Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to make a custom drag and drop tracker image
How to make a custom drag and drop tracker image [message #449221] Wed, 19 January 2005 13:12 Go to next message
I want to drag a tree item to the editor. I want to tracker image showing
the actual size of the object being dropped. Just like when you move a
control, it shows the tracker with the actual size of the object moved.
Could someone tell me how to do it or which classes I should look at?
Kevin
Re: How to make a custom drag and drop tracker image [message #449287 is a reply to message #449221] Thu, 20 January 2005 10:30 Go to previous messageGo to next message
This is not currently supported with DragSource/DropTarget. This is a
requirement that I am investigating but I can not give a date when this will
be available.
You could use org.eclipse.swt.widgets.Tracker and implement your own
DragDetect listener.
"Kevin" <kevinlouisnospam@hotmail.com> wrote in message
news:csm7vb$8mq$1@www.eclipse.org...
> Kevin
Re: How to make a custom drag and drop tracker image [message #449308 is a reply to message #449287] Thu, 20 January 2005 20:17 Go to previous messageGo to next message
Could you tell me how it can be done? I look at the DragSource.drag
function, it uses the COM.DoDragDrop to do the drag drop. I don't know
where I can set the Tracker.
Thanks.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:csoir4$3so$1@www.eclipse.org...
will
> be available.
> > Hi,
showing
> > Thanks,
> > Kevin
Re: How to make a custom drag and drop tracker image [message #449314 is a reply to message #449308] Fri, 21 January 2005 07:02 Go to previous messageGo to next message
You can not do it using DragSource. You must implement your own mouse event
handlers to simulate drag and drop. This is how Eclipse allows you to drag
views around the workbench. It does not use DragSource and DropTarget, it
uses DragDetect, MouseEnter, MouseMove, MouseExit events etc.
news:cspl82$v4g$1@www.eclipse.org...
> Thanks.
> will
>> be available.
>> > Hi,
> showing
>> > Thanks,
>> > Kevin
Re: How to make a custom drag and drop tracker image [message #449452 is a reply to message #449314] Mon, 24 January 2005 13:04 Go to previous messageGo to next message
Hi Veronika,
I cannot find the DragDetect function in SWT. Could you tell me which file
I should look at?
Thanks.
Kevin
news:csqr0n$b6k$1@www.eclipse.org...
event
drag
> > Thanks.
> > will
> >> be available.
> >> > Hi,
> > showing
a
moved.
> >> > Thanks,
> >> > Kevin
Re: How to make a custom drag and drop tracker image [message #449479 is a reply to message #449452] Tue, 25 January 2005 07:50 Go to previous message
control.addListener(SWT.DragDetect, new Listener() {
public void handleEvent(Event e) {
// code to start using Tracker.
news:ct3dc4$mea$1@www.eclipse.org...
> Hi Veronika,
> file
> I should look at?
> Thanks.
> Kevin
> event
> drag
>> it
>> > Thanks.
>> >> this
>> > will
>> >> be available.
>> >> > Hi,
>> > showing
>> >> > move
> a
> moved.
>> >> > at?
>> >> > Thanks,
>> >> > Kevin
Previous Topic:JFace Table - truncated image size in ITableLabelProvider
Next Topic:activeEditorPart is always null (setActivePage)
Current Time: Sun Jul 27 22:23:32 EDT 2025
Powered by FUDForum. Page generated in 0.08417 seconds
