Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Panic ! SWT kills the Java VM
Panic ! SWT kills the Java VM [message #448878] Fri, 14 January 2005 10:14 Go to next message
I'm going a bit desperate. The project's deadline is approaching, and I'm
unable to fix two problems related to SWT. Any comment of any kind is really
welcome.
The problem is that, at certain points and in an aparent ramdom way, SWT
kills the VM.
It is always is a loop like:
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
The display.readAndDispatch() call is one to blame.
I'm using the SWT version bundled with Eclipse 3.0.1.
I'm coping below two VM logs. Again, any help or workaround is truly
welcome.
- Juan
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77D30A22
Function=DrawIcon+0x833
Library=C:\WINDOWS\system32\USER32.dll
Current Java thread:
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:139 7)
at org.eclipse.swt.widgets.Combo.callWindowProc(Combo.java:254)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3050 )
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:1499)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3338 )
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:1496)
at org.eclipse.swt.widgets.Control.WM_LBUTTONDOWN(Control.java: 3672)
at org.eclipse.swt.widgets.Composite.WM_LBUTTONDOWN(Composite.j ava:607)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3001 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 73)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2429)
at estrella.ofertasEmpleo.DialogSondeo.open(DialogSondeo.java:8 0)
at
estrella.ofertasEmpleo.OfertasEmpleo$12.widgetSelected(Ofert asEmpleo.java:516)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at estrella.Estrella.showGUI(Estrella.java:343)
at estrella.Estrella.main(Estrella.java:321)
Dynamic libraries:
0x00400000 - 0x0040B000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\bin\javaw.exe
0x7C910000 - 0x7C9C6000 C:\WINDOWS\system32\ntdll.dll
0x7C800000 - 0x7C901000 C:\WINDOWS\system32\kernel32.dll
0x77DA0000 - 0x77E4C000 C:\WINDOWS\system32\ADVAPI32.dll
0x77E50000 - 0x77EE1000 C:\WINDOWS\system32\RPCRT4.dll
0x77D10000 - 0x77DA0000 C:\WINDOWS\system32\USER32.dll
0x77EF0000 - 0x77F36000 C:\WINDOWS\system32\GDI32.dll
0x77BE0000 - 0x77C38000 C:\WINDOWS\system32\MSVCRT.dll
0x08000000 - 0x08139000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\client\jvm.dll
0x76B00000 - 0x76B2E000 C:\WINDOWS\system32\WINMM.dll
0x10000000 - 0x10007000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\hpi.dll
0x003E0000 - 0x003EE000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\verify.dll
0x008A0000 - 0x008B9000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\java.dll
0x003F0000 - 0x003FD000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\zip.dll
0x02EB0000 - 0x02EFE000 C:\estrella_v2\swt-win32-3063.dll
0x774B0000 - 0x775EC000 C:\WINDOWS\system32\ole32.dll
0x58C30000 - 0x58CC7000 C:\WINDOWS\system32\COMCTL32.dll
0x76360000 - 0x763AA000 C:\WINDOWS\system32\comdlg32.dll
0x77F40000 - 0x77FB6000 C:\WINDOWS\system32\SHLWAPI.dll
0x7C9D0000 - 0x7D1EE000 C:\WINDOWS\system32\SHELL32.dll
0x770F0000 - 0x7717C000 C:\WINDOWS\system32\OLEAUT32.dll
0x76340000 - 0x7635D000 C:\WINDOWS\system32\IMM32.dll
0x74D20000 - 0x74D8B000 C:\WINDOWS\system32\USP10.dll
0x773A0000 - 0x774A2000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll
0x5B150000 - 0x5B188000 C:\WINDOWS\system32\uxtheme.dll
0x030A0000 - 0x03207000 C:\WINDOWS\system32\nview.dll
0x76BB0000 - 0x76BBB000 C:\WINDOWS\system32\PSAPI.DLL
0x77BD0000 - 0x77BD8000 C:\WINDOWS\system32\VERSION.dll
0x77660000 - 0x77681000 C:\WINDOWS\system32\NTMARTA.DLL
0x76F20000 - 0x76F4D000 C:\WINDOWS\system32\WLDAP32.dll
0x71B90000 - 0x71BA3000 C:\WINDOWS\system32\SAMLIB.dll
0x032C0000 - 0x032CC000 C:\Archivos de
programa\Java\j2sdk1.4.2_06\jre\bin\JdbcOdbc.dll
0x745E0000 - 0x7461D000 C:\WINDOWS\system32\ODBC32.dll
0x20000000 - 0x20018000 C:\WINDOWS\system32\odbcint.dll
0x4DDC0000 - 0x4DE04000 C:\WINDOWS\System32\odbcjt32.dll
0x1B000000 - 0x1B170000 C:\WINDOWS\System32\msjet40.dll
0x1B5D0000 - 0x1B665000 C:\WINDOWS\System32\mswstr10.dll
0x67240000 - 0x67250000 C:\WINDOWS\System32\odbcji32.dll
0x1B2C0000 - 0x1B2CD000 C:\WINDOWS\System32\msjter40.dll
0x1B2D0000 - 0x1B2FD000 C:\WINDOWS\System32\MSJINT40.DLL
