Home » Eclipse Projects » Standard Widget Toolkit (SWT) » error when using eclipse with Suse 9.2
error when using eclipse with Suse 9.2 [message #449359] Mon, 24 January 2005 11:03 Go to next message
Originally posted by: emerson.tre-sc.gov.br
I was having a lot of crashs using suse 9.2 on kde and eclipse 3.1 m4,
regardless the jdk version I used. It gave me an error related to qt
libraries, but I knew that eclipse used GTK, so i changed to GTK and the
error stopped occuring.
Emerson
Re: error when using eclipse with Suse 9.2 [message #449365 is a reply to message #449359] Mon, 24 January 2005 12:18 Go to previous messageGo to next message
Can you tell us the nature of the crashes? Was it in and around the
org.eclipse.swt.program.Program class?
"emerson" <emerson@tre-sc.gov.br> wrote in message
news:ct3695$du0$1@www.eclipse.org...
> Thanks
> Emerson
Re: error when using eclipse with Suse 9.2 [message #449366 is a reply to message #449359] Mon, 24 January 2005 12:20 Go to previous messageGo to next message
Eclipse 3.1M4 includes KDE integration where it will use the KDE
database to look up icons and default applications for file types if you
are running under KDE. It could be that this is causing the crashes.
This will not be used when running under GNOME, which has its own
integration layer. Could you please file a bug at bugs.eclipse.org
(under Platform > SWT) with a crash log from running under KDE?
-Billy
Re: error when using eclipse with Suse 9.2 [message #449591 is a reply to message #449365] Wed, 26 January 2005 14:43 Go to previous messageGo to next message
Here goes the log error :
Window that opens when eclipse crashs:
JVM terminated. Exit code=255
/home/emerson/j2sdk1.4.2_04/bin/java
-cp /home/emerson/eclipse/./startup.jar org.eclipse.core.launcher.Main
-os linux
-ws gtk
-arch x86
-showsplash /home/emerson/eclipse/./eclipse -showsplash 600
-exitdata /home/emerson/eclipse/./eclipse -exitdata 53d0015
-vm /home/emerson/j2sdk1.4.2_04/bin/java
-vmargs
Error that appear at console (i starte throught console):
QApplication: There should be max one application object
# HotSpot Virtual Machine Error, Internal Error
# Please report this error at
# http://java.sun.com/cgi-bin/bugreport.cgi
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# Error ID: 43113F32554E54494D45110E4350500308
# Problematic Thread: prio=1 tid=0x5112a090 nid=0x1bb7 runnable
Heap at VM Abort:
Heap
def new generation total 3392K, used 3391K [0x44760000, 0x44b00000,
0x44c40000)
eden space 3072K, 99% used [0x44760000, 0x44a5fcb8, 0x44a60000)
from space 320K, 100% used [0x44a60000, 0x44ab0000, 0x44ab0000)
to space 320K, 0% used [0x44ab0000, 0x44ab0000, 0x44b00000)
tenured generation total 43444K, used 26260K [0x44c40000, 0x476ad000,
0x48760000)
the space 43444K, 60% used [0x44c40000, 0x465e53c0, 0x465e5400,
0x476ad000)
compacting perm gen total 32256K, used 32113K [0x48760000, 0x4a6e0000,
0x4c760000)
the space 32256K, 99% used [0x48760000, 0x4a6bc760, 0x4a6bc800,
0x4a6e0000)
[error occured during error reporting]
I had a a hs_err_pic* file from a a eclipse error:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D995172
Function=XSetTile+0x12
Library=/usr/X11R6/lib/libX11.so.6
Current Java thread:
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:46 33)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:907)
at org.eclipse.swt.internal.gtk.OS._gtk_adjustment_value_change d(Native
Method)
at
org.eclipse.swt.internal.gtk.OS.gtk_adjustment_value_changed (OS.java:3157)
at org.eclipse.swt.widgets.ScrollBar.setValues(ScrollBar.java:6 53)
at org.eclipse.swt.custom.StyledText.setScrollBars(StyledText.j ava:7061)
