3.2M6 custom target problem [message #447344] |
Tue, 04 April 2006 04:00  |
I'm trying to run our RCP App against a
custom target platform consisting of a bunch of
3.2M5 plugins.
In M5 it works perfectly, but in M6 I get the
following exception on startup:
java.lang.IllegalStateException: Bundle
initial@reference :file:plugins/org.eclipse.update.configurator_3.1.100.v20051 214.jar/
was not resolved.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startBundles (EclipseStarter.java:1064)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:627)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:296)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:165)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Seems that the bundle is started twice!?
Any suggestions?
Thanx, Volker
Re: 3.2M6 custom target problem [message #448679 is a reply to message #447355] |
Fri, 28 April 2006 04:10  |
Found it myself finally:
com.ibu.icu was missing in my custom target.
Would have been great if eclipse had indicated that properly.
Volker
Volker wrote:
> Hi Paul,
> thank you for your prompt reply.
>> Which plugins are listed in your launch configuration? Are there any
>> references to the configurator from M6?
>> org.eclipse.update.configurator_3.1.100.v20060329.jar
> No references to M6 plugins. I don't see any of M6 actually, since my
> (custom) target is based on M5 plugins.
> I created a .target file in M5 using the new target-Editor and load it
> via Preferences->Target Platform 'Load Target'.
> I did not change the target, just use M6 instead of M5.
>> Is the M5 configurator
>> org.eclipse.update.configurator_3.1.100.v20051214.jar still available
>> in the target directory? Is it listed specifically in the launch config?
> Yes, the M5 configurator plugin is listed (and checked) under 'Target
> Platform'. 'Validate Plug-in Set' does not show any unresolved
> dependencies.
>> You didn't update to M6 by expanding it over your M5 install?
> No, fresh installation into new directory. I do use my old (M5-created)
> workspace though.
> Thanks so far, I really hope you can help me out on this one.
> Volker
FUDForum. Page generated in 0.02847 seconds
