progress bar [message #448982] |
Mon, 08 May 2006 10:05  |
I have seen that there is now the possibility to add a progress bar
under the "Branding" section of the "appname.product" file. However if
I check the "Add a progress bar" and "Add a progress message" check
boxes and enter some values in the dedicated fields (x-offset etc...)
nothing happens in my rcp application.
Is there something more to do to incorporate the progress bar into my
splash screen ?
Thanks very much in advance.
Re: progress bar [message #449033 is a reply to message #449030] |
Mon, 08 May 2006 16:13  |
This did the trick. Thanks for your help.
On 2006-05-08 18:05:49 +0200, "Mauro" <mauro@automaware.com.br> said:
> When you change your appname.prduct you need to syncronyze it before launch
> the product again, try to do this ...
> "Dominique Buenzli" <dominique.buenzli@gmail.com> wrote in message
> news:e3nm5b$3i2$1@utils.eclipse.org...
>> Thanks I was able to show it up in my splash screen adding your code to
>> ApplicationWorkbenchWindowAdvisor.java.
>> However, changing the settings (widght, height) under the "Branding"
>> section of the "appname.product" didn't do anything.
>> What do you mean by do it on property file ? "plugin.properties" ? If yes
> how ?
>> Thanks
>> Dominique
>>> Yes,
>>> public void initialize(IWorkbenchConfigurer configurer) {
>>> PlatformUI.getPreferenceStore().setValue(
>>> IWorkbenchPreferenceConstants.SHOW_PROGRESS_ON_STARTUP, true);
>>> If you wanna fix it
>>> You can do it on property file to be configurable
>>> news:e3nj6m$h07$1@utils.eclipse.org...
>>>> Hello,
>>>> splash screen ?
FUDForum. Page generated in 0.03725 seconds
