Home » Eclipse Projects » Rich Client Platform (RCP) » Making another project into a plugin
Making another project into a plugin [message #448862] Fri, 05 May 2006 17:39 Go to next message
I have just started RCP development, so I apologize if my question is a bit naive.... In my current Eclipse development environment, I have a project called (lets say) "Common Framework". This is a bunch of classes that provide persistence, error handling, etc. In my new RCP application, I need to reference classes in this Common Framework project.
Reading the Eclipse RCP book, it seems that making my new RCP application dependant on a new plugin (from an external JAR file) that represents this Common Framework would be a good way to solve this. However, as far as I can tell, it only works if I have an existing JAR file already exported. The challenge is that, during development, I am constantly adding new capabilities to the framework project - in this scenario, I would need to export to a JAR every time I made a change to the framework - which is obviously tedious and prone to forgetfulness.
Is there a way I can make my RCP application reference the workspace "project" during the development cycle, yet still deploy using the plugin-dependancy model when I am finished development. I was thinking that maybe some trickery in the MANIFEST might let me be able to do it, but I would see if anyone else has a similar situation. Many thanks.
Craig
Re: Making another project into a plugin [message #448863 is a reply to message #448862] Fri, 05 May 2006 17:58 Go to previous messageGo to next message
Originally posted by: cfieber.gmail.com
I'd recommend converting your "Common Framework" project to a plugin
project (right click, PDE Tools -> Convert projects to plugin
projects...). This will let you dev with it open in your workspace
along with your other plugins, manage its manifest, etc.
As a plugin project, it still appears as a java project to other
non-plugin related projects, so it won't (shouldn't ;) mess up your
abiilty to use it with standard Java projects.
> Craig
Re: Making another project into a plugin [message #448885 is a reply to message #448862] Sat, 06 May 2006 01:11 Go to previous messageGo to next message
1) Transform your "Common Framework" project into a Plug-in Project: rig=
ht =
click on project (Package explorer) -> PDE Tools -> "Convert Projects to=
Plugin Projects". This operation will add a META-INF/MANIFEST.MF and a =
build.properties to your project's root. Open MANIFEST.MF, select Runtim=
e =
tab and add whatever packages you want to export to other plugins.
2) Open manifest.mf of your rcp plugin, select Dependencies tab and add =
your "Common Framework" plugin to your required plug-ins.
Hope this helps!
Cristinel Angheluta
IQBYTE Romania
Re: Making another project into a plugin [message #448972 is a reply to message #448885] Mon, 08 May 2006 05:07 Go to previous messageGo to next message
> right click on project (Package explorer) -> PDE Tools -> "Convert
> Projects to Plugin Projects".
Thanks to both you and Cameron for your suggestion. It works perfectly! Thanks.
Craig
Re: Making another project into a plugin [message #448973 is a reply to message #448972] Mon, 08 May 2006 05:53 Go to previous messageGo to next message
I am facing the same problem trying to use the jface databinding from CVS.
I add the plugin, my project compiles fine, but when I try to launch it I get a "Required plugin is missing" error...
Re: Making another project into a plugin [message #448974 is a reply to message #448973] Mon, 08 May 2006 05:55 Go to previous message
Duh! I had to add it in the Run configuration too...
Now I'm back to the ClassNotFoundException... *Sigh* Does it have to be so hard ?
Previous Topic:Navigator view
Next Topic:context menu for component within an editor
Current Time: Sun Aug 31 22:44:17 EDT 2025
Powered by FUDForum. Page generated in 0.03228 seconds
