Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWTError
SWTError [message #448152] Tue, 04 January 2005 05:26 Go to next message
Originally posted by: pankajsanghi.hotmail.com
hi everybody,
We have developed a SWT based plugin which extends the functionality of
GEF Logic Example(Another eclipse plugin). As of now, we run this plugin
as 'Runtime Workbench'.
While the application is running, sometime it throws the exception as
given below and my whole run time workbench window gets closed. I am
giving the exception trace as below. To my surprise this exception trace
nowhere mentions the name of my classes. Exception is thrown under three
categories as
1. org.eclipse.swt.SWTError: No more handles
2. Dialog open exception:org.eclipse.swt.SWTError: No more handles
3. Fatal error happened during workbench emergency close.
Can you please help me with the possible cause of this error and how I can
handle it without knowing the class where it is generated. Should I use
try catch block to handle it??
Please help me in resolving the problem??
regards
Pankaj Sanghi
at org.eclipse.swt.SWT.error(SWT.java:2715)
at org.eclipse.swt.SWT.error(SWT.java:2614)
at org.eclipse.swt.SWT.error(SWT.java:2585)
at org.eclipse.swt.graphics.Image.internal_new_GC(Image.java:17 23)
at org.eclipse.swt.graphics.GC.<init>(GC.java:120)
at org.eclipse.swt.graphics.GC.<init>(GC.java:87)
at
org.eclipse.draw2d.BufferedGraphicsSource.getGraphics(Buffer edGraphicsSource.java:76)
at
org.eclipse.draw2d.DeferredUpdateManager.getGraphics(Deferre dUpdateManager.java:108)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:194)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:134)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:118)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem .java:211)
at
org.eclipse.draw2d.LightweightSystem$4.handleEvent(Lightweig htSystem.java:115)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:80 3)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3001 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3282 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 75)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2380)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
at org.eclipse.swt.graphics.Image.init(Image.java:1564)
at org.eclipse.swt.graphics.Image.init(Image.java:1689)
at org.eclipse.swt.graphics.Image.<init>(Image.java:628)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:878)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:947)
at org.eclipse.jface.window.Window.configureShell(Window.java:2 91)
at
org.eclipse.jface.dialogs.MessageDialog.configureShell(Messa geDialog.java:159)
at org.eclipse.jface.window.Window.createShell(Window.java:408)
at org.eclipse.jface.window.Window.create(Window.java:347)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:924)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open (InternalErrorDialog.java:67)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open Question(InternalErrorDialog.java:173)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.openQuestion Dialog(IDEExceptionHandler.java:151)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:83)
at
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.eventLoopExc eption(IDEWorkbenchAdvisor.java:241)
at
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:62)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1367)
at
at
at
at
at org.eclipse.swt.graphics.Image.<init>(Image.java:279)
at org.eclipse.swt.widgets.ToolItem.createDisabledImage(ToolIte m.java:195)
at org.eclipse.swt.widgets.ToolItem.updateImages(ToolItem.java: 794)
at org.eclipse.swt.widgets.ToolItem.setEnabled(ToolItem.java:55 6)
at
org.eclipse.jface.action.StatusLine.setCancelEnabled(StatusL ine.java:386)
at
org.eclipse.jface.action.StatusLineManager.setCancelEnabled( StatusLineManager.java:228)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:609)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1588)
at
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorManager.java:845)
at org.eclipse.ui.internal.EditorManager.saveAll(EditorManager. java:947)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:508)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:608)
at org.eclipse.core.runtime.Platform.run(Platform.java:758)
at org.eclipse.ui.internal.Workbench.saveAllEditors(Workbench.j ava:482)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:4 08)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:39 9)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:571)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:569)
at
org.eclipse.ui.internal.WorkbenchConfigurer.emergencyClose(W orkbenchConfigurer.java:150)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.closeWorkben ch(IDEExceptionHandler.java:104)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:84)
at
at
at
at
at
at
Re: SWTError [message #448155 is a reply to message #448152] Tue, 04 January 2005 07:11 Go to previous messageGo to next message
This happens when the component you use is not supported on your platform.
This happen with a component on AIX for example.
Pankaj Sanghi wrote:
> hi everybody,
> categories as
> regards
> Pankaj Sanghi
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: SWTError [message #448183 is a reply to message #448155] Tue, 04 January 2005 22:43 Go to previous message
Hi everybody
Can you please elaborate on it a little. Is it about an unsupported
component on eclipse platform or SWT platform itself.
thanks and regards
Pankaj Sanghi
>> hi everybody,
>> categories as
>> regards
>> Pankaj Sanghi
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Opening and closing a view programmatically
Next Topic:One more label in Section.
Current Time: Sun Jul 27 11:43:16 EDT 2025
Powered by FUDForum. Page generated in 0.03977 seconds