at org.eclipse.swt.custom.StyledText.handleResize(StyledText.ja va:5138)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:4757)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:996)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1020)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1001)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:552)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 31)
at org.eclipse.swt.widgets.Canvas.setBounds(Canvas.java:240)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:466)
at org.eclipse.swt.custom.SashFormLayout.layout(SashFormLayout. java:188)
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:1097)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 34)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:438)
at org.eclipse.ui.part.PageBook$PageBookLayout.layout(PageBook. java:59)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:159 )
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java :319)
at
org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(PresentablePart.java:118)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.layoutContent(PresentablePartFolder.java:131)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.layout(PresentablePartFolder.java:401)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.setBounds(PresentablePartFolder.java:256)
at
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.setBounds(TabbedStackPresentation.java:203)
at org.eclipse.ui.internal.PartStack.setBounds(PartStack.java:9 94)
at org.eclipse.ui.internal.LayoutTree.doSetBounds(LayoutTree.ja va:543)
at org.eclipse.ui.internal.LayoutTree.setBounds(LayoutTree.java :534)
at
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:520)
at
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:519)
at
org.eclipse.ui.internal.LayoutPartSash.widgetSelected(Layout PartSash.java:263)
at
org.eclipse.ui.internal.LayoutPartSash.access$1(LayoutPartSa sh.java:246)
at
org.eclipse.ui.internal.LayoutPartSash$1.widgetSelected(Layo utPartSash.java:60)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1005)
at org.eclipse.swt.widgets.Sash.gtk_motion_notify_event(Sash.ja va:358)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1338)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3241 )
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1095)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2395)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:03 215895
/home/emerson/j2sdk1.4.2_05/bin/java
08056000-08059000 rwxp 0000d000 03:03 215895
40000000-40016000 r-xp 00000000 03:03 8018 /lib/ld-2.3.3.so
40016000-40018000 rwxp 00015000 03:03 8018 /lib/ld-2.3.3.so
40035000-40043000 r-xp 00000000 03:03 8045 /lib/tls/libpthread.so.0
40043000-40045000 rwxp 0000d000 03:03 8045 /lib/tls/libpthread.so.0
40047000-40049000 r-xp 00000000 03:03 8027 /lib/libdl.so.2
40049000-4004b000 rwxp 00001000 03:03 8027 /lib/libdl.so.2
4004b000-4015a000 r-xp 00000000 03:03 8043 /lib/tls/libc.so.6
4015a000-4015b000 ---p 0010f000 03:03 8043 /lib/tls/libc.so.6
4015b000-4015c000 r-xp 0010f000 03:03 8043 /lib/tls/libc.so.6
4015c000-4015f000 rwxp 00110000 03:03 8043 /lib/tls/libc.so.6
40162000-4055e000 r-xp 00000000 03:03 194025
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so
4055e000-40579000 rwxp 003fb000 03:03 194025
4058b000-40593000 r-xp 00000000 03:03 194019
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/native_threads/libh pi.so
40593000-40594000 rwxp 00007000 03:03 194019
405a7000-405b9000 r-xp 00000000 03:03 8030 /lib/libnsl.so.1
405b9000-405bb000 rwxp 00011000 03:03 8030 /lib/libnsl.so.1
405bd000-405de000 r-xp 00000000 03:03 8044 /lib/tls/libm.so.6
