Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TableTree events not forwarded by TableTreeViewer?
TableTree events not forwarded by TableTreeViewer? [message #448642] Wed, 12 January 2005 13:57 Go to next message
Originally posted by: fn2o-mycl.spamex.com
I want to enable and disable right-click menu items depending on which
TreeTableViewer has been clicked clicked like in this Tree example:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet90.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
I've added listeners for the TableTree events but it appears that the
messages aren't being forwarded by the TableTreeViewer. Is this not
supported, have I done something wrong, or is JFace busted?
TableTree tableTree = (TableTree) tableTreeViewer.getControl();
tableTree.addListener (SWT.MouseDown, new Listener ()
public void handleEvent (Event event)
// Event is never received.
System.out.println ("TableTree SWT.MouseDown");
Re: TableTree events not forwarded by TableTreeViewer? [message #448646 is a reply to message #448642] Wed, 12 January 2005 14:12 Go to previous messageGo to next message
------=_NextPart_000_01D6_01C4F8B0.B1AA3130
Content-Type: text/plain;
charset="iso-8859-15"
Content-Transfer-Encoding: quoted-printable
You need to do:
TableTree tableTree =3D (TableTree) tableTreeViewer.getControl();
tableTree.getTable().addListener (SWT.MouseDown, new Listener ()
In 3.1, consider using Tree with TreeColumns instead of TableTree. Tree =
does not have these issues.
"Mighty M" <fn2o-mycl@spamex.com> wrote in message =
news:cs3rv0$uqu$1@www.eclipse.org...
>I want to enable and disable right-click menu items depending on which=20
>=20
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org=
/eclipse/swt/snippets/Snippet90.java?rev=3DHEAD&content- type=3Dtext/vnd.v=
iewcvs-markup
>=20
> I've added listeners for the TableTree events but it appears that the=20
> messages aren't being forwarded by the TableTreeViewer. Is this not=20
>=20
>=20
>=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.2523" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT size=3D2>You need to do:</FONT></DIV>
<DIV><FONT size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT size=3D2>TableTree tableTree =3D (TableTree)=20
tableTreeViewer.getControl();<BR>tableTree.<STRONG><FONT=20
color=3D#ff0000>getTable().</FONT></STRONG>addListener (SWT.MouseDown, =
new=20
Listener ()<BR>{<BR>&nbsp; public void handleEvent (Event =
event)<BR>&nbsp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp; // Event is never=20
received.<BR><BR>&nbsp;&nbsp;&nbsp;&nbsp; System.out.println ("TableTree =
SWT.MouseDown");<BR>&nbsp; }<BR>});</FONT></DIV>
<DIV><FONT size=3D2>In 3.1, consider using Tree with TreeColumns instead =
of=20
TableTree.&nbsp; Tree does not have these issues.<BR></FONT></DIV>
<DIV><FONT size=3D2>"Mighty M" &lt;</FONT><A=20
href=3D"mailto:fn2o-mycl@spamex.com"><FONT=20
size=3D2>fn2o-mycl@spamex.com</FONT></A><FONT size=3D2>&gt; wrote in =
message=20
</FONT><A href=3D"news:cs3rv0$uqu$1@www.eclipse.org"><FONT=20
size=3D2>news:cs3rv0$uqu$1@www.eclipse.org</FONT></A><FONT=20
size=3D2>...</FONT></DIV><FONT size=3D2>&gt;I want to enable and disable =
right-click=20
menu items depending on which <BR>&gt; TreeTableViewer has been clicked =
clicked=20
like in this Tree example:<BR>&gt; <BR>&gt; </FONT><A=20
href=3D" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets=
/src/org/eclipse/swt/snippets/Snippet90.java?rev=3DHEAD& amp;content-type=3D=
text/vnd.viewcvs-markup"><FONT=20
size=3D2> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppet=
s/src/org/eclipse/swt/snippets/Snippet90.java?rev=3DHEAD& ;amp;content-type=
=3Dtext/vnd.viewcvs-markup</FONT></A><BR><FONT=20
size=3D2>&gt; <BR>&gt; I've added listeners for the TableTree events but =
it=20
appears that the <BR>&gt; messages aren't being forwarded by the=20
TableTreeViewer. Is this not <BR>&gt; supported, have I done something =
wrong, or=20
is JFace busted?<BR>&gt; <BR>&gt; TableTree tableTree =3D (TableTree)=20
tableTreeViewer.getControl();<BR>&gt; tableTree.addListener =
(SWT.MouseDown, new=20
Listener ()<BR>&gt; {<BR>&gt;&nbsp;&nbsp; public void handleEvent (Event =
event)<BR>&gt;&nbsp;&nbsp; {<BR>&gt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // =
Event is=20
never received.<BR>&gt; <BR> &gt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=2 0
System.out.println ("TableTree SWT.MouseDown");<BR>&gt;&nbsp;&nbsp; =
}<BR>&gt;=20
});<BR>&gt; <BR>&gt;</FONT></BODY></HTML>
------=_NextPart_000_01D6_01C4F8B0.B1AA3130--
Re: TableTree events not forwarded by TableTreeViewer? [message #448661 is a reply to message #448646] Wed, 12 January 2005 18:08 Go to previous messageGo to next message
Thanks! Where can I get a build that supports TreeColumns? I just
installed Stable Build: 3.1M4 (December 17, 2004) and it doesn't contain a
TreeColumns class.
While attaching the SWT.MouseDown handler to the TableTree captures
right-clicks for the 1st column, no right-click SWT.MoustDown is received
in column two or higher.
Veronika Irvine wrote:
> You need to do:
Re: TableTree events not forwarded by TableTreeViewer? [message #448692 is a reply to message #448661] Thu, 13 January 2005 08:34 Go to previous message
> TreeColumns class.
It is very new and just became available in this weeks 3.1 integration
build.
I tested on Windows and I am receiving MouseDown events for all columns.
What platform are you using? Note also that you need to create the
TableTree with the style SWT.FULL_SELECTION in order for
TableTree.getItem(Point) to return an item if click anywhere other than the
first column. Perhaps you are getting the mouse down event but are failing
on the call to getItem.
news:cs4alu$mhs$1@www.eclipse.org...
> TreeColumns class.
>> You need to do:
Previous Topic:testing...
Next Topic:Clipboard change notifications?
Current Time: Sat Jul 19 04:36:46 EDT 2025
Powered by FUDForum. Page generated in 0.03605 seconds
