Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Trying to find a widget that behaves like widget in Outlook 2003
Trying to find a widget that behaves like widget in Outlook 2003 [message #447652] Wed, 15 December 2004 18:11 Go to next message
Originally posted by: parwizr.msoft.com
I'm faily new to SWT and Eclipse but have the bulk of my GUI app built so
far.
I wanted to implement a widget similiar to the Outlook 2003 left side menu
with icons
that expand and shrink. I've included two snap shots to give you an idea of
what it looks like.
Please give me some pointers, advice, or anything helpful because I'm lost
as how to start
writting a custom widget like the Outlook control. Is this an ActiveX object
and if so
how can I use it in my Eclipse GUI.
thanks,
Parwiz
  • Attachment: snap1.jpg
    (Size: 11.27KB, Downloaded 171 times)
  • Attachment: snap2.jpg
    (Size: 9.69KB, Downloaded 145 times)
Re: Trying to find a widget that behaves like widget in Outlook 2003 [message #447750 is a reply to message #447652] Thu, 16 December 2004 22:40 Go to previous messageGo to next message
--------------050102050105060100000007
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
<font face="serif">You'll have to emulate it yourself.&nbsp; As to how to
start...<br>
<br>
I'm envisioning a subclass of Composite as the actual widget you
control.&nbsp; Within that widget you would have possibly subclasses of
Canvas which would be dynamically moved (no layout manager) within your
composite.&nbsp; This would implement your little icon-tab-text-thingies.&nbsp;
The internal frames would be once again dynamically controlled by the
Composite subclass and be most likely Composite's themselves.&nbsp; For
instance: (this code is designed as I type so it's not guarantied to
compile)<br>
<br>
/**<br>
&nbsp;* This is the main widget class.<br>
&nbsp;*/<br>
public class OutlookBar extends Composite {<br>
&nbsp;&nbsp;&nbsp; public OutlookBar(Composite parent, int style) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; super(parent, style);<br>
&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; /**<br>
&nbsp;&nbsp;&nbsp;&nbsp; * Called by the class OutlookItem when it is created with this
instance as it's parent.<br>
&nbsp;&nbsp;&nbsp;&nbsp; */<br>
&nbsp;&nbsp;&nbsp; void addChild(OutlookItem item) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; <br>
}<br>
<br>
public class OutlookItem extends Item {<br>
&nbsp;&nbsp;&nbsp; public OutlookItem(OutlookBar parent, int style) {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; super(parent, style);&nbsp;&nbsp; &nbsp;&nbsp; // ???<br>
<br>
&nbsp;&nbsp;&nbsp; public void setImage(Image image) {}<br>
<br>
&nbsp;&nbsp;&nbsp; public void setText(String text) {}<br>
<br>
&nbsp;&nbsp;&nbsp; public void setGradientColor1(Color color1) {}<br>
<br>
&nbsp;&nbsp;&nbsp; public void setGradientColor2(Color color2) {}<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * You create a Composite with the instance of<br>
&nbsp;&nbsp;&nbsp;&nbsp; * OutlookBar as it's parent and pass it to this method<br>
&nbsp;&nbsp;&nbsp;&nbsp; * of the corresponding OutlookItem.<br>
&nbsp;&nbsp;&nbsp; public void setControl(Composite child) {}<br>
}<br>
<br>
These are just stubs, but you get the idea.&nbsp; Your other option is to
see if the OutlookBar thingy is published as an ActiveX control by
MSOffice.&nbsp; If so, then you can embed it in your application using the
org.eclipse.swt.internal.win32.activex package.&nbsp; (I'm pretty sure about
the package name, double check it)&nbsp; However, this solution will <i>only</i>
work on windows.&nbsp; The best solution in my opinion is to either use a
native control (like a TabbedPane), or emulate the OutlookBar as
demonstrated above.<br>
<br>
Daniel<br>
</font><br>
Parwiz wrote:
<blockquote cite="midcpqgci$7uv$1@www.eclipse.org" type="cite">
<pre wrap="">Hi,
far.
with icons
what it looks like.
as how to start
and if so
thanks,
Parwiz
</pre>
<center><img src="cid:part1.05000902.04030901@hotpop.com"></center>
<center><img src="cid:part2.09070200.04070400@hotpop.com"></center>