0x77FC0000 - 0x77FD1000 C:\WINDOWS\system32\Secur32.dll
0x76F90000 - 0x7700F000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77010000 - 0x770E0000 C:\WINDOWS\system32\COMRes.dll
0x1B810000 - 0x1B84A000 C:\WINDOWS\System32\msjtes40.dll
0x0F9A0000 - 0x0F9AB000 C:\WINDOWS\system32\VBAJET32.DLL
0x0F9C0000 - 0x0FA22000 C:\WINDOWS\system32\expsrv.dll
0x74C10000 - 0x74C3C000 C:\WINDOWS\system32\oleacc.dll
0x76030000 - 0x76095000 C:\WINDOWS\system32\MSVCP60.dll
0x04F30000 - 0x04F45000 C:\WINDOWS\system32\nvwddi.dll
0x77B10000 - 0x77B32000 C:\WINDOWS\system32\appHelp.dll
0x779F0000 - 0x77A45000 C:\WINDOWS\System32\cscui.dll
0x765B0000 - 0x765CD000 C:\WINDOWS\System32\CSCDLL.dll
0x75F30000 - 0x7602C000 C:\WINDOWS\System32\browseui.dll
0x778F0000 - 0x779E7000 C:\WINDOWS\system32\SETUPAPI.dll
0x76950000 - 0x76976000 C:\WINDOWS\system32\ntshrui.dll
0x76AE0000 - 0x76AF1000 C:\WINDOWS\system32\ATL.DLL
0x597F0000 - 0x59844000 C:\WINDOWS\system32\NETAPI32.dll
0x76630000 - 0x766E4000 C:\WINDOWS\system32\USERENV.dll
0x77730000 - 0x7789C000 C:\WINDOWS\System32\shdocvw.dll
0x77A50000 - 0x77AE5000 C:\WINDOWS\system32\CRYPT32.dll
0x77AF0000 - 0x77B02000 C:\WINDOWS\system32\MSASN1.dll
0x76890000 - 0x76914000 C:\WINDOWS\system32\CRYPTUI.dll
0x76BF0000 - 0x76C1E000 C:\WINDOWS\system32\WINTRUST.dll
0x76C50000 - 0x76C78000 C:\WINDOWS\system32\IMAGEHLP.dll
0x77180000 - 0x77227000 C:\WINDOWS\system32\WININET.dll
0x76940000 - 0x76948000 C:\WINDOWS\system32\LINKINFO.dll
0x059D0000 - 0x05CA6000 C:\WINDOWS\system32\xpsp2res.dll
0x5D4B0000 - 0x5D551000 C:\WINDOWS\system32\DBGHELP.dll
Heap at VM Abort:
Heap
def new generation total 768K, used 318K [0x10010000, 0x100e0000,
0x104f0000)
eden space 704K, 38% used [0x10010000, 0x10053cf0, 0x100c0000)
from space 64K, 73% used [0x100d0000, 0x100dbbf0, 0x100e0000)
to space 64K, 0% used [0x100c0000, 0x100c0000, 0x100d0000)
tenured generation total 9448K, used 9258K [0x104f0000, 0x10e2a000,
0x14010000)
the space 9448K, 97% used [0x104f0000, 0x10dfa8c8, 0x10dfaa00,
0x10e2a000)
compacting perm gen total 5632K, used 5564K [0x14010000, 0x14590000,
0x18010000)
the space 5632K, 98% used [0x14010000, 0x1457f368, 0x1457f400,
0x14590000)
Local Time = Fri Jan 14 11:17:19 2005
Elapsed Time = 6158
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_06-b03 mixed mode)
# An error report file has been saved as hs_err_pid2124.log.
# Please refer to the file for further information.
M
Re: Panic ! SWT kills the Java VM [message #448884 is a reply to message #448878] Fri, 14 January 2005 12:51 Go to previous messageGo to next message
Sounds like the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=4721
Are you running on Windows NT? Do you have any very long strings ion the
Combo?
"Juan" <juan00045@hotmail.com> wrote in message
news:cs8nec$jvk$1@www.eclipse.org...
> I'm unable to fix two problems related to SWT. Any comment of any kind is
> really welcome.
> SWT kills the VM.
> display.sleep();
> welcome.
> - Juan
> PC=0x77D30A22
> at
> at
> Dynamic libraries:
> Heap at VM Abort:
> Heap
> 0x104f0000)
> 0x14010000)
> 0x10e2a000)
> 0x18010000)
> 0x14590000)
> Elapsed Time = 6158
> M
Re: Panic ! SWT kills the Java VM [message #448943 is a reply to message #448884] Sat, 15 January 2005 21:09 Go to previous messageGo to next message
> Combo?
After reading the bug, I'm not sure it's the same problem... I'm using
Windows XP SP2.
I've tried with the latest released libraries (bundled with Eclipse M4) with
the same result. I'm not using any other library (native or java) for this
project.
I've been searching for any bug entry affecting the Windows library method
reported in the VM crash log (DrawIcon in USER32.DLL) without success.
So, I'm a bit lost here..
- Juan
Re: Panic ! SWT kills the Java VM [message #448985 is a reply to message #448943] Mon, 17 January 2005 05:29 Go to previous message
I've been reading several bug reports this weekend, but didn't find any that
could be considered the same. I've placed a new bug report (#82953). I'll
continue to try to reproduce this problem in a consistent way.
"Juan" <juan00045@hotmail.com> escribi
Previous Topic:How to use a TitleAreaDialog as main Window
Next Topic:Table
Current Time: Wed Jul 23 21:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.25536 seconds
