Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Auto-sizing table columns
Auto-sizing table columns [message #449159] |
Tue, 18 January 2005 17:32  |
Often, we want to automatically widen a column in a table to make if fill
out any extra space when the table control is resized.
This should be pretty easy to do, right? We can just take the available
space, subtract the other column widths, see what's left over and then
decide whether we should plump up a certain column.
But, what about the vertical scroll bar? It takes width too. So, we have
to see if it exists and if it is visible, and then account for its width
too.
The right API's would seem to be:
ScrollBar sb = table.getVerticalBar();
and
sb.getVisible();
The code sample below illustrates this but it doesn't work because
getVisible always returns true, NO MATTER WHAT.
Anyone know a solution to this problem? Our next attempt would be to do
something really hideous like trying to use one of the API's to tell us
what column a certain point is in to indirectly determine whether the
scrollbar is there (yeccchh).
TIA, Bill.
private void maximizeTableColWidth(Table t, int column, int minWidth) {
// Determine overall width available for use by the table
int availableWidth = t.getSize().x - t.getBorderWidth() * 2;
// Subtract the widths of all columns except the one to be maximized
for (int i = 0; i < t.getColumns().length; i++) {
if (i != column ) {
availableWidth -= t.getColumn(i).getWidth();
// If vertical scrollbar is present, subtract its width too
if (t.getVerticalBar() != null) {
if (t.getVerticalBar().getVisible()) {
availableWidth -= t.getVerticalBar().getSize().x;
// Set the column to avail width or its minimum - whichever is larger
t.getColumn(column).setWidth( availableWidth > minWidth ?
availableWidth : minWidth);
Re: Auto-sizing table columns [message #449161 is a reply to message #449159] |
Tue, 18 January 2005 17:52   |
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet77.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
"Bill Ewing" <ewing@irori.com> wrote in message
news:csk2qj$1nm$1@www.eclipse.org...
> too.
> and
> sb.getVisible();
> TIA, Bill.
> if (i != column ) {
Re: Auto-sizing table columns [message #449162 is a reply to message #449161] |
Tue, 18 January 2005 17:54   |
Also compare isVisible and getVisible.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:csk3vm$7u5$1@www.eclipse.org...
> See:
>> have to see if it exists and if it is visible, and then account for its
>> width too.
>> and
>> sb.getVisible();
>> TIA, Bill.
>> if (i != column ) {
Re: Auto-sizing table columns [message #449181 is a reply to message #449161] |
Tue, 18 January 2005 19:23   |
Veronika Irvine wrote:
> See:
>> too.
Nope. The sample you pointed me at merely did what I was already doing.
>> and
>> sb.getVisible();
>> TIA, Bill.
>> if (i != column ) {
Re: Auto-sizing table columns [message #449183 is a reply to message #449162] |
Tue, 18 January 2005 19:28  |
>> See:
>>> width too.
>>> and
>>> sb.getVisible();
>>> TIA, Bill.
>>> if (i != column ) {
Thank you, Veronika, for trying. isVisible worked the same as getVisible.
If you actually think/know the code you suggested works, could you let me
know? A lot of respondents put up answers that look logical, but cannot
spend the time to test them.
Your response did inspire some thoughts: we are using JFace, and it
creates the table object automatically by itself. The constructor
arguments that allow you to set the style and scroll bars are thus hidden,
and there is no post-constructor setStyle method. Thus, my problem may
lie in the design of JFace. However, I can't believe the JFace guys would
be so stupid as to eliminate an option like that, so it has to be
something we're doing wrong.
Anybody got a clue? TIA for all responses.
Current Time: Wed Jul 23 12:07:45 EDT 2025
Powered by FUDForum. Page generated in 0.07834 seconds