</blockquote>
</body>
</html>
Content-Type: image/jpeg
Content-ID: <part1.05000902.04030901@hotpop.com>
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CADjAO0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1bw//AMjbq/8A142f/oy5 rqa5bw//AMjb
q/8A142f/oy5rqa3xH8R/L8kZ0vgCiiisDQq6i1qlhK17EktvxuR1DBuRjg8 dcda5sWfgm8m
2XWiaOjEZDT20DA/iMgfjW9rTbNODH/nvB/6NWsXUdXghVh56Aj/AGhXDi8X 9XaujalS9psa
Oj6V4Zs7l5tEsNIgn2bHeyhjVtpIOCVGcZA/KpZvEug22qDS59b02LUC6oLR 7pFlLNjaNhOc
nIwMc5Fcj4W1P7Z47MQkDr/Z8rDBzjEkQ/rXTXUEzeOtJuFikMCaZeo8gU7V ZpbUqCegJCsQ
O+0+lbYWv7ekqlrXJq0/ZzcbmhPqtjbaNLrD3MZ0+O3N01xH86mILu3jbncN vPGc9quV5GIN
UuvBOoW+sxeIJtal0LZYxhbpo3B09Q4kC/uzKZvPGJf3mdv+xWhr0fiD7RBa XN3qUMavNLeX
VvbXdxHNIxQQeUtrIkiJsWUFMkKV+fezpK/QZnpEc8MzzJFLG7wvslVWBKNt DYb0O1lOD2IP
epK8zh0/ULSHXnvbzWbXWLtLaU3SWdxOkkYhtY5D5NuxjWVnSRT5bCRRllba A1dp4WM58OWh
uLOezkO8+TPdy3Lhd7bSZJQJDkYbDgMudpAIwADYooooAKKKKACiiigAoooo AKKKKACiiigC
Of8A1J/D+dRR1LP/AKk/h/Ooo6T3AyvGf/Ii69/2D5//AEA15x4q/wCRnn/6 8YP/AEOavR/G
f/Ii69/2D5//AEA15x4q/wCRnn/68YP/AEOau2h/Bl/XYwn8aOi+EX/II13/ ALCx/wDSeCvQ
688+EX/II13/ALCx/wDSeCvQ65HubLY5bw//AMjbq/8A142f/oy5rqa5bw// AMjbq/8A142f
/oy5rqa2xH8R/L8kRS+AKKKKwNCrqLWqWErXsSS2/G5HUMG5GODx1x1rmxZ+ CbybZdaJo6MR
kNPbQMD+IyB+Nb2tNs04Mf8AnvB/6NWsXUdXghVh56Aj/aFcOLxf1dq6NqVL 2mxo6PpXhmzu
Xm0Sw0iCfZsd7KGNW2kg4JUZxkD8qlm8S6DbaoNLn1vTYtQLqgtHukWUs2No 2E5ycjAxzkVy
PhbU/tnjsxCQOv8AZ8rDBzjEkQ/rXTXUEzeOtJuFikMCaZeo8gU7VZpbUqCe gJCsQO+0+lbY
Wv7ekqlrXJq0/ZzcbhH408KzJM8XiXRnSFN8rLfxEIu4Llvm4G5lGT3IHeti CeG6t4ri3ljm
glQPHJGwZXUjIII4II5zXD67bXKeGfiMos7uR7x3S2SK3eRpi9jBGuxVBLDf kEjgYOcYOO4g
mW5t4p0EgSRA6iSNkYAjPKsAVPsQCO9dBmSUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
Rz/6k/h/Ooo6ln/1J/D+dRR0nuBleM/+RF17/sHz/wDoBrzjxV/yM8//AF4w f+hzV6P4z/5E
XXv+wfP/AOgGvOPFX/Izz/8AXjB/6HNXbQ/gy/rsYT+NHRfCL/kEa7/2Fj/6 TwV6HXnnwi/5
BGu/9hY/+k8Feh1yPc2Wxy3h/wD5G3V/+vGz/wDRlzXU1y3h/wD5G3V/+vGz /wDRlzXU1tiP
4j+X5Iil8AUUUVgaFXUWtUsJWvYklt+NyOoYNyMcHjrjrXNiz8E3k2y60TR0 YjIae2gYH8Rk
D8a3tabZpwY/894P/Rq1i6jq8EKsPPQEf7QrhxeL+rtXRtSpe02NHR9K8M2d y82iWGkQT7Nj
vZQxq20kHBKjOMgflWi9/ZxxXUsl3Akdpn7S7SACHChzvP8AD8pDc9iD0rhf C2p/bPHZiEgd
f7PlYYOcYkiH9adryzx2XjfSPsV9Jd63v+weTZyyRyb7OKFd0qqUj/eIwO9l wBk4Ug1tha/t
6SqWtcmrT9nNxudhda7o9jqMGnXmq2NvfT7fJtprhEkk3Hau1ScnJBAx1NSa bq2m6zbtcaXq
FpfQK5RpLWZZVDYBwSpIzgg49xWHpF2NEurnTtQtr5r271CaYXMNlNNHMkkp MRaVFIXamyM7
yu0R/wBwKxk8ESmXQrktb3cB/tO+cLdW0kDFXuZJEIV1BIKupz7kdQQOgzOk ooooAKKKKACi
iigAooooAKKKKACiiigAooooAZKMx49SP51QN9DF/DIw9QB/jWhJ90f7w/nX nGrarqml3K3A
tvtmnyxiNUhXDxy9s9chiQM/TjP3tqNNTbuROXKb/ivUYbjwV4gjVXVhp05+ YDn5COx964Tx
V/yM8/8A14wf+hzVq6gb8eAddOpNH9pawlYrGMBASML15x0z/PqcrxV/yM8/ /XjB/wChzV1q
ChTkl/Wxhzc0l/Xc6L4Rf8gjXf8AsLH/ANJ4K9Drzz4Rf8gjXf8AsLH/ANJ4 K9Drz3udK2OF
s9c03RfFupf2hciDzbG12ZRmziS4z0B9RWz/AMJz4b/6CS/9+pP/AImvOPFf hrVfEPi1/wCz
J7WLyLGHzPtDsud0k2MYU+hrK/4Vr4q/5/dK/wC/0n/xuu+o8FzfvalpaafL 0OWLr29yN0eu
f8Jz4b/6CS/9+pP/AImj/hOfDf8A0El/79Sf/E15H/wrXxV/z+6V/wB/pP8A 43R/wrXxV/z+
6V/3+k/+N1F8t/5/fj/wCr4r+T+vvPVb3xj4aubSSE3tvKGwNk8Dsh57jbzj rj27ViC68CTT
f6bZeH50I+8NLIYH6FDn8xXC/wDCtfFX/P7pX/f6T/43R/wrXxV/z+6V/wB/ pP8A43U/8Jt7
+2/H/gBfFfyf1956Vp+r+ANIuGuNNh02ymZdjSW1h5bFcg4JVAcZA49hWl/w nPhv/oJL/wB+
pP8A4mvI/wDhWvir/n90r/v9J/8AG6P+Fa+Kv+f3Sv8Av9J/8bp3y3/n9+P/ AAAviv5P6+89
c/4Tnw3/ANBJf+/Un/xNH/Cc+G/+gkv/AH6k/wDia8j/AOFa+Kv+f3Sv+/0n /wAbo/4Vr4q/
5/dK/wC/0n/xunfLf+f34/8AAC+K/k/r7z1z/hOfDf8A0El/79Sf/E00+PfD CuqNqqB3ztUx
vk464+WvJf8AhWvir/n90r/v9J/8bqe18AeL7KSSSC+0dXkheFmZmY7GGGAJ jOMjjIwaTll1
tKv4/wDAGniesP6+89RX4geFX2bdYibzM7MI53Y6445oX4geFX2bdYibzM7M I53Y6445rzVf
BfjVPL2X+iL5do1kmFI2wnOVH7rgnJy3Xk80L4L8ap5ey/0RfLtGskwpG2E5 yo/dcE5OW68n
mo5sD/z9X3/8Ad6/8n4f8E9KX4geFX2bdYibzM7MI53Y6445oX4geFX2bdYi bzM7MI53Y644
5rzVfBfjVPL2X+iL5do1kmFI2wnOVH7rgnJy3Xk80L4L8ap5ey/0RfLtGskw pG2E5yo/dcE5
OW68nmjmwP8Az9X3/wDAC9f+T8P+Cenf8Jz4b/6CS/8AfqT/AOJo/wCE58N/ 9BJf+/Un/wAT
Xkf/AArXxV/z+6V/3+k/+N0f8K18Vf8AP7pX/f6T/wCN1pfLf+f34/8AAJvi v5P6+89c/wCE
58N/9BJf+/Un/wATR/wnPhv/AKCS/wDfqT/4mvI/+Fa+Kv8An90r/v8ASf8A xuj/AIVr4q/5
/dK/7/Sf/G6L5b/z+/H/AIAXxX8n9feeuf8ACc+G/wDoJL/36k/+Jo/4Tnw3 /wBBJf8Av1J/
8TXkf/CtfFX/AD+6V/3+k/8AjdH/AArXxV/z+6V/3+k/+N0Xy3/n9+P/AAAv iv5P6+89c/4T
