:44:52.437
!MESSAGE An error occurred while automatically activating bundle Jprim (1).
!STACK 0
org.osgi.framework.BundleException: The activator
jprim.presentacio.rcp.JprimPlugin for bundle Jprim is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:142)
... 27 more
Root exception:
java.lang.ClassNotFoundException: jprim.presentacio.rcp.JprimPlugin
at
at
at
I have look for a solution in some forums and i have met a lot of people
with the same problem but no solution. I have checked the dependencies,
the manifest.mf, the config.ini, it seems all correct. What's happen?
Anyone can help me?
Re: A common problem [message #449412 is a reply to message #449409] Fri, 12 May 2006 05:44 Go to previous messageGo to next message
just a few hints:
- check that all classes are _really_ in the packaged plugin-jars (in
the right directory-structure)
- check that you have the "." on the Bundle-ClassPath in the
Manifest-files of the plugins, e.g.:
Bundle-ClassPath: .,anylib1.jar,anylib2.jar
- check in the config.ini that your bundle
(jprim.presentacio.rcp.JprimPlugin?) is listed there
osgi.bundles=...,jprim.presentacio.rcp.JprimPlugin,...
but this should be the case.
Hope that helps!
Stephan
iMEDIC GmbH
www.imedic.de
RCP Training Alliance
www.rcp-training.com
Re: A common problem [message #449416 is a reply to message #449409] Fri, 12 May 2006 08:23 Go to previous messageGo to next message
and don't post separately in different newsgroups ... now you have 2
threads that aren't connected.
At the very least, cross-post.
Later,
PW
Re: A common problem [message #449418 is a reply to message #449416] Fri, 12 May 2006 10:56 Go to previous message
Ups sorry, i thought the groups was composed by diferent people and i will
have more help
Previous Topic:IFileEditorInput problem
Next Topic:Setting the default perspective
Current Time: Sun Aug 31 19:55:56 EDT 2025
Powered by FUDForum. Page generated in 0.04155 seconds