405de000-405e0000 rwxp 00020000 03:03 8044 /lib/tls/libm.so.6
405e0000-40615000 r-xs 00000000 03:03 47281 /var/run/nscd/passwd
40615000-40619000 rwxs 00000000 03:03 313973
/tmp/hsperfdata_emerson/27403
40619000-40629000 r-xp 00000000 03:03 194030
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libverify.so
40629000-4062b000 rwxp 0000f000 03:03 194030
4062b000-4064b000 r-xp 00000000 03:03 194031
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libjava.so
4064b000-4064d000 rwxp 0001f000 03:03 194031
4064d000-40661000 r-xp 00000000 03:03 194033
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libzip.so
40661000-40664000 rwxp 00013000 03:03 194033
40664000-42008000 r-xs 00000000 03:03 215888
/home/emerson/j2sdk1.4.2_05/jre/lib/rt.jar
42052000-42068000 r-xs 00000000 03:03 194060
/home/emerson/j2sdk1.4.2_05/jre/lib/sunrsasign.jar
42068000-42145000 r-xs 00000000 03:03 215482
/home/emerson/j2sdk1.4.2_05/jre/lib/jsse.jar
42145000-42156000 r-xs 00000000 03:03 194061
/home/emerson/j2sdk1.4.2_05/jre/lib/jce.jar
42156000-426af000 r-xs 00000000 03:03 215596
/home/emerson/j2sdk1.4.2_05/jre/lib/charsets.jar
44757000-4475c000 r-xs 00000000 03:03 288272
/home/emerson/eclipse/startup.jar
4475c000-4475e000 r-xp 00000000 03:03 25149
/opt/gnome/lib/pango/1.4.0/modules/pango-basic-fc.so
4475e000-4475f000 rwxp 00001000 03:03 25149
4c963000-4c996000 r-xp 00000000 03:03 12095
/usr/lib/locale/en_US.utf8/LC_CTYPE
4c996000-4c99c000 r-xs 00000000 03:03 8589
/usr/lib/gconv/gconv-modules.cache
4cba0000-4cba3000 r-xs 00000000 03:03 194057
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/dnsns.jar
4cba3000-4cbbf000 r-xs 00000000 03:03 194056
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/sunjce_provider.jar
4cbbf000-4cbcc000 r-xs 00000000 03:03 194059
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/ldapsec.jar
4cbcc000-4cc88000 r-xs 00000000 03:03 215597
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/localedata.jar
4cd09000-4cd41000 r-xs 00000000 03:03 193741
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/core.ja r
4cd41000-4cd49000 r-xs 00000000 03:03 193742
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/console .jar
4cd49000-4cd55000 r-xs 00000000 03:03 193744
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/osgi.ja r
4cd55000-4cd6b000 r-xs 00000000 03:03 193743
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/resolve r.jar
4cd6b000-4cd81000 r-xs 00000000 03:03 193746
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/default Adaptor.jar
4cd81000-4cda0000 r-xs 00000000 03:03 193745
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/eclipse Adaptor.jar
4cea2000-4cf03000 r-xs 00000000 03:03 205397
/home/emerson/eclipse/plugins/org.eclipse.core.runtime_3.1.0 /runtime.jar
4cf03000-4cf13000 r-xp 00000000 03:03 194036
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libnet.so
4cf13000-4cf14000 rwxp 0000f000 03:03 194036
4cf14000-4cf1a000 r-xp 00000000 03:03 194037
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libnio.so
4cf1a000-4cf1b000 rwxp 00005000 03:03 194037
4cf1b000-4cf30000 r-xs 00000000 03:03 288009
/home/emerson/eclipse/plugins/org.eclipse.core.runtime.compa tibility_3.0.0/compatibility.jar
4cf30000-4cf46000 r-xs 00000000 03:03 205414
/home/emerson/eclipse/plugins/org.eclipse.update.configurato r_3.0.0/configurator.jar
4cfc7000-4d047000 r-xs 00000000 03:03 313976 /tmp/jar_cache62790.tmp
(deleted)
4d047000-4d1a1000 r-xs 00000000 03:03 204909
/home/emerson/eclipse/plugins/org.eclipse.ui.ide_3.1.0/ide.j ar
4d1a1000-4d1a2000 r-xs 00000000 03:03 288016
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench.compa tibility_3.1.0/compatibility.jar