nw3/ANBJf+/Un/xNH/Cc+G/+gkv/AH6k/wDia8j/AOFa+Kv+f3Sv+/0n/wAb o/4Vr4q/5/dK
/wC/0n/xui+W/wDP78f+AF8V/J/X3nrUnjfw6yEJqaBuCMwyY/8AQawj4h0M HCXkO3t+9lH/
ALRrgv8AhWvir/n90r/v9J/8bo/4Vr4q/wCf3Sv+/wBJ/wDG6qFXL4bVvx/4 BMliXvA6zXtc
0WXwtrUK3sXmS2MqqA0jljtJA5jUDJA5/wD11l+Kv+Rnn/68YP8A0Oaud1T4 f+JLLSL26nvN
NaGGB5JAkshYqFJOMp1wK6LxV/yM8/8A14wf+hzVrKdCdNujPm/pCiqikudW /pnRfCL/AJBG
u/8AYWP/AKTwV6HXnnwi/wCQRrv/AGFj/wCk8Feh15j3OtbHAQvs8W6h72Nr /wCjLitQTszi
ONWeQ9FXr/8AWrCkfZ4tvvextv8A0ZPW3pU5jSYiISmaXYiqxDZCg8/7PPXt +NeZiqP1jMZw
7JP8InVRl7PCxl3b/Nizyy2rgTqoB/iRtwH14FKJ8jIORUepXItUZ7rTigPA Zbgtyem7nge9
cfrkzN4A1xWYMws7xcjpwHHFcmLwNSjFVJJJNpaO/wCZtQrQqNxWrSudp5/v R5/vXh/jDw7r
WkeAtRtLjXXuNFsWjNjCB+9dWkQBJmxyqAnaB1JB4Cqo19R8b6lF4wggtrny oP7Yi0+SxuZI
97IygGRYxGHCEnKuZDk44wcDlVByV6cr7/hb/M1cknaSsep/2lbfbfsX2mH7 X5fm+RvHmbM4
3beu3PGemam8/wB68T+G97JdeJ9MuJVhV28PygiGFIl4vX6KgCj8BXrfn+9Z 4hexnyXLpR54
8xo+f70ef71nef70ef71h7U09kaPn+9Hn+9Z3n+9Hn+9HtQ9kaPn+9Hn+9Z3 n+9Hn+9HtQ9k
aPn+9Hn+9Z3n+9Hn+9HtQ9kaPn+9Hn+9Z3n+9Hn+9HtQ9kaPn+9Hn+9Z3n+9 Hn+9HtQ9kaPn
+9Hn+9Z3n+9Hn+9HtQ9kaPn+9Hn+9Z3n+9Hn+9HtQ9kaPn+9Hn+9Z3n+9Hn+ 9HtQ9kR+J5s+
E9ZGetjP/wCizXNeKv8AkZ5/+vGD/wBDmrW8RzZ8MasPWym/9ANZPir/AJGe f/rxg/8AQ5q+
oyOXNhqnr/keTj48tWJ0Xwi/5BGu/wDYWP8A6TwV6HXnnwi/5BGu/wDYWP8A 6TwV6HXW9zFb
Hl9++zxbd+9jb/8Aoyenx3dxB5n2e5eHzMbiirk/iQTUGp2eo3fi26+wR2r7 bG33+fM0eMyT
4xhGz39KT+x/EP8Az76X/wCBsn/xmvKzDBZg8bOthlo0tbxXRd33R34XEYT6 tGnWeqvpZ935
CTC4uFKy6ldsCMEEpz/47TrONLK1S3jZii5wWIzySe31pP7H8Q/8++l/+Bsn /wAZo/sfxD/z
76X/AOBsn/xmuOvgs5rxUKqut/ij/mb0sRl1J3g7P0f+RY8+jz6r/wBj+If+ ffS//A2T/wCM
0f2P4h/599L/APA2T/4zXL/YmYfyf+TR/wAzf+0MJ/N+D/yLHn0efVf+x/EP /Pvpf/gbJ/8A
GaP7H8Q/8++l/wDgbJ/8Zo/sTMP5P/Jo/wCYf2hhP5vwf+RY8+jz6r/2P4h/ 599L/wDA2T/4
zR/Y/iH/AJ99L/8AA2T/AOM0f2JmH8n/AJNH/MP7Qwn834P/ACLHn0efVf8A sfxD/wA++l/+
Bsn/AMZo/sfxD/z76X/4Gyf/ABmj+xMw/k/8mj/mH9oYT+b8H/kWPPo8+q/9 j+If+ffS/wDw
Nk/+M0f2P4h/599L/wDA2T/4zR/YmYfyf+TR/wAw/tDCfzfg/wDIsefR59V/ 7H8Q/wDPvpf/
AIGyf/GaP7H8Q/8APvpf/gbJ/wDGaP7EzD+T/wAmj/mH9oYT+b8H/kWPPo8+ q/8AY/iH/n30
v/wNk/8AjNH9j+If+ffS/wDwNk/+M0f2JmH8n/k0f8w/tDCfzfg/8ix59Hn1 X/sfxD/z76X/
AOBsn/xmj+x/EP8Az76X/wCBsn/xmj+xMw/k/wDJo/5h/aGE/m/B/wCRY8+j z6r/ANj+If8A
n30v/wADZP8A4zR/Y/iH/n30v/wNk/8AjNH9iZh/J/5NH/MP7Qwn834P/Ise fR59V/7H8Q/8
++l/+Bsn/wAZo/sfxD/z76X/AOBsn/xmj+xMw/k/8mj/AJh/aGE/m/B/5Fjz 6PPqv/Y/iH/n
30v/AMDZP/jNH9j+If8An30v/wADZP8A4zR/YmYfyf8Ak0f8w/tDCfzfg/8A Ira/Nnw5qg9b
SX/0A1B4q/5Gef8A68YP/Q5qNd0rXY/D2pvNBpoiW1lLlLtywGw5wDEMn8RR 4q/5Gef/AK8Y
P/Q5q+kybB18Lh5xrxs2+6fbs2eRmFelWqxdJ3+/9TovhF/yCNd/7Cx/9J4K 9Drzz4Rf8gjX
f+wsf/SeCvQ63e5itjz6N9ni3UPextf/AEZPU895eiRhbWazIvG4s4+bHfaj ccr743cZCh6E
z7PFt772Nt/6MnrQgCSGAmOJs3LBt1i82R5R4JU8j/Z6969OpZK7/rQ44aux mzeI7iF2VrNF
IOMM8mR6bsRnHVc4zjD4zhd+pY6it9Zx3KAqHz8p6jBIIPvxz/XrWXN9mW2t 1+xwPK0dnknS
nYEGTDEnpnHU9GHArInmuP8AhCtYFkJFudl6IBbqVYNvk2hAOQc4wB04qIzh K6je672LqU5Q
Sbtqdn53vUNxqVtaeV9puYYfOkEUXmOF3ueijPUnsBzXmGkat4d0XwEuoaXD ZSavBpKGcacI
vtQO1QzNwSAGILFgQMZIOMVg3HiK/wBV1Szsby+t76Ky8Rac0M8MqSgh0ckb 0RFYAr/dBBJG
Tik5pWJUWz3PzvejzvevGdP8YeJZ9Nur641rTYbhbW9aXTpJE8+GRA5TZD5Y ZSpTkOz5XJPN
F14y8S6fp0nk3j3s03h6DUw0tuhaGRpFVyoRVG0Kxb5gcbQTxkE9pG1w5Gew R6lbTXM9tFcw
vcW+3zolcFo9wyu4dRkcjPWpvO968Vt9fGma34turTU5r4XFxp0C6ikkIVNy sC8jiMxqg5Un
Yew6nNSaZ4v8S6vqGnaZBrNvE0t9qFqbpYUnV0jjR43yAoYjccEBQeCVPIIp r+vWw+Rns3ne
9Hne9Z/ne9Hne9a8hnzGh53vR53vWf53vR53vRyBzGh53vR53vWf53vR53vR yBzGh53vR53v
Wf53vR53vRyBzGh53vR53vWf53vR53vRyBzGh53vR53vWf53vR53vRyBzGh5 3vR53vWf53vR
53vRyBzGh53vR53vWf53vR53vRyBzEfiaXPhTWB62M3/AKAa53xV/wAjPP8A 9eMH/oc1afiK
bPhjVh62c3/oBrM8Vf8AIzz/APXjB/6HNTmrU3/XYcHeR0Xwi/5BGu/9hY/+ k8Feh1558Iv+
QRrv/YWP/pPBXodeU9ztWx5dqD7PFt172Nv/AOjJ6hlN08itDql5bKp3BIWU Luxjdyp5wcU/
VLLUbvxbdfYI7V9tjb7/AD52jxmSfGMI2e/pTf7G8Q/8++l/+Bsn/wAZr2rR aVzzveT0K/2e
62hf7b1HACKBuj4C/dH3O1T2ca2dsIVkkk+ZnLyEbmLMWJOAB1Jpf7G8Q/8A Pvpf/gbJ/wDG
aP7G8Q/8++l/+Bsn/wAZoSgtmD5mTed70ed71D/Y3iH/AJ99L/8AA2T/AOM0 f2N4h/599L/8
DZP/AIzT93uKz7E3ne9Hne9Q/wBjeIf+ffS//A2T/wCM0f2N4h/599L/APA2 T/4zR7vcLPsT
ed70ed71D/Y3iH/n30v/AMDZP/jNH9jeIf8An30v/wADZP8A4zR7vcLPsTed 70ed71D/AGN4
h/599L/8DZP/AIzR/Y3iH/n30v8A8DZP/jNHu9ws+xN53vR53vUP9jeIf+ff S/8AwNk/+M0f
