Home » Eclipse Projects » Rich Client Platform (RCP) » Get classes from RCP to plugin
Get classes from RCP to plugin [message #448724] Sun, 30 April 2006 09:42 Go to next message
Hello !
I have created an editor as a plugin for my rcp-application.
The rcp-application is dependent on that plugin. In the context menu of that editor plugin i try to invoke some methods of the main rcp-application.
Now when i try to access classes from my rcp inside the plugin i get errors because of cycled dependencies.
My question is how can i access classes that are in my main rcp-application ?
Thanks in advance for any answer !
Re: Get classes from RCP to plugin [message #448739 is a reply to message #448724] Mon, 01 May 2006 07:43 Go to previous messageGo to next message
Marcel wrote:
> Hello !
Option 1. Refactor your plugins so you don't have cyclic dependences!
Seriously, if you wrote the editor plugin and the RCP app plugin, create
a utilities plugin. Have the editor plugin and the RCP app plugin both
depend on the utilities plugin.
Option 2. Fool around with buddy classloading. You can set a policy on
the editor, and have the RCP app register itself with the editor plugin.
A google search should turn up some examples.
Later,
PW
Re: Get classes from RCP to plugin [message #448778 is a reply to message #448739] Tue, 02 May 2006 05:22 Go to previous messageGo to next message
Thanks for the answer which is of course very helpful for me to get a better understanding!
But i think in my case the easiest solution would be to contribute a menu point to the editor from my rcp application.
So is it also possible to contribute a menu point in the context menu of the required editor from my rcp application ? And if it is possible how can i realize that ?
Re: Get classes from RCP to plugin [message #448782 is a reply to message #448778] Tue, 02 May 2006 08:08 Go to previous messageGo to next message
Have your editor create its context menu. Then use the
org.eclipse.ui.popupMenu extension point in your RCP app to contribute
to your editor context menu (probably viewerContribution).
http://www.eclipse.org/articles/Article-action-contribution/ Contributing%20Actions%20to%20the%20Eclipse%20Workbench.html
Later,
PW
Re: Get classes from RCP to plugin [message #448799 is a reply to message #448782] Wed, 03 May 2006 02:36 Go to previous message
Exactly what i need. Thank you very much for your help !
Previous Topic:key assist in RCP app
Next Topic:[How to] prepare a plugin to be patched?
Current Time: Mon Sep 01 01:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
