Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Easy way to get API info
Easy way to get API info [message #449225] |
Wed, 19 January 2005 16:46  |
Can anyone tell me how to quickly and easily set up Eclipse so I can see
doc'n on SWT API methods?
For example, I am currently working alot with gc.drawImage(). It has many
overloads, and I wonder if the one with just two int arg's is the one I
want.
(SWT people: seeing "int arg0, int arg1" is one step above useless. If it
were "int x, int y" that would be far better).
I would like to be able to select "drawImage" in my code and with one
click or keystroke, get taken into the doc'n on that method.
We've always had this in other API's, can someone describe how it works in
Eclipse?
TIA, Bill
Re: Easy way to get API info [message #449284 is a reply to message #449225] |
Thu, 20 January 2005 10:15   |
Place the mouse in the method and either hit F2 and a dialog pops up with
the Javadoc or have the Javadoc view open and the doc will be displayed in
the view.
Also, during code assist (Ctrl+space), if you use the arrow keys to move
through the possible matches, the javaodoc for the selected item will appear
beside the code assist dialog.
However, you should be seeing int x, int y rather than int arg0, int arg1.
I experimented a bit with Eclipse. If I specify the swt jar as an external
jar in the Java Build Path, and do not specify the src or javadoc location,
I get the javadoc as I expected. As soon as I specify the source location,
I do not get the javadoc. This may be a bug in Eclipse. Is your project an
Eclipse plugin or a regular Java project? If it is a regular Java project,
how have you defined your Java build path?
"Bill Ewing" <ewing@irori.com> wrote in message
news:csmkff$q7t$1@www.eclipse.org...
> want.
> Eclipse?
> TIA, Bill
Re: Easy way to get API info [message #449285 is a reply to message #449225] |
Thu, 20 January 2005 10:17   |
the view.
> want.
> Eclipse?
> TIA, Bill
Re: Easy way to get API info [message #449303 is a reply to message #449285] |
Thu, 20 January 2005 14:29   |
Hi Veronika. I briefly tried the F2 key, but it didn't show anything
beyond what code assist shows (for example, it tells me that there are two
int arg's, which I already knew).
The advice about the build path is something I will need to explore, but I
wanted to get back quickly and say thanks for the help.
(My comment to SWT/Eclipse developers is: why isn't this easy and
automatic? Yes, it's nice to have things flexible and reconfiguarable,
but imagine if this happened to you when you bought a car? You get a bag
full of parts, all ready for you to assemble, anyway you please, when all
you want to do is drive the car somewhere.)
Re: Easy way to get API info [message #449304 is a reply to message #449285] |
Thu, 20 January 2005 14:32   |
> the view.
>> want.
>> Eclipse?
>> TIA, Bill
Thanks again for the support.
My project is a regular, standalone app. It is not a plug in.
We created a new JFace/SWT project and have a JFace Application window.
Isn't it enough to tell the IDE that's what we're doing?
Re: Easy way to get API info [message #449307 is a reply to message #449303] |
Thu, 20 January 2005 19:56  |
> two int arg's, which I already knew).
Ehm, did you try and set the javadoc location for the classes you were
addressing? In .class (and therefore, .jar) files there is no
documentation, or names of parameters etc. Eclipse automatically fills
in the values it finds within the javadoc documentation.
Maarten
Current Time: Sat Jul 26 10:57:03 EDT 2025
Powered by FUDForum. Page generated in 0.08126 seconds