2N4h/wCffS//AANk/wDjNHu9ws+xN53vR53vUP8AY3iH/n30v/wNk/8AjNH9 jeIf+ffS/wDw
Nk/+M0e73Cz7E3ne9Hne9Q/2N4h/599L/wDA2T/4zR/Y3iH/AJ99L/8AA2T/ AOM0e73Cz7E3
ne9Hne9Q/wBjeIf+ffS//A2T/wCM0f2N4h/599L/APA2T/4zR7vcLPsTed70 ed71D/Y3iH/n
30v/AMDZP/jNH9jeIf8An30v/wADZP8A4zR7vcLPsTed70ed71D/AGN4h/59 9L/8DZP/AIzR
/Y3iH/n30v8A8DZP/jNHu9ws+xN53vR53vUP9jeIf+ffS/8AwNk/+M0f2N4h /wCffS//AANk
/wDjNHu9ws+xV16XPh3Ux62kv/oBqLxV/wAjPP8A9eMH/oc1Gu6Trsfh7UpJ oNNES2spcpdu
zABDnAMQyfxFHir/AJGef/rxg/8AQ5qitb2en9bGlK/NqdF8Iv8AkEa7/wBh Y/8ApPBXodee
fCL/AJBGu/8AYWP/AKTwV6HXjvc7lsefRvs8W6h72Nr/AOjJ61UMsgJjilcA 4JRCwz+FYUz7
PFt772Nt/wCjJ6peI5gtlZTySD7PDPMZYXHySZjQDnI+YE5A7jd+PfiaipQ5 3toc1Cm6s+Rb
nUkzr1tbr8Ld/wDCo0ulkUlSeGKnIwQQcEEHoQQRVew1y6l8N6ZJC1wGMAV8 jJLLlSf9W2QS
Mj2xXL3M9yfBes/YzL9qK33k+Tnfv3ybduOc5xjFKlJzjzdAqR5JcvU7Lzve jzvevIbbVdL0
b4bC/wDDSaUfEEOlwmY28cbzqDsEjOF5+XO47uMgZptz4s1o6g9lY629xYHW rK0h1JI4XZ0l
jYyoGCeWSpCnhcjPOafOkTys9g873o873rxKTV72+8TaRNqeqPbQ6Zq2pWP9 p7YkKqI1Kbyy
+WGPI+6MgcDPNa2o+NtRi8YQQW1z5UH9sRafJY3Mke9kZQDIsYjDhCTlX8w5 OOMHAOdBys9X
873o873rxLVdXvfEHww1aS91R5tWZS1xpKrEPsqpcrk7AvmAKqjO5jwcmtbx F4r1DTbvSxYa
2dR06WPDvZT2pvJXaXaCEKFZAOVARQchtxGKOdbhys9X873o873rP873o873 rXkI5jQ873o8
73rP873o873o5A5jQ873o873rP8AO96PO96OQOY0PO96PO96z/O96PO96OQO Y0PO96PO96z/
ADvejzvejkDmNDzvejzves/zvejzvejkDmNDzvejzves/wA73o873o5A5jQ8 73o873rP873o
873o5A5iPxNLnwprA9bGb/0A1zvir/kZ5/8Arxg/9DmrT8RTZ8MasPWzm/8A QDWZ4q/5Gef/
AK8YP/Q5qc1am/67Dg7yOi+EX/II13/sLH/0ngr0OvPPhF/yCNd/7Cx/9J4K 9Drynudq2PLt
QfZ4tuvext//AEZPUM0aTk7pblQeoiuZIwfwVgKfqllqN34tuvsEdq+2xt9/ nztHjMk+MYRs
9/Sm/wBjeIf+ffS//A2T/wCM17VotK55zvfQrnT7Zust4frezf8AxVWbZIrS AQwghASfmYsc
kkkkkknkmk/sbxD/AM++l/8AgbJ/8Zo/sbxD/wA++l/+Bsn/AMZppQXVC94m 873o873qH+xv
EP8Az76X/wCBsn/xmj+xvEP/AD76X/4Gyf8Axmj3e4WfYm873o873qH+xvEP /Pvpf/gbJ/8A
GaP7G8Q/8++l/wDgbJ/8Zo93uFn2JvO96PO96h/sbxD/AM++l/8AgbJ/8Zo/ sbxD/wA++l/+
Bsn/AMZo93uFn2JvO96PO96h/sbxD/z76X/4Gyf/ABmj+xvEP/Pvpf8A4Gyf /GaPd7hZ9ibz
vejzveof7G8Q/wDPvpf/AIGyf/GaP7G8Q/8APvpf/gbJ/wDGaPd7hZ9ibzve jzveof7G8Q/8
++l/+Bsn/wAZo/sbxD/z76X/AOBsn/xmj3e4WfYm873o873qH+xvEP8Az76X /wCBsn/xmj+x
vEP/AD76X/4Gyf8Axmj3e4WfYm873o873qH+xvEP/Pvpf/gbJ/8AGaP7G8Q/ 8++l/wDgbJ/8
Zo93uFn2JvO96PO96h/sbxD/AM++l/8AgbJ/8Zo/sbxD/wA++l/+Bsn/AMZo 93uFn2JvO96P
O96h/sbxD/z76X/4Gyf/ABmj+xvEP/Pvpf8A4Gyf/GaPd7hZ9ibzvejzveof 7G8Q/wDPvpf/
AIGyf/GaP7G8Q/8APvpf/gbJ/wDGaPd7hZ9irr0ufDupj1tJf/QDUXir/kZ5 /wDrxg/9Dmo1
3Sddj8PalJNBpoiW1lLlLt2YAIc4BiGT+Io8Vf8AIzz/APXjB/6HNUVrez0/ rY0pX5tTovhF
/wAgjXf+wsf/AEngr0OvPPhF/wAgjXf+wsf/AEngr0OvHe53LY8+jfZ4t1D3 sbX/ANGT1pea
2x3CuyoNzlVJ2j3xWLM+zxbe+9jbf+jJ60otRs7TT7s3ySPA7RIdhIwcsQcj pyBzkc49a9DE
S9nBz8kctGDqVFBdQXU4mMo+YCJQzsPmUKc8llyB91up7GrHne9cvqV1BPb6 jqOnmWOzt4XH
mtM7NOwGdoLE4QEc+p49a1ZjFcQSQzRpLFIpR0cBlZSMEEHqCKxws51YXl/w 5piaSoy5evVd
jT873o873ryHw/NZ+HdC8aatbad/pFrql3DE1pCglSP5MKpKkBFPzdCAATg4 xVf/AITTxAbX
WoINX02Y2d1a+XcteQAvG6sXSOUokRb5OMpwN/3iBWvOluZcr6HsH9pW3237 F9ph+1+X5vkb
xv2Zxu29cZ4z0zU3ne9eEy+JtT/4SCz1i0W7WW48PqJ7q7iV5LSJro7p9iKo kCjkYAyuGIxm
uluPFOpQeOLDT11L7bpk/wBnSE2E1u8pypZnmj2FiG4JZNihMEc8UKaYOLPU fO96PO96z/O9
6PO9615COY0PO96PO96z/O96PO96OQOY0PO96PO96z/O96PO96OQOY0PO96P O96z/O96PO96
OQOY0PO96PO96z/O96PO96OQOY0PO96PO96z/O96PO96OQOY0PO96PO96z/O 96PO96OQOY0P
O96PO96z/O96PO96OQOY0PO96PO96z/O96PO96OQOYj8TS58KawPWxm/9ANc 74q/5Gef/rxg
/wDQ5q0/EU2fDGrD1s5v/QDWZ4q/5Gef/rxg/wDQ5qc1am/67Dg7yOi+EX/I I13/ALCx/wDS
eCvQ688+EX/II13/ALCx/wDSeCvQ68p7natjy7UH2eLbr3sbf/0ZPTZZZ3ie KK8lgjkG2RUV
GEg9DuU8cn86TVLLUbvxbdfYI7V9tjb7/PnaPGZJ8YwjZ7+lN/sbxD/z76X/ AOBsn/xmvaag
4pSPPvJO6Kb6e0lobRtRu/spXYYAI1Xb6cJmtLzveof7G8Q/8++l/wDgbJ/8 Zo/sbxD/AM++
l/8AgbJ/8ZojGEdFYTc5O7JvO96PO96h/sbxD/z76X/4Gyf/ABmj+xvEP/Pv pf8A4Gyf/Gaf
u9xWfYm873o873qH+xvEP/Pvpf8A4Gyf/GaP7G8Q/wDPvpf/AIGyf/GaPd7h Z9ibzvejzveo
f7G8Q/8APvpf/gbJ/wDGaP7G8Q/8++l/+Bsn/wAZo93uFn2JvO96PO96h/sb xD/z76X/AOBs
n/xmj+xvEP8Az76X/wCBsn/xmj3e4WfYm873o873qH+xvEP/AD76X/4Gyf8A xmj+xvEP/Pvp
f/gbJ/8AGaPd7hZ9ibzvejzveof7G8Q/8++l/wDgbJ/8Zo/sbxD/AM++l/8A gbJ/8Zo93uFn
2JvO96PO96h/sbxD/wA++l/+Bsn/AMZo/sbxD/z76X/4Gyf/ABmj3e4WfYm8 73o873qH+xvE
P/Pvpf8A4Gyf/GaP7G8Q/wDPvpf/AIGyf/GaPd7hZ9ibzvejzveof7G8Q/8A Pvpf/gbJ/wDG