4d1a2000-4d414000 r-xs 00000000 03:03 196462
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench_3.1.0 /workbench.jar
4d414000-4d498000 r-xs 00000000 03:03 203317
/home/emerson/eclipse/plugins/org.eclipse.jface_3.1.0/jface. jar
4d498000-4d4a5000 r-xs 00000000 03:03 287828
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt-mozilla.jar
4d4a5000-4d4c0000 r-xs 00000000 03:03 287827
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt-pi.jar
4d4c0000-4d5af000 r-xs 00000000 03:03 287829
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt.jar
4d5af000-4d5b1000 r-xs 00000000 03:03 193436
/home/emerson/eclipse/plugins/org.eclipse.ui_3.1.0/ui.jar
4d5b1000-4d5f1000 r-xp 00000000 03:03 287836
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/os/l inux/x86/libswt-pi-gtk-3116.so
4d5f1000-4d5f3000 rwxp 00040000 03:03 287836
4d5f3000-4d5f4000 r-xp 00000000 03:03 9295
/usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
4d5f4000-4d5f5000 r-xp 00000000 03:03 11862
/usr/lib/locale/en_US.utf8/LC_MEASUREMENT
4d5f5000-4d5f6000 r-xp 00000000 03:03 9298
/usr/lib/locale/en_US.utf8/LC_TELEPHONE
4d5f6000-4d5f7000 r-xp 00000000 03:03 9294
/usr/lib/locale/en_US.utf8/LC_ADDRESS
4d5f7000-4d5f8000 r-xp 00000000 03:03 9297
/usr/lib/locale/en_US.utf8/LC_NAME
4d5f8000-4d5f9000 r-xp 00000000 03:03 11898
/usr/lib/locale/en_US.utf8/LC_PAPER
4d5f9000-4d5fa000 r-xp 00000000 03:03 12060
/usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
4d5fa000-4d5fb000 r-xp 00000000 03:03 9296
/usr/lib/locale/en_US.utf8/LC_MONETARY
4d5fb000-4d5fd000 r-xp 00000000 03:03 174285
/home/emerson/eclipse/plugins/org.eclipse.core.resources.lin ux_3.0.0/os/linux/x86/libcore_3_1_0.so
4d5fd000-4d5fe000 rwxp 00001000 03:03 174285
4d5fe000-4d60d000 r-xs 00000000 03:03 287855
/home/emerson/eclipse/plugins/org.eclipse.help_3.0.0/help.ja r
4d60f000-4d8c9000 r-xp 00000000 03:03 42377
/opt/gnome/lib/libgtk-x11-2.0.so.0.400.9
4d8c9000-4d8d2000 rwxp 002ba000 03:03 42377
4d8d5000-4d8d8000 r-xp 00000000 03:03 8309
/opt/gnome/lib/libgthread-2.0.so.0.400.6
4d8d8000-4d8d9000 rwxp 00003000 03:03 8309
4d8d9000-4d8de000 r-xp 00000000 03:03 16431
/usr/X11R6/lib/libXtst.so.6.1
4d8de000-4d8df000 rwxp 00004000 03:03 16431
4d8df000-4d8f3000 r-xp 00000000 03:03 42373
/opt/gnome/lib/libgdk_pixbuf-2.0.so.0.400.9
4d8f3000-4d8f4000 rwxp 00013000 03:03 42373
4d8f4000-4d95e000 r-xp 00000000 03:03 42371
/opt/gnome/lib/libgdk-x11-2.0.so.0.400.9
4d95e000-4d963000 rwxp 00069000 03:03 42371
4d963000-4da5b000 r-xp 00000000 03:03 16387
/usr/X11R6/lib/libX11.so.6.2
4da5b000-4da5f000 rwxp 000f7000 03:03 16387
4da5f000-4da63000 r-xp 00000000 03:03 22378
/opt/gnome/lib/libpangoxft-1.0.so.0.400.1
4da63000-4da64000 rwxp 00003000 03:03 22378
4da64000-4da6e000 r-xp 00000000 03:03 22376
/opt/gnome/lib/libpangox-1.0.so.0.400.1
4da6e000-4da6f000 rwxp 0000a000 03:03 22376
4da6f000-4da9e000 r-xp 00000000 03:03 22372
/opt/gnome/lib/libpango-1.0.so.0.400.1
4da9e000-4daa3000 rwxp 0002e000 03:03 22372
4daa3000-4dabc000 r-xp 00000000 03:03 12424
/opt/gnome/lib/libatk-1.0.so.0.600.0
4dabc000-4dabe000 rwxp 00018000 03:03 12424
4dabe000-4daf6000 r-xp 00000000 03:03 8307
/opt/gnome/lib/libgobject-2.0.so.0.400.6
4daf6000-4daf8000 rwxp 00037000 03:03 8307
4daf8000-4dafb000 r-xp 00000000 03:03 8305
/opt/gnome/lib/libgmodule-2.0.so.0.400.6
4dafb000-4dafc000 rwxp 00002000 03:03 8305
4dafc000-4db7a000 r-xp 00000000 03:03 8303
/opt/gnome/lib/libglib-2.0.so.0.400.6
4db7a000-4db7b000 rwxp 0007e000 03:03 8303
4db7b000-4db88000 r-xp 00000000 03:03 16403
/usr/X11R6/lib/libXext.so.6.4
4db88000-4db89000 rwxp 0000d000 03:03 16403
4db89000-4db8c000 r-xp 00000000 03:03 16424
