Home » Eclipse Projects » Standard Widget Toolkit (SWT) » View refresh problem
View refresh problem [message #448941] Sat, 15 January 2005 09:50 Go to next message
Originally posted by: dicesCAVA.ctonet.it
If i refresh my view from new Thread throw this exception:
org.eclipse.swt.SWTException: Invalid thread access
code is this:
public void myMethod(){
new Thread(){
textViewer.getDocument().set(veryHeavyMethod()); //veryHeavyMethod
return a string
textViewer.refresh();
}.start();
why this exception?
(Sorry for my spaghetti english)
Re: View refresh problem [message #448946 is a reply to message #448941] Sat, 15 January 2005 15:43 Go to previous messageGo to next message
Originally posted by: nickthat.yahoo.com
The problem is that you are only allowed to make certain GUI calls on the
main thread. If you have an operation that takes a long time, you can have
it run on the main thread as a sort of thread i.e. when there are no
messages being processed. This is done by using the method call.
Display.getCurrent().asyncExec(myThread)
> code is this:
> new Thread(){
> return a string
> }.start();
> why this exception?
Re: View refresh problem [message #448950 is a reply to message #448946] Sun, 16 January 2005 07:55 Go to previous messageGo to next message
On Sat, 15 Jan 2005 20:43:39 +0000 (UTC), Nick Thatcher
> the main thread. If you have an operation that takes a long time, you
> can have it run on the main thread as a sort of thread i.e. when there
> are no messages being processed. This is done by using the method call.
Ok, it working but gui is freezed too
Re: View refresh problem [message #448964 is a reply to message #448950] Mon, 17 January 2005 02:57 Go to previous messageGo to next message
you have to call veryHeavyMethod() in a separat thread and store the result
in a string. Then this thread calls another thread with
Display.getCurrent().asyncExec(). The second thread calls
textViewer.getDocument().set() with the stored string.
new Thread(){
final String s = veryHeavyMethod();
Display.getCurrent().asyncExec(new Runnable() {
public void run() {
textViewer.getDocument().set(s);
}.start();
Bye Stefan
"SaThot" <dicesCAVA@ctonet.it> schrieb im Newsbeitrag
news:opsko4udxa5horlisaDjehwty@djehwty.mes...
> > the main thread. If hyou have an operation that takes a long time, you
Re: View refresh problem [message #448989 is a reply to message #448964] Mon, 17 January 2005 07:15 Go to previous messageGo to next message
On Mon, 17 Jan 2005 08:57:07 +0100, Stefan Pietsch <pietsch@multichart.de>
wrote:
> result
> new Thread(){
> public void run() {
> }.start();
if do that Display.getCurrent return null.
Re: View refresh problem [message #449088 is a reply to message #448989] Tue, 18 January 2005 03:50 Go to previous message
I'm sorry, because I have not checked out the code.
I use a static var in my application to store the main display:
public class MyApplication {
public static Display display.
public MyApplication() {
display = new Display();
So I can use this static var in my threads like:
MyApplication.display.asyncExec().
Bye Stefan
news:opskqxopol5horlisaDjehwty@djehwty.mes...
> wrote:
> > Hi,
> > result
> > new Thread(){
> > public void run() {
> > }.start();
Previous Topic:path to images?
Next Topic:How to handle the right mouse button
Current Time: Sat Jul 26 12:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.07235 seconds