aP7G8Q/8++l/+Bsn/wAZo93uFn2JvO96PO96h/sbxD/z76X/AOBsn/xmj+xv EP8Az76X/wCB
sn/xmj3e4WfYm873o873qH+xvEP/AD76X/4Gyf8Axmj+xvEP/Pvpf/gbJ/8A GaPd7hZ9irr0
ufDupj1tJf8A0A1F4q/5Gef/AK8YP/Q5qNd0nXY/D2pSTQaaIltZS5S7dmAC HOAYhk/iKPFX
/Izz/wDXjB/6HNUVrez0/rY0pX5tTovhF/yCNd/7Cx/9J4K9Drzz4Rf8gjXf +wsf/SeCvQ68
d7nctjz5H2eLdQ97G1/9GT1o+d71izvs8W3vvY23/oyerXn+9es43/A4Lmh5 3vR53vWf5/vR
5/vS5A5jQ873o873rP8AP96PP96OQOY0PO96PO96z/P96PP96OQOY0PO96PO 96z/AD/ejz/e
jkDmNDzvejzves/z/ejz/ejkDmNDzvejzves/wA/3o8/3o5A5jQ873o873rP 8/3o8/3o5A5j
QM2BVr7He/8APA/99r/jWHJNmN+exrbt9aErpCVdXORkjjI6jr1rxc1x88HK Kj1OzC0PbJvs
V5nltp0hniaN5FZkyQchSAehP94U3zzkKAzMeyKWP5CoNbuS2r2GT0gn/wDQ oqNN8m41MJPG
kiiFyA6gjO5fWtqGLlLB/WJb/wDBsKVFKt7MnFwCSOQw4IIII+oNL53vUWpG xiU7bS2B9fKX
/Cuf0W/+0fbwMAR3RQAcADYh4H41ngc0jiqvsVHVK9y8RhHRp+0vodJHLcTz vDa2ktw0aqzl
GQABiQPvMP7pqnHrEU12LSIwyXRJAhS9ty5IGT8okzwAc/SrOmag2nwa5fJA 9w9vaRyLFGMs
5HmnArhPDXg65bV7Lx5f3kP2+5WWeSCJQERJIyFC47jdzXa5TdTlRiox5bs7 m0v472zgu4ST
FPGsiZGDtYZH86jn1iwtZGjuL62hdVDsskqqQpO0EgnoTwD68Vi+Grjd4V0c +tlCf/HBVDxD
oEuvXcMv22OFIYnSNPI3Es/DFjn5l2/wdCeTu6V08rtdGN1ezN7xLNu8Kaxz 1sZv/QDXP+Kv
+Rnn/wCvGD/0Oapr20j0rwLfafE8jxw2EqKZHLNjYepNQ+Kv+Rnn/wCvGD/0 OanNWpP+uwQf
v/15nRfCL/kEa7/2Fj/6TwV6HXnnwi/5BGu/9hY/+k8Feh15b3O1bHluovs8 W3XvY2//AKMn
pfO96dq2nC81dr621qxt90CQsksXmfdZyCCJFx98/lVT+yrr/oY9L/8AAQ// AB6vYVSnZXke
e4TvsWfO96PO96rf2Vdf9DHpf/gIf/j1H9lXX/Qx6X/4CH/49T9pS/mQuSfY s+d70ed71W/s
q6/6GPS//AQ//HqP7Kuv+hj0v/wEP/x6j2lL+ZByT7Fnzvejzveq39lXX/Qx 6X/4CH/49R/Z
V1/0Mel/+Ah/+PUe0pfzIOSfYs+d70ed71W/sq6/6GPS/wDwEP8A8eo/sq6/ 6GPS/wDwEP8A
8eo9pS/mQck+xZ873o873qt/ZV1/0Mel/wDgIf8A49R/ZV1/0Mel/wDgIf8A 49R7Sl/Mg5J9
iz53vR53vVb+yrr/AKGPS/8AwEP/AMeo/sq6/wChj0v/AMBD/wDHqPaUv5kH JPsWfO96PO96
rf2Vdf8AQx6X/wCAh/8Aj1H9lXX/AEMel/8AgIf/AI9R7Sl/Mg5J9iyZsjGa rzLNPKJXvp/M
HR1WNT+i0n9lXX/Qx6X/AOAh/wDj1H9lXX/Qx6X/AOAh/wDj1YV6GEr29raV u5pTnXp/BdDx
5puEmmvJ52RGRRJtwASCegH90U6QrL1aRTgjMcjIcHqMgj0FRf2Vdf8AQx6X /wCAh/8Aj1H9
lXX/AEMel/8AgIf/AI9VQp4aEPZxty9ugpOtKXM73KU2hadO26U3jH/r/nH/ ALPVrTrG00qG
SKzR0WR/MffK0hLYAzliT0A/Kn/2Vdf9DHpf/gIf/j1H9lXX/Qx6X/4CH/49 ThDDQd4WXov+
AEnWkrSuyVpbtHZ7TUrmzLgK/krGd2M4zvVvU9Mdapvbag4I/wCEi1MKSSVV LcDnk/8ALKp/
7Kuv+hj0v/wEP/x6j+yrr/oY9L/8BD/8eqr0b35vzF+8tawtjFHp+n21lEzG O3iWJC5ySFAA
z78VU1vR7HX7Vbe+RiqOGVkcqw55GRzg9D/+qrX9lXX/AEMel/8AgIf/AI9R /ZV1/wBDHpf/
AICH/wCPU+ai1bmQuWpe9inqyx2/hW/t4lCxpZyqqgYAGw07xQpbxROB/wA+ MH/oc1S3WhT3
dnPbSeJNMCTRtGxW1OQCMHH76rusaWmo6sb631uxg3QJCySxeZ91nIIIkX+/ +lTUnTceVSX9
WKpxkndowvDPivU/CMWo2sGjW19HdXf2kSPetCV/dRpt2iJv+eec571uf8LX 1j/oVrP/AMGr
f/GKoHw7IT/yMWl/+Ap/+PUf8I4//QxaX/4Cn/49XF7GP8yOn2j7HozWsBJz Ev5Uz7Hbf88U
/KiiuNmwfY7b/nin5Uhsrb/nin5UUVDGJ9itv+eKflR9itv+eKflRRUjE+xW 3/PFPyo+xW3/
ADxT8qKKQw+xW3/PFPyo+xW3/PFPyoooAPsVt/zxT8qPsVt/zxT8qKKAD7Fb f88U/Kj7Fbf8
8U/KiigA+xW3/PFPyo+xW3/PFPyoooAPsVt/zxT8qPsVt/zxT8qKKAD7Fbf8 8U/Kj7Fbf88U
/KiigA+xW3/PFPyo+xW3/PFPyoooAPsVt/zxT8qPsVt/zxT8qKKAD7Fbf88U /Kj7Fbf88U/K
iigA+xW3/PFPyo+xW3/PFPyoooAPsVt/zxT8qPsVt/zxT8qKKAP/2Q==
Content-ID: <part2.09070200.04070400@hotpop.com>
CACQAO0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
q/8A142f/oy5rqa3xH8R/L8kZ0vgCiiisDQz9aAOmkNnBmhBwcdZFHUVj3cN tAwkDTiRQQrf
aJMjPvurfv7NL+0a3eSSMFlYPHjcpVgwIyCOoHauKutH07UGcp4k8RuoJBa1 t1kXPsRAQfwN
cWLoVqlvZOxtSnCPxlrw7q0s/ix7Dz5XhNm8u15WfkOgz8xOPvH864f4oeLd Zh8X3EehTakU
8N2UV5LHZxz+U9w00bGO5KfKYvIVm5IH3hu6iu78J+FtMsdRfWrPV9TvpTC9 sVvQi7AWVjlR
GjA/IvXsfeulbSdNZ7120+0L36BLxjCubhQpUCTj5wFJGDng4rbDU6lOko1H dk1ZRlNuCsjz
+P4jard6x4mn0+10268P6LZQ6gJGaSKeaKS0eZQoIIyWC8kDaueGJ4x/FV5r 2r+FfAOqXt5p
vn6hrumXFssNk6LAzo7YfMxMgBI6FOh9ePWLLSdN015HsNPtLV5EjR2ghVCy ou1AcDkKvAHY
cCqdt4T8N2e37L4f0qDbKk48qyjXEiZ2PwPvLubB6jJx1rczPM/Fni7WtS+E niq7W9k0/UtE
1htPa405jCLgJNGucEs0YIkGQGzleuCVr2Ssufw1oN1by29xommzQS3BupI5 LVGV5iMGQgjB
cjjd1rQgghtbeK3t4o4YIkCRxxqFVFAwAAOAAOMUAcdp1odU8KabcrO7alqM H9pPbLqMln57
ybCxMkYMm2NXCKOQF2Kc4UjN0ma5ka116+u5tQs7iWwxNHqs0EkTyxQKqvaJ +6GZHDsN33ZO
jcA9kfDmlS2stpd2cN5aPcvdLBdxLKkcjklioI7sztzkjeQMDAFqTS9Pl1KL UpLG2e/iXZHd
NCplReeA+MgfM3Ge59a9P67Bcy11v8le9t/6/vKyUcrM7w3/AKO2raYn/Htp 98Ybcf3Y2ijm
CegVTKVUAABVUdsncqppunxaZYraws7gM8jvIQWkd2LuxwAMszMcAADPAAwK t1w1pqc3Jf8A