/usr/X11R6/lib/libXrandr.so.2.0
4db8c000-4db8d000 rwxp 00002000 03:03 16424
4db8d000-4db94000 r-xp 00000000 03:03 16412
/usr/X11R6/lib/libXi.so.6.0
4db94000-4db95000 rwxp 00006000 03:03 16412
4db95000-4dba7000 r-xp 00000000 03:03 16410
/usr/X11R6/lib/libXft.so.2.1.2
4dba7000-4dba8000 rwxp 00011000 03:03 16410
4dba8000-4dc10000 r-xp 00000000 03:03 11509
/usr/lib/libfreetype.so.6.3.7
4dc10000-4dc17000 rwxp 00068000 03:03 11509
4dc17000-4dc3c000 r-xp 00000000 03:03 12409
/usr/lib/libfontconfig.so.1.0.4
4dc3c000-4dc40000 rwxp 00025000 03:03 12409
4dc41000-4dc49000 r-xp 00000000 03:03 16399
/usr/X11R6/lib/libXcursor.so.1.0.2
4dc49000-4dc4a000 rwxp 00007000 03:03 16399
4dc4a000-4dc51000 r-xp 00000000 03:03 16426
/usr/X11R6/lib/libXrender.so.1.2.2
4dc51000-4dc52000 rwxp 00006000 03:03 16426
4dc52000-4dc76000 r-xp 00000000 03:03 22374
/opt/gnome/lib/libpangoft2-1.0.so.0.400.1
4dc76000-4dc77000 rwxp 00024000 03:03 22374
4dc77000-4dc94000 r-xp 00000000 03:03 8082 /usr/lib/libexpat.so.0.5.0
4dc94000-4dc96000 rwxp 0001d000 03:03 8082 /usr/lib/libexpat.so.0.5.0
4dc96000-4dd6e000 r-xp 00000000 03:03 12096
/usr/lib/locale/en_US.utf8/LC_COLLATE
4dd6e000-4dd6f000 r-xp 00000000 03:03 9300
/usr/lib/locale/en_US.utf8/LC_TIME
4dd6f000-4dd70000 r-xp 00000000 03:03 12072
/usr/lib/locale/en_US.utf8/LC_NUMERIC
4dd70000-4dd71000 r-xp 00000000 03:03 13165
/usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
4dd71000-4dd72000 rwxp 00000000 03:03 13165
4dd72000-4dd73000 r-xp 00000000 03:03 8534
/usr/lib/gconv/ISO8859-1.so
4dd73000-4dd75000 rwxp 00000000 03:03 8534
4dd75000-4dd9b000 r-xp 00000000 03:03 287834
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/os/l inux/x86/libswt-gtk-3116.so
4dd9b000-4dd9d000 rwxp 00025000 03:03 287834
4dd9e000-4ddb8000 r-xp 00000000 03:03 14507
/opt/gnome/lib/gtk-2.0/2.4.0/engines/libqtengine.so
4ddb8000-4ddb9000 rwxp 0001a000 03:03 14507
4ddb9000-4e473000 r-xp 00000000 03:03 41752
/usr/lib/qt3/lib/libqt-mt.so.3.3.3
4e473000-4e4b4000 rwxp 006ba000 03:03 41752
4e4b7000-4e4bc000 r-xs 00000000 03:03 213430
/home/emerson/jakarta-tomcat-5.0.28/server/lib/catalina-ant. jar
4e4c5000-4e4d3000 r-xs 00000000 03:03 288111
/home/emerson/eclipse/plugins/org.eclipse.ui.views_3.1.0/vie ws.jar
4e4d3000-4e500000 r-xp 00000000 03:03 12629 /usr/lib/libpng.so.3.1.2.6
4e500000-4e501000 rwxp 0002d000 03:03 12629 /usr/lib/libpng.so.3.1.2.6
4e501000-4e511000 r-xp 00000000 03:03 12363 /lib/libz.so.1.2.1
4e511000-4e512000 rwxp 0000f000 03:03 12363 /lib/libz.so.1.2.1
4e512000-4e519000 r-xp 00000000 03:03 16384
/usr/X11R6/lib/libSM.so.6.0
4e519000-4e51a000 rwxp 00007000 03:03 16384
4e51a000-4e52f000 r-xp 00000000 03:03 16382
/usr/X11R6/lib/libICE.so.6.3
4e52f000-4e530000 rwxp 00014000 03:03 16382
4e532000-4e5e5000 r-xp 00000000 03:03 12641
/usr/lib/libstdc++.so.5.0.7
4e5e5000-4e5ea000 rwxp 000b3000 03:03 12641
4e5ef000-4e5f6000 r-xp 00000000 03:03 9054 /lib/libgcc_s.so.1
4e5f6000-4e5f7000 rwxp 00006000 03:03 9054 /lib/libgcc_s.so.1
4e5f7000-4e661000 r-xp 00000000 03:03 45255
/usr/lib/qt3/plugins/styles/thinkeramik.so
4e661000-4e664000 rwxp 00069000 03:03 45255
4e664000-4e672000 r-xp 00000000 03:03 52153
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Roman.ttf
4e672000-4e6a2000 rwxs 00000000 00:06 241139734 /SYSV00000000 (deleted)
4e6a2000-4e74a000 r-xs 00000000 03:03 287914
/home/emerson/eclipse/plugins/org.eclipse.core.resources_3.1 .0/resources.jar
4e74a000-4e7b9000 r-xs 00000000 03:03 290994
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.ui_1.0.0/x mleditor.jar
4e7b9000-4e857000 r-xs 00000000 03:03 174301
/home/emerson/eclipse/plugins/org.eclipse.jface.text_3.1.0/j facetext.jar
