Home » Eclipse Projects » Standard Widget Toolkit (SWT) » where do i put my gif file?
where do i put my gif file? [message #448956] Sun, 16 January 2005 16:58 Go to next message
Where do i put my gif file?
Ok, I think an hour is enough time, right?
pls skip the following parenthetical rant
(<rant begins
Plus too bad i cant Search thru these messages here, i just have
to read all of them, and i can never find what i am looking for...
I AM CERTAIN WHAT I AM DOING HAS NOTHING TO DO WITH A PLUG-IN...
And i looked in the much touted eclipse help....
try "where do i put gif files", try "GIF files" try "images"...
rant ends>).
i have a project. Chap05
It is a java project.
i create a new class, LabelExample, which contains one .gif file
(interspatial.gif)
when i go run my class,LabelExample, it cant find the gif...
where, using eclipse, do i specify where to find the gif file?
i created the interspatial.gif thru ms-paint, and saved it to
c:\temp
where do i put it? Where do i tell eclipse where to find it?
Here's what i mean: [message #448958 is a reply to message #448956] Sun, 16 January 2005 19:59 Go to previous messageGo to next message
here's what i mean:
Image image = new Image(display, "interspatial.gif");
Where in the project do i specify where the gif is
to be found?
For now i just made it like this, and it works:
"C:\\TEMP\\interspatial.gif"
but there has to be a way of copying the resources
into the project. Isnt there?
Re: Here's what i mean: [message #448963 is a reply to message #448958] Mon, 17 January 2005 01:02 Go to previous messageGo to next message
> to be found?
You could store them in the plug-in directory or its subdirectory and
fetch them using the method I described in "Re: path to images" message.
For example, if you stored images in a directory called "images" under
your plug-in's directory, you can fetch them using
MyPlugin.getDefault().getImage("images/interspatial.gif");
Re: Here's what i mean: [message #448995 is a reply to message #448958] Mon, 17 January 2005 10:13 Go to previous messageGo to next message
One simple solution:
1. save your image into the source folder that contains your class
LabelExample.java
2. In your class LabelExample, load it through:
LabelExample.class.getResourceAsStream("interspatial.gif"));
Chris
Re: Here's what i mean: [message #449000 is a reply to message #448995] Mon, 17 January 2005 11:17 Go to previous messageGo to next message
If you di it that way, you need to do this instead or you will have an
unclosed stream laying around.
InputStream is = LabelExample.class.getResourceAsStream("interspatial.gif");
try {
Image image = new Image(display, is);
} finally {
try {
is.close();
} catch (IOException e) {
> LabelExample.java
> Chris
Rich Kulp
Re: Here's what i mean: [message #449193 is a reply to message #449000] Tue, 18 January 2005 22:14 Go to previous messageGo to next message
Rich Kulp wrote:
InputStream is =
Rich
Thanks for your input.
I tried it, but was unable to get far.
InputStream cannot be resolved.
Apparently, i need to import the place where it lives.
For the life of me, i cant figure out where it lives. . .
So what i ask is this...
How do i figure out where InputStream lives?
I tried the help, obviously, but it doesnt help at all.
I then tried by looking at the
"Eclipse Platform Release 3.0" documentation....(thru the 'help')
in the index actually. . . and InputStream is not even in the index.
this is what i have in my imports:
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.graphics.*;
Re: Here's what i mean: [message #449207 is a reply to message #449193] Wed, 19 January 2005 09:50 Go to previous messageGo to next message
Use content assist. It's part of the Java Editor, do ctrl+Space when you
cursor is at the end of the word InputStream and it will present you
with a list of possible completions. One of them will be the InputStream
you want, and when you select it with the enter key or the mouse it will
add the import automatically to your class.
By the way InputStream is a standard part of java. It is
java.io.InputStream.
Victor wrote:
> Rich Kulp wrote:
> InputStream is =
> Rich
> I then tried by looking at the "Eclipse Platform Release 3.0"
Rich Kulp
That is so cool! [message #449278 is a reply to message #449207] Wed, 19 January 2005 22:34 Go to previous message
Thanks for the ctl+space thingy!
and thanks for having patience with me on the java.io thing!
I KNEW THAT! (so why was i spinning my wheels for an hour?)
Previous Topic:How to get parent window's location in new popup window?
Next Topic:pocket PC - ScrollBar.setVisible()
Current Time: Wed Jul 23 17:34:43 EDT 2025
Powered by FUDForum. Page generated in 0.04064 seconds
