Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Setting source of SelectionEvent
Setting source of SelectionEvent [message #448413] Sat, 08 January 2005 10:58 Go to next message
Originally posted by: fleque.users.NoSpam.sourceforge.net
Hi all,
I'm trying to implement a Composite accepting and notifying
SelectionListeners. So far so good, but I'm not able to instantiate a
SelectionEvent and set its source.
Is there a way?
Regards Alex
Re: Setting source of SelectionEvent [message #448762 is a reply to message #448413] Thu, 13 January 2005 15:19 Go to previous messageGo to next message
Alex,
You just create a regular Event object, set its widget field, and send it
with Widget.notifyListeners(SWT.Selection, yourEvent).
Grant
"Fleque" <fleque@users.NoSpam.sourceforge.net> wrote in message
news:crovuf$74i$1@www.eclipse.org...
> Hi all,
> Is there a way?
> Regards Alex
Re: Setting source of SelectionEvent [message #448769 is a reply to message #448762] Thu, 13 January 2005 15:51 Go to previous messageGo to next message
Thanks for your answer Grant,
I had a look at this possibility (and some implementations of Widgets)
and found the ?prefered? way to add listeners is by adding a
TypedListener. I can do that in my Composite but can not remove it as I
can not access the package-visible member of Widget eventTable to invoke
unhook. Is there an other way to remove the listener ??
Regards Alex
Grant Gayed wrote:
> Alex,
> Grant
Re: Setting source of SelectionEvent [message #448877 is a reply to message #448769] Fri, 14 January 2005 09:45 Go to previous message
Widget.removeListener(int, Listener) should do what you want.
Grant
news:cs6n09$9on$1@www.eclipse.org...
> Regards Alex
> Grant Gayed wrote:
> > Alex,
it
> > Grant
Previous Topic:Image with transparent background
Next Topic:TableEditor Question
Current Time: Sat Jul 26 10:29:34 EDT 2025
Powered by FUDForum. Page generated in 0.07462 seconds