4e857000-4e8b4000 r-xs 00000000 03:03 203322
/home/emerson/eclipse/plugins/org.eclipse.ui.editors_3.1.0/e ditors.jar
4e8b4000-4e8e0000 r-xs 00000000 03:03 193736
/home/emerson/eclipse/plugins/org.eclipse.text_3.1.0/text.ja r
4e8e0000-4e980000 r-xs 00000000 03:03 291968
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.ui_1.0.0/e ditor.jar
4e980000-4e9e2000 r-xs 00000000 03:03 220314
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench.texte ditor_3.1.0/texteditor.jar
4e9e2000-4ea2d000 r-xs 00000000 03:03 293201
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.core_1.0.0 /model.jar
4ea2d000-4ea3f000 r-xs 00000000 03:03 193937
/home/emerson/eclipse/plugins/org.eclipse.core.filebuffers_3 .1.0/filebuffers.jar
4ea3f000-4ea65000 r-xs 00000000 03:03 291870
/home/emerson/eclipse/plugins/org.eclipse.wst.common.content model_1.0.0/contentmodel.jar
4ea65000-4ea7c000 r-xs 00000000 03:03 291843
/home/emerson/eclipse/plugins/org.eclipse.wst.common.ui_1.0. 0/ui.jar
4ea7c000-4eab0000 r-xs 00000000 03:03 205420
/home/emerson/eclipse/plugins/org.eclipse.team.core_3.1.0/te am.jar
4eab0000-4eaba000 r-xs 00000000 03:03 193756
/home/emerson/eclipse/plugins/org.eclipse.ant.core_3.1.0/ant support.jar
4eaba000-4eb09000 r-xs 00000000 03:03 293299
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.core_1.0.0 /xmlmodel.jar
4eb09000-4eb19000 r-xs 00000000 03:03 291239
/home/emerson/eclipse/plugins/org.eclipse.wst.common.encodin g_1.0.0/encodingresource.jar
4eb19000-4ebdf000 r-xs 00000000 03:03 196494
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/antui .jar
4ebdf000-4ebe6000 r-xs 00000000 03:03 293367
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.uriresolve r_1.0.0/xmlcatalog.jar
4ec67000-4ec76000 r-xp 00000000 03:03 52152
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Oblique.ttf
4ec76000-4ec7c000 r-xs 00000000 03:03 288105
/home/emerson/eclipse/plugins/org.eclipse.core.variables_3.1 .0/variables.jar
4ec85000-4ecbc000 r-xs 00000000 03:03 291070
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.snippets_1 .0.0/snippets.jar
4ecbc000-4eccb000 r-xs 00000000 03:03 291879
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.ui_1.0.0/d tdeditor.jar
4eccb000-4ece3000 r-xp 00000000 03:03 50214
/usr/share/ghostscript/fonts/n022003l.pfb
4ecee000-4ecfb000 r-xs 00000000 03:03 220658
/home/emerson/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/jd i.jar
4ecfb000-4ed09000 r-xp 00000000 03:03 51883
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Bold.ttf
4ed09000-4ed23000 r-xs 00000000 03:03 204089
/home/emerson/eclipse/plugins/org.eclipse.ui.externaltools_3 .1.0/externaltools.jar
4ed25000-4ed34000 r-xp 00000000 03:03 51922
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-BoldOblique.ttf
4ed34000-4ed40000 r-xs 00000000 03:03 291867
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.parser_1.0 .0/dtdparser.jar
4ed41000-4ee51000 r-xs 00000000 03:03 205032
/home/emerson/eclipse/plugins/org.eclipse.debug.ui_3.1.0/dtu i.jar
4ee51000-4ee89000 r-xs 00000000 03:03 203311
/home/emerson/eclipse/plugins/org.eclipse.debug.core_3.1.0/d tcore.jar
4ee89000-4ef5e000 r-xs 00000000 03:03 290806
/home/emerson/eclipse/plugins/org.eclipse.gef_3.1.0/gef.jar
4ef5e000-4efb5000 r-xs 00000000 03:03 287959
/home/emerson/eclipse/plugins/org.eclipse.search_3.1.0/searc h.jar
4f0b7000-4f0d6000 r-xs 00000000 03:03 290442
/home/emerson/eclipse/plugins/org.eclipse.emf.common_2.1.0/r untime/common.jar
4f0d6000-4f1cb000 r-xs 00000000 03:03 47334
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant.j ar
4f1cb000-4f1cd000 r-xs 00000000 03:03 47169
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a ntlr.jar