D+fz3KWwUUUVkMKKKKACiiigAooooAjn/wBSfw/nUUdSz/6k/h/Ooo6T3Ayv Gf8AyIuvf9g+
f/0A15x4q/5Gef8A68YP/Q5q9H8Z/wDIi69/2D5//QDXnHir/kZ5/wDrxg/9 DmrtofwZf12M
J/GjovhF/wAgjXf+wsf/AEngr0OvPPhF/wAgjXf+wsf/AEngr0OuR7my2OW8 P/8AI26v/wBe
Nn/6Mua6muW8P/8AI26v/wBeNn/6Mua6mtsR/Efy/JEUvgCiiisDQrahA9zp t1BGcPJC6KfQ
kECuNnvNG0HT7aS2sL0xtEs939luZFFtG2BvYbufmPQc4DHtXcu6xozuwVVG SzHAArkLvw0m
rTn7NeaFcRRMWiFzpouZIdxLYD+aOMnjih3asnYzqKTXu7ljwtCh1nXLmBpD BuhtxvlZ8sql
yQWJ/wCeo/KuE129uR4i+Jt5Jr2pWR0O3srjTtl+8cUUpgLBfLJ8tw7qqlWU 53EDk16noulD
SLFoDKJpZJXmlkCbQzMc8DJwBwByeAKZN4a0G51QapPommy6gHVxdvao0oZc bTvIzkYGDnjA
qpNN3RUU0tTzu28f+OdT1O4stM8NQT3WnWmny3tq6iMtJPGJJFLyTIYcAlQN kpyvzYzWHoXi
rV9F1vVNF0WyjuLvVvFurHcyCQqsSRsQqNJECTuHJkGAp4JIr2DUvDWg6zcL capomm306oEW
S6tUlYLknALAnGSTj3NE/hrQbq3lt7jRNNmgluDdSRyWqMrzEYMhBGC5HG7r UlHn+j6t4vv/
AIq6bbak0elTnw4J77TWdriAsLsozIFkCq7KAQx3bQcHdUeg/EjxdqWht4ol 8OQPoH2S9uWK
OkRh8neY1D+azSZ2FCfKTBORkDn0RfDWgqlki6JpoSwcvZqLVMW7FgxMfHyE sAcjHIzRD4a0
G21Q6pBommxagXZzdpaospZs7jvAzk5OTnnJoA838IX+pat8XNO1TVJbR577 wbHdKtrA0Sxq
86tsO53LEEn5sjPHArD8Z6jqenS/FSS01jVYm0/+zPsgXUJsQecyNJsG7C5P p0BIGASK9k03
w1oOjXDXGl6JptjOyFGktbVImK5BwSoBxkA49hQnhrQY7i7uE0TTVnvUdLqR bVA06ucuHOMs
GPJBznvQBxev+LPGNj4mh8MaRZWOo6mulPqMkyW21JD5pRFCPcL5ajAy29yc 8Lway9X+Jfib
TH8T3UthpsEHh9NNeewdGklc3KoZI/OVwoKksAwRgeOPX0Sbwn4buLO2s5vD +lSWtru+zwvZ
RlItxy21SMLk8nHWpD4a0E29xbnRNN8i4SJJ4/sqbZVjAEYYYwQoACg9McYo A4O/8d+LLGfx
HpdtpMGrX+jXdkjz2Nq5/cTpvZxbeYWdlxjAkGdwJwFOe08H64viXwnYawlz HcC6Rm8xLZoB
kMQV2M7kFSNp+YgkEg4IqxeeGtB1F53vtE026ed0eZp7VHMjIpVC2RyVUkAn oCQK0IIIbW3i
t7eKOGCJAkccahVRQMAADgADjFAHF2SR3vhfSLh5L2XUtWi+3m1tbt7fzZZF VizyJh1iiDBA
SSAuxcO3lip9Qiu7GTT7s6vNeXMFza2l7cLclBGzNEm0Wq/uz5nmEkudyCTc pbaijYbwros6
NHeadbXsXnyzxpdwJKIWkO6QJuGQGfLHJPJx0AAtpoulR3VtdJplktzaxCG3 mWBQ8MYBARDj
KrgkYHHJr0ni6fNdXtrpbv032to9PXmVkRys5+y0ddXS7Md/qD6XcwFPtM1y ZHuJshluYQ2V
hCEEoUCqxbcFCpGW3PD2oS6t4a0rUp1RZruzhnkWMEKGdAxAyScZPrVV/B/h 8Wtzb2uk2ViL
qIwTvZ28cTyREjfGWC52sBg455yCCARuVhiK0JxtHXXr00+d7/pppZJpWCii iuQojn/1J/D+
dRR1LP8A6k/h/Ooo6T3AyvGf/Ii69/2D5/8A0A15x4q/5Gef/rxg/wDQ5q9H 8Z/8iLr3/YPn
/wDQDXnHir/kZ5/+vGD/ANDmrtofwZf12MJ/GjovhF/yCNd/7Cx/9J4K9Drz z4Rf8gjXf+ws
f/SeCvQ65HubLY5bw/8A8jbq/wD142f/AKMua6muW8P/API26v8A9eNn/wCj LmuprbEfxH8v
yRFL4ArgLy8uo72wRNO0+S1ksy8srtl2f918zfuzhhl8Lu+bkkjFd/WVJ4Y8 PzSvLLoemPI5
LMzWkZLE9STjk1nCST1Kkm9jPsnafwDo7zO7tJb2e9yx3Ekx5OeueetMu4ba BhIGnEighW+0
SZGffdW7qFpDc6e8EkrQRDa3mIQNm0hgeQR1A6iual8JWuqs3leKtVbH3hBL bnH/AJCNefjK
Nao17J2OijKEfjI/DurSz+LHsPPleE2by7XlZ+Q6DPzE4+8fzqvrdzc6b4o1 26try7jC2Wm7
i1w7xWqS3Msc86xsTGpWKMNuK4GwkggtnU0DwPaaBrDaomp6leTmBoMXTRlQ rMrEjYinOUHf
1rcj0nTYdUm1SLT7RNQmTZLdrColdeOGfGSPlXgnsPStcLTqU6SjUd2TVlGU 24qyI9M0a10j
zfs0t9J5uN32u/nucYzjHmu23r2xnjPQVw+o2g1L4War4hvLm+fVJ9EuXuYv tsywwymB1eLy
A3ljyzuTBXcCnzEvlj3GmaFo+ieb/ZOlWNh52PM+yW6Rb8ZxnaBnGT19TUc/ hrQbq/lv7jRN
NmvJUKSXElqjSOpTYQWIyQV+XHpx0roMzh38aa/FJfRabpcdxFp73VxdPJIp VkF5cxqpkmuE
8kbbcncBIBu4RQoVjxD4o16Hwrq149xaLBcvqtjarawvFPbNAl0UlMvmEMcW 3QKvLgg/Lg95
NoWj3EttLNpVjJJaytPbu9uhMUjNvZ1JHysW+Ykck89asLYWaeXttIF8qV54 8RgbJH3bnHox
3vk9Tub1NAHN3ura9pWpabb38tolnI8Uc2ox6e7xzzSSlFhCLMWgONo8xt6E vztICt1lZdt4
a0GyuLa4tNE02Ce1QpbyRWqK0KksSEIGVBLuSB/ePqa1KACiiigAooooAKKK KACiiigAoooo
Ajn/ANSfw/nUUdSz/wCpP4fzqKOk9wMrxn/yIuvf9g+f/wBANeceKv8AkZ5/ +vGD/wBDmr0f
xn/yIuvf9g+f/wBANeceKv8AkZ5/+vGD/wBDmrtofwZf12MJ/GjovhF/yCNd /wCwsf8A0ngr
0OvPPhF/yCNd/wCwsf8A0ngr0OuR7my2OW8P/wDI26v/ANeNn/6Mua6muW8P /wDI26v/ANeN
n/6Mua6mtsR/Efy/JEUvgCiiisDQz9aAOmkNnBmhBwcdZFHUVj3cNtAwkDTi RQQrfaJMjPvu
re1G2iu7GSKaZoUyrmRSAV2sGB5BHUd65mXwla6qzeV4q1VsfeEEtucf+QjX Di6Nao17J2Nq
U4R+Mj8O6tLP4sew8+V4TZvLteVn5DoM/MTj7x/OjUda1W28bzaPayWivepa JazSxyOsAKXk
jb4/MAcn7MQCuw/OM7tgBuaB4HtNA1htUTU9SvJzA0GLpoyoVmViRsRTnKDv 61qT+HtNvLi/
mv7aO+F8kUcsV0ivH5cZLIgUjBAZnfJycsecBQNsLTqU6SjUd2TVlGU24qyO DTxDrCap4i1+
J7Ef2XpS/bYGt3P2r7Nc3yHy28weVu8pjyJNu4fe2/N1FnbPc+KGvNPvr6SC CWRb2ea5Z4Zj
hlFvFFnyx5Z27pFUEGPYS7NLt1H8NaDJcWlw+iaa09kiJayNaoWgVDlAhxlQ p5AGMdqIfDWg
22qHVINE02LUC7ObtLVFlLNncd4GcnJyc85NdBmWI72d9UmtG0y7jgRNy3rN F5Uh4+VQHL55
PVQPlPPTPn9v4i1Lwpol3qMotLzT5NT1gRWqxNFKjRvdz5aXcwYHyWXAQY3g 5O3DemVXWws0
8vbaQL5Urzx4jA2SPu3OPRjvfJ6nc3qaAPL9e8T+IrOG3uNVsIIb7TJZb233 rGnmf6BfEBoo
