Home » Eclipse Projects » Rich Client Platform (RCP) » Open View from Dialog
Open View from Dialog [message #448833] Thu, 04 May 2006 04:58 Go to next message
Originally posted by: b.h.stud.uni-goettingen.de
I have a RCP applcation. I open a view from menu and it works. Now I want
to open the view from a button in a Dialog. The view is multiple. I can
open many views from the menu.
The method makeAction(..) in class ApplicationActionBarAdvisor.java called
new OpenViewAction(window, TreeView.ID);
and the view open. I tried to called this from my Dialog but I need the
window. How can I get the window? In the moment where the Dialog is open I
can't get the activeWorkbenchwindow.
What can I do, to open the view? Sorry my english is very bad but I hope
you understand me?
Gruß
Björn
Re: Open View from Dialog [message #448841 is a reply to message #448833] Thu, 04 May 2006 16:00 Go to previous messageGo to next message
What about the time when your are creating the Dialog?
Is the window available at this point in time?
If yes, you could pass it as argument in the constructor.
Stefan
Björn schrieb:
> Hello,
> want to open the view from a button in a Dialog. The view is multiple. I
> can open many views from the menu.
> I can't get the activeWorkbenchwindow.
> you understand me?
> Gruß
> Björn
Re: Open View from Dialog [message #448848 is a reply to message #448841] Fri, 05 May 2006 02:17 Go to previous messageGo to next message
Hello Stefan,
I start my RCP application and wenn I press a button a Dialog open. In
this Dialog I can choose a datasource. After that I press the OK Button
and now I want to open a view to fill this with data from the datasource.
I dont't understand what you mean with I could pass it as argument in the
constructor? I don't get the window, this is my problem. My class
ViewOpenAction need as argument (IWorkbenchWindow window, String viewid).
The String is viewid = TreeView.ID;
But I don't know how to get the window? I have tried this but it doesn't
work, because I think the dialog is active and not the window.
IWorkbench wb = PlatformUI.getWorkbench();
IWorkbenchWindow window = wb.getActiveWorkbenchWindow();
What can I do? :-(
public class OpenViewAction extends Action {
private final IWorkbenchWindow window;
private int instanceNum;
private final String viewId;
public OpenViewAction(IWorkbenchWindow window, String viewId) {
this.window = window;
this.viewId = viewId;
public void run() {
try {
window.getActivePage().showView(viewId,
Integer.toString(instanceNum++),
IWorkbenchPage.VIEW_ACTIVATE);
} catch (PartInitException e) {
e.printStackTrace();
Re: Open View from Dialog [message #448892 is a reply to message #448848] Sat, 06 May 2006 11:06 Go to previous messageGo to next message
Björn wrote:
> Hello Stefan,
> the constructor? I don't get the window, this is my problem. My class
> What can I do? :-(
What Stefan was saying was, save the workbench window when you open the
dialog. When do you create the dialog? Where in the code? Where in
the code do you open it?
Later,
PW
Re: Open View from Dialog [message #448896 is a reply to message #448848] Sat, 06 May 2006 11:22 Go to previous messageGo to next message
Originally posted by: tom.seidel.javawiki.org
Hi Björn,
why don't you open the view _after_ closing the dialog
something like that:
MyDialog diag = new MyDialog(currentShell);
if (diag.open() == IDialogConstants.OK_ID) {
MyDataFromDialog data = diag.getData();
openNewView(data);
Cheerz,
Björn wrote:
> Hello Stefan,
> What can I do? :-(
> public void run() {
> try {
Re: Open View from Dialog [message #448907 is a reply to message #448848] Sun, 07 May 2006 11:26 Go to previous message
Hello Björn,
afaik you can get the active WorkbenchWindow anytime staticly by:
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
Hope that helps
Best regards
Alex
Previous Topic:RCP, default preferences
Next Topic:Errors when building in 3.2 an RCP plug-in project created in 3.1
Current Time: Sat Aug 30 21:33:15 EDT 2025
Powered by FUDForum. Page generated in 0.05166 seconds