4f1cd000-4f1d0000 r-xs 00000000 03:03 47168
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-bcel.jar
4f1d0000-4f1d4000 r-xs 00000000 03:03 47155
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-bsf.jar
4f1d4000-4f1d5000 r-xs 00000000 03:03 47166
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-log4j.jar
4f1d5000-4f1e1000 r-xs 00000000 03:03 47158
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-oro.jar
4f1e1000-4f1e2000 r-xs 00000000 03:03 47152
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-regexp.jar
4f1e2000-4f1e3000 r-xs 00000000 03:03 47172
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-resolver.jar
4f1e3000-4f1e4000 r-xs 00000000 03:03 47162
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-c ommons-logging.jar
4f1e4000-4f1ed000 r-xs 00000000 03:03 47157
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-c ommons-net.jar
4f1ed000-4f1f0000 r-xs 00000000 03:03 47153
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-i contract.jar
4f1f0000-4f1f6000 r-xs 00000000 03:03 47160
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j ai.jar
4f1f6000-4f1f8000 r-xs 00000000 03:03 47193
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j avamail.jar
4f1f8000-4f1fa000 r-xs 00000000 03:03 47165
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j depend.jar
4f1fa000-4f1fc000 r-xs 00000000 03:03 47161
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j mf.jar
4f1fc000-4f202000 r-xs 00000000 03:03 47156
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j sch.jar
4f202000-4f214000 r-xs 00000000 03:03 47173
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j unit.jar
4f214000-4f217000 r-xs 00000000 03:03 47185
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-l auncher.jar
4f217000-4f21a000 r-xs 00000000 03:03 47167
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-n etrexx.jar
4f21a000-4f27e000 r-xs 00000000 03:03 47159
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-n odeps.jar
4f27e000-4f287000 r-xs 00000000 03:03 47154
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s tarteam.jar
4f287000-4f288000 r-xs 00000000 03:03 47164
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s tylebook.jar
4f288000-4f28a000 r-xs 00000000 03:03 47186
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s wing.jar
4f28a000-4f29b000 r-xs 00000000 03:03 47170
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-t rax.jar
4f29b000-4f2a7000 r-xs 00000000 03:03 47230
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-v aj.jar
4f2a7000-4f2ab000 r-xs 00000000 03:03 47180
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-w eblogic.jar
4f2ab000-4f2ad000 r-xs 00000000 03:03 47224
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-x alan1.jar
4f2ad000-4f2ae000 r-xs 00000000 03:03 47171
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-x slp.jar
4f2ae000-4f2b9000 r-xp 00000000 03:03 52159
/usr/X11R6/lib/X11/fonts/truetype/SUSESansMono-Roman.ttf
4f2cc000-4f379000 r-xs 00000000 03:03 220659
/home/emerson/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/jd imodel.jar
4f379000-4f6a2000 r-xs 00000000 03:03 196334
/home/emerson/eclipse/plugins/org.eclipse.jdt.core_3.1.0/jdt core.jar
4f723000-4fcbe000 r-xs 00000000 03:03 203413
/home/emerson/eclipse/plugins/org.eclipse.jdt.ui_3.1.0/jdt.j ar
4fcbe000-4fcd7000 r-xs 00000000 03:03 287954
/home/emerson/eclipse/plugins/org.eclipse.ltk.core.refactori ng_3.1.0/refcore.jar
4fd58000-50234000 r-xs 00000000 03:03 217054
/home/emerson/j2sdk1.4.2_05/lib/tools.jar
50234000-50236000 r-xs 00000000 03:03 212344
/home/emerson/eclipse/plugins/org.eclipse.pde.ui_3.1.0/pdeui ant.jar