55SFzF94uN2SABsJPeaPf6l/bN9pGqS2lxPbW8F0txawNApWVpV2FGdzkGEn du53AYGMkufC
GgzaDdaNBplpZWlykoItIEjKNJGYmdcLgPsYrnHTjpxWhpuk6bo1u1vpen2l jAzl2jtYViUt
gDJCgDOABn2FAHm914l1pLvQvEbR2lw+o6PI1jZwwFWgNxcWKqrs0uJSvmr/ AM8g208ruyup
N4s8S22kyT31lBYLZyyi/v2tluRboscbqXtobhnTcJDyHfaEDEBXynWJ4a0G O4u7hNE01Z71
HS6kW1QNOrnLhzjLBjyQc570L4a0FUskXRNNCWDl7NRapi3YsGJj4+QlgDkY 5GaAOf8ABOpT
SXN9pzrHBFHe6jJGJAd9zm+ly6EHARM7WHLZcZCDYZO0quthZp5e20gXypXn jxGBskfducej
He+T1O5vU1YoAKKKKACiiigAooooAjn/ANSfw/nUUdSz/wCpP4fzqKOk9wMr xn/yIuvf9g+f
/wBANeceKv8AkZ5/+vGD/wBDmr0fxn/yIuvf9g+f/wBANeceKv8AkZ5/+vGD /wBDmrtofwZf
12MJ/GjovhF/yCNd/wCwsf8A0ngr0OvPPhF/yCNd/wCwsf8A0ngr0OuR7my2 OW8P/wDI26v/
ANeNn/6Mua6muW8P/wDI26v/ANeNn/6Mua6mtsR/Efy/JEUvgCuAvLy6jvbB E07T5LWSzLyy
u2XZ/wB18zfuzhhl8Lu+bkkjFd/WVJ4Y8PzSvLLoemPI5LMzWkZLE9STjk1n CST1Kkm9jPsn
afwDo7zO7tJb2e9yx3Ekx5OeueetMu4baBhIGnEighW+0SZGffdW7qFpDc6e 8EkrQRDa3mIQ
Nm0hgeQR1A6iual8JWuqs3leKtVbH3hBLbnH/kI15+Mo1qjXsnY6KMoR+Mj8 O6tLP4sew8+V
4TZvLteVn5DoM/MTj7x/Oqapql5421j7HHqpkttVtlS6N/izhgEFu8sRgMnL MrS4IiPzSKdw
IyuxoHge00DWG1RNT1K8nMDQYumjKhWZWJGxFOcoO/rXSRwQwvM8UUaPM++V lUAu20LlvU7V
UZPYAdq1wtOpTpKNR3ZNWUZTbirI870/x14iubG3u7rSoLaHVIoJLBpfLHl+ dNDEvyrO7zqo
uFYtth+6AQpkG3Qi17xJd+Iz4ehutKiurb7R9ou3sZHSXYlo67YxMCnF3g5d s7M8ZwOoi0LR
4ft3laVYx/2hn7btt0H2nOc+Zx8+dzdc/ePrWfc+CPDd3LYedo1i9rYRTRW9 kbWMwJ5rIzME
K4DZTgjH3m65roMzh9K8X6zeXdy+h6XuutXlXUWXYk/koLGwyuHmgB5mHzbv 4funOV9M0m9b
UtGsb94o4nubeOZo45lmVSyg4Drw4GfvDg9RUd9oWj6nFJFf6VY3cckondJ7 dJA0gUIHII5Y
KAueuBjpWhQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHP8A6k/h/Ooo6lmG YiB1JH86riaK
M4eaJT7uKVm3oBm+M/8AkRde/wCwfP8A+gGvOPFX/Izz/wDXjB/6HNXofi+e GXwNr4jljcjT
58hWBx8hrzzxV/yM8/8A14wf+hzV20ValK/9bGE/jR0Xwi/5BGu/9hY/+k8F eh1558Iv+QRr
v/YWP/pPBXodcj3Nlsct4f8A+Rt1f/rxs/8A0Zc11Nct4f8A+Rt1f/rxs/8A 0Zc11NbYj+I/
l+SIpfAFFFFYGhn60AdNIbODNCDg46yKOorHu4baBhIGnEighW+0SZGffdW5 qlulzp8kTmcD
crAwAF9wYEYyCOoHXiuXl8J/2lMUl1jxHbEjI/499p/ERnH44rgxlKrUa9k0 mb0pQj8QeHdW
ln8WPYefK8Js3l2vKz8h0GfmJx94/nUms291Y+IY9VvmnuNNe7toojBqc9u1 uXdIlQ26YjmX
zW3Mztna5XBCKDY0DwPaaBrDaomp6leTmBoMXTRlQrMrEjYinOUHf1rY/sLR /wC2P7X/ALKs
f7T/AOf37Onnfd2/fxu+7x16cVvhadSnSUajuyKsoym3FWRwdr458UXWnW12 +nWlmmqJbS2L
3CIRGstxBH9xLgvMAtxndiHBVcj58LoWuq69eePLXS2vrRHsEu47xkt38q6U CxkBWPzf3bhZ
yoYs+MMcfNgdZDoWj28tzLDpVjHJdSrPcOlugMsitvV2IHzMG+YE8g89akm0 nTblw8+n2kri
4W6DPCrETKoVZOR98KAA3UAAV0GZxfxBae2vLi6tr2+gkj8NapOohvJY0EkY iCPsVgpYea+D
jPIPVVxJrXiXxRpF69nBaWmoPYWSX17cJEkETq7ygLmW5XyAFhOX/e9Sdoxh uwk0nTZtUh1S
XT7R9QhTZFdtCplReeFfGQPmbgHufWq6+GtBVLJF0TTQlg5ezUWqYt2LBiY+ PkJYA5GORmgD
j7nxlr1rFfXbHTXggTU7tIhbOG8mxn8poy3mEb5AykPjCbT8j546DTNZ1Kfx VdabqSR2Y2Sy
WlobVi0sKOqCYXAcoQdwJjKq67xngBm2H0nTZEdH0+0ZHSVGUwqQyytulB45 DsMsP4jyc0We
k6bp9xdXFlp9pbT3b77mSGFUaZsk5cgZY5YnJ9T60AXKKKKACiiigAooooAK KKKACiiigBsn
3R/vD+dcHfeJYLG/+y3qSW8Zh8yK4f7khA+ZRjuOPc/lnu5SRGSFLEEHA6nm uRvNKiu4Vt7q
EzxowYB7SYjI6H7n+ckdK6cO0r3MqlzC1DUm1HwDrt39nlgD2EwQSYyyZADf iP8AJGCcjxV/
yM8//XjB/wChzV0/iK1kPg/X8CTnT5esMiAADcTllHp29a5jxV/yM8//AF4w f+hzV1Npwlb+
tjFX5lf+tzovhF/yCNd/7Cx/9J4K9Drzz4Rf8gjXf+wsf/SeCvQ6817nUtjw vx2NSPi0f2fY
3d1/oMW/7PC0m395LjO0HHf8q53HiP8A6Aeq/wDgHJ/hXq8L7PFuoe9ja/8A oy4rT8/3r3Fi
HBKNjzXTUne54rjxH/0A9V/8A5P8KMeI/wDoB6r/AOAcn+Fe1ef70ef70/rb /lF7FdzxXHiP
/oB6r/4Byf4UbfEn/QD1b/wDk/wr2rz/AHp6T8da5MbmksNS9oopm1DCKrPl ueJbfEn/AEAt
W/8AAOT/AAo2+JP+gFq3/gHJ/hXtpugN2NzbRltqlsD3x0pVuQwyrAj1FeU+ JKySbpK3zOxZ
XBuykeI48R/9APVf/AOT/CjHiP8A6Aeq/wDgHJ/hXstzqCW2C4lbJOBFE0h/ JQT6AepIA5IB
rnXLUdrk+m21lbPpjC854xjrvTGd6592OPvFNpHA8PZ2PIseI/8AoB6r/wCA cn+FSWw1lJ2l
uvDutTYhdYkWGWNVdhgOwCndt644r2C21KG7VmhcsFOCSpH06jkEYIPcEEcE Ezef71TxfMvh
J9jZ7nj0Yv4/I/4pbX38m0aL5vOO+ds/vW+TkDPCew560Ri/j8j/AIpbX38m 0aL5vOO+ds/v
W+TkDPCew5617D5/vR5/vUe2X8v4srk8/wAjx6MX8fkf8Utr7+TaNF83nHfO 2f3rfJyBnhPY
c9aIxfx+R/xS2vv5No0Xzecd87Z/et8nIGeE9hz1r2BrlUUszBQOpJxQtyHU MrBlPIIOQaPb
rbl/FhyPv+B4tjxH/wBAPVf/AADk/wAKMeI/+gHqv/gHJ/hXtXn+9J9pX+8P zq3jbbpEqhfY
8Wx4j/6Aeq/+Acn+FGPEf/QD1X/wDk/wr2hbtGYqsikjsDTvP96FjG9UkDoW 3Z4rjxH/ANAP
Vf8AwDk/wox4j/6Aeq/+Acn+Fe1ef70ef70/rb/lF7FdzxXHiP8A6Aeq/wDg HJ/hRjxH/wBA
PVf/AADk/wAK9kl1G2gYLNcxRsRkB3AOPxpn9sWP/P7b/wDf1f8AGl9d8kP2 HmePY8R/9APV