50236000-5023b000 r-xs 00000000 03:03 287868
/home/emerson/eclipse/plugins/org.eclipse.pde.build_3.1.0/li b/pdebuild-ant.jar
5023b000-5023d000 r-xs 00000000 03:03 204862
/home/emerson/eclipse/plugins/org.eclipse.pde_3.1.0/ant_task s/pde-ant.jar
5023d000-5023f000 r-xs 00000000 03:03 287916
/home/emerson/eclipse/plugins/org.eclipse.core.resources_3.1 .0/ant_tasks/resources-ant.jar
5023f000-50242000 r-xs 00000000 03:03 196335
/home/emerson/eclipse/plugins/org.eclipse.jdt.core_3.1.0/jdt CompilerAdapter.jar
50242000-50246000 r-xs 00000000 03:03 196493
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/lib/a ntrunner.jar
50246000-50251000 r-xs 00000000 03:03 196492
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/lib/r emoteAnt.jar
50251000-50259000 r-xs 00000000 03:03 193755
/home/emerson/eclipse/plugins/org.eclipse.ant.core_3.1.0/lib /antsupportlib.jar
503dc000-503f8000 r-xp 00000000 03:03 50222
/usr/share/ghostscript/fonts/n022024l.pfb
503f8000-50400000 r-xp 00000000 03:03 8033 /lib/libnss_files.so.2
50400000-50402000 rwxp 00007000 03:03 8033 /lib/libnss_files.so.2
50402000-5041f000 r-xs 00000000 03:03 196341
/home/emerson/eclipse/plugins/org.eclipse.ui.console_3.1.0/c onsole.jar
5041f000-5042c000 r-xs 00000000 03:03 193762
/home/emerson/eclipse/plugins/org.eclipse.core.expressions_3 .1.0/expressions.jar
5042c000-5048c000 rwxs 00000000 00:06 248021012 /SYSV00000000 (deleted)
5060f000-50615000 r-xs 00000000 03:03 291965
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.contentmod el_1.0.0/cmdtd.jar
50615000-5061b000 r-xs 00000000 03:03 193883
/home/emerson/eclipse/plugins/org.eclipse.update.scheduler_3 .0.0/scheduler.jar
5061b000-506ab000 r-xs 00000000 03:03 290435
/home/emerson/eclipse/plugins/org.eclipse.emf.ecore_2.1.0/ru ntime/ecore.jar
506ab000-506b0000 r-xs 00000000 03:03 293371
/home/emerson/eclipse/plugins/org.eclipse.wst.internet.proxy _1.0.0/runtime/ipproxy.jar
506b0000-506dc000 r-xs 00000000 03:03 291620
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd_1.0.0/dtdm odel.jar
506f8000-506fc000 r-xp 00000000 03:03 8032 /lib/libnss_dns.so.2
506fc000-506fe000 rwxp 00003000 03:03 8032 /lib/libnss_dns.so.2
50800000-5080f000 r-xp 00000000 03:03 8039 /lib/libresolv.so.2
5080f000-50811000 rwxp 0000e000 03:03 8039 /lib/libresolv.so.2
Heap at VM Abort:
Heap
def new generation total 1152K, used 765K [0x44760000, 0x448a0000,
0x44c40000)
eden space 1024K, 66% used [0x44760000, 0x44809668, 0x44860000)
from space 128K, 68% used [0x44860000, 0x44875e80, 0x44880000)
to space 128K, 0% used [0x44880000, 0x44880000, 0x448a0000)
tenured generation total 14528K, used 8715K [0x44c40000, 0x45a70000,
0x48760000)
the space 14528K, 59% used [0x44c40000, 0x454c2db0, 0x454c2e00,
0x45a70000)
compacting perm gen total 21248K, used 21003K [0x48760000, 0x49c20000,
0x4c760000)
the space 21248K, 98% used [0x48760000, 0x49be2f80, 0x49be3000,
0x49c20000)
Local Time = Tue Jan 18 15:22:25 2005
Elapsed Time = 40
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_05-b04 mixed mode)
>> Thanks
>> Emerson
Re: error when using eclipse with Suse 9.2 [message #449613 is a reply to message #449591] Thu, 27 January 2005 09:06 Go to previous message
This is due to a bug in the "gtk-qt" theme engine which SuSE will
be using when you run under KDE. Upgrading to the latest version of
gtk-qt should fix the problem.
See:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=77928
-Billy
Previous Topic:TableViewer with items inside table pre-fixed with checkbox
Next Topic:Redrawing pixels to the screen in SWT-simple graphics prob
Current Time: Sun Jul 27 03:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.05616 seconds