f/AOT/CjHiP/AKAeq/8AgHJ/hXtK3KuoZWDKwyCDkEUvn+9P62/5Q9iu54bf DX/7PufO0fU4
4vKbe72kgVVwckkjgV3Pir/kZ5/+vGD/ANDmrpPE82fCesjPWxn/APQDXN+K v+Rnn/68YP8A
0Oas69V1Kd2rf0jSlDlkdF8Iv+QRrv8A2Fj/AOk8Feh1558Iv+QRrv8A2Fj/ AOk8Feh14z3O
5bHnEj7PFt972Nt/6Mnq353vWXfPs8W3fvY2/wD6Mnp/ne9exy3see3qaPne 9Hne9Z3ne9Hn
e9HILmNHzvel80ttRdxLOq4XqckDA96zfO96Vbh0ZHjbDo6uDnuCD6H0ry82 5Y0Yue3NG/pc
7cAnKo1HezOqkubGCHyY7kRqRnCQluffnr9eawbq4igv7ZbaYSrMT5hVcAfK SM8nk4+tD+Ib
6OMxWtnbIhySWnYsSepJ28msRvts2qR3MggiiDl3SNydzbSM4wOea8qvLLpU pzVT3rO2r3tp
5HfShi1OMXDS+uxvNiVbh/KeRobeSQBVQgEY5O/jH05pl1oVvc3hSS0u1xce UFUWykjyt+OO
N2efTHvWbc3M6wyrb21pO0iNGRckgID/ABDAPzDHFV5rq+nkLPoehFTL5mws SPubcY8vp3+t
e9T9t7KPs3bRfkjzb0lUfPtdj9FWC2vZRAsipLZW0x8wIMlvMPG3jHTrzV3V tTuLKCy8lYli
lnlWeYxRyOmI1KAB+xY4z6kevOXp0VxDcyzTw2sIMEUKJbsSPk3cnKjruqTU Ipb6A2++3ERJ
P7yNy3IAIyrrwdo49qqvCtUp6ay8yaU6UamukTq7bULKfRLG7Om2U7TwK7sk JIDdx8qNjB4+
uaxNKujJZyM2P+Pm4AAGAAJXAA9sVmRx6hFbR2yT6cIogQimxLYycnkyE9ST +NT2EbWdoInl
Ejl3dmVdoJZyxwMn19aqjRcUuZakVaik3y7HUNBBc6ZalbuC2mHmMxZDubkg HKspGBnv/Kua
t7ny5oAhR7d7qQJOI9jSsVZmxycoDnqTz6Yqtqqy38UUK2kKmLKi4W6ZHdSx YqQEIxknvnv3
IpCb25ubHzbe0t7ezYlFhlZ/4GUDBUY+9+lcsMLU9u5yVl+Z1zrUVQUY6yf4 en9aG+8+I2IP
ODXSxarFKFCyIWK52hhn8q4oy5UjPUVE97fLcrNbwW8ZUk7WmLDnr/BnB9K4 M6wuJqSg6Eb9
wwU6ST9o7HQa7c79XsPaCf8A9CiqOzjS9v1idiFETP8AdVuQVHRgR3rElvLy 8voZrmKCNYon
QeXIWJLFD3UY+7UgurmCXzrWWOOTYyZdCwwSD0yPSt8Pha6wHs2vf7fMidSm sRdPQ2ru0gtQ
zJczrnnaNgH5beKytO1E3X2oFiRDOYwTjP3VPOPrWPeDxBdsf+JxZqp7fYCf /alLotlPpkNy
Li7W5lnnMxZYvLA+VVxjcf7ueveoy7DY+Fa9f4LbXNMTVw0qdqfxX7HZaJfQ WMmr3t1II4IL
aJ5HPYAyk1574bufF+o+MLbxEbrU4/DFy05itZ7lnwnlttZl9C2MfhXQ/wBo XNsl3FFYWl7B
eRLFKlzOYxgbuMBGyDu9ulU01TXYLCOxt9M01beJPLjDajISqjgDPk9hx+Fe h7Buo29jnVVK
CSLfhucHwtpBHQ2UP/oArH8Uxa3c6hGdJF6sYgImaO6CK5z8qou4bXB5LdNv BD/dq9o8Mmn6
JYWUrK0lvbRxMUPBKqAce3FQ63HqtzaqNI1FbO4DjLPEsisueeD39P8AJHS6 fumHN7xLevfJ
4Evo9TmjmvBYSiWSNNqsdh5x/n6DpVXxV/yM8/8A14wf+hzU/V3kTwpqEcsp lkFlKGcgAsdh
54AH5U3xSM+J58f8+MH/AKHNTqK1L+vIqm7z/rzOh+EX/II13/sLH/0ngr0O vH/APjDRfDNp
rFpq011DNNqHnRhLGeUMhghXO5EI6qw69q67/hafhH/n+vP/AAV3X/xuvJa1 O1bHP61aakPE
Ul1a6bPdQyWkUe6KSIYZXlJBDup6OKqeXrP/AEAb3/v9b/8Ax2u2bQ4yTi5u R9Jn/wAab/YK
f8/dz/3+f/Gu1Y+ytynM8Nd3ucX5es/9AG9/7/W//wAdo8vWf+gDe/8Af63/ APjtdn/YSf8A
P3df9/n/AMaP7CX/AJ+7r/v83+NH9oL+UPqvmcZ5es/9AG9/7/W//wAdpfL1 n/oA3v8A3+t/
/jtdj/Ya/wDP3df9/m/xpP7DX/n7uv8Av83+NcuMrUsXS9lVjob4eE8PPng9 Tj/L1n/oA3v/
AH9t/wD47R5es/8AQBvf+/tv/wDHa7D+w1/5/Lr/AL/N/jR/Ya/8/l1/3+b/ ABryf7MwH8j+
9nd9exXdfccd5es/9AG9/wC/1v8A/HaPL1n/AKAN7/3+t/8A47XY/wBhr/z+ XX/f5v8AGj+w
1/5/Lr/v83+Ne7DHxhFRUdjzJYZybbe5x3l6z/0Ab3/v9b//AB2jy9Z/6AN7 /wB/rf8A+O12
P9hr/wA/l1/3+b/Gj+w1/wCfy6/7/N/jVf2kv5Sfqnmcd5es/wDQBvf+/wBb /wDx2jy9Z/6A
N7/3+t//AI7XY/2Gv/P5df8Af5v8aP7DX/n8uv8Av83+NH9pL+UPqnmcd5es /wDQBvf+/wBb
/wDx2jy9Z/6AN7/3+t//AI7XY/2Gv/P5df8Af5v8aP7DX/n8uv8Av83+NH9p L+UPqnmcd5es
/wDQBvf+/wBb/wDx2jy9Z/6AN7/3+t//AI7XY/2Gv/P5df8Af5v8aP7DX/n8 uv8Av83+NH9p
L+UPqnmcd5es/wDQBvf+/wBb/wDx2jy9Z/6AN7/3+t//AI7XY/2Gv/P5df8A f5v8aP7DX/n8
uv8Av83+NH9pL+UPqnmcd5es/wDQBvf+/wBb/wDx2jy9Z/6AN7/3+t//AI7X Y/2Gv/P5df8A
f5v8aP7DX/n8uv8Av83+NH9pL+UPqnmcd5es/wDQBvf+/wBb/wDx2jy9Z/6A N7/3+t//AI7X
Y/2Gv/P5df8Af5v8aP7DX/n8uv8Av83+NH9pL+UPqnmcd5es/wDQBvf+/wBb /wDx2jy9Z/6A
N7/3+t//AI7XY/2Gv/P5df8Af5v8aP7DX/n8uv8Av83+NH9pL+UPqnmcLqNl rd5pd3ax6Fdh
5oXjUtNBgEqRz+896veIdN1KbxA9zbadNdQPaRR7o5IxhleQkEO6nowrrP7D X/n8uv8Av83+
NH9hr/z+XX/f5v8AGplmCkrOJUcM46pnnbaJqzHP9hXf/f23/wDjlJ/Yerf9 AK7/AO/tv/8A
HK9F/sNf+fy6/wC/zf40f2Gv/P5df9/m/wAay+tU/wCUv2c+5//Z
--------------050102050105060100000007--
Re: Trying to find a widget that behaves like widget in Outlook 2003 [message #447751 is a reply to message #447652] Thu, 16 December 2004 22:41 Go to previous message
<html>
<head>
<title></title>
</head>
start...<br>
<br>
compile)<br>
<br>
/**<br>
&nbsp;*/<br>
}<br>
<br>
<br>
<br>
<br>
<br>
<br>
}<br>
<br>
<br>
Daniel<br>
</font><br>
<pre wrap="">Hi,
far.
with icons
what it looks like.
as how to start
and if so
thanks,
Parwiz
</pre>
</blockquote>
</body>
</html>
Previous Topic:Custom Look and Feel in SWT
Next Topic:Control over SWT Browser Widget ?
Current Time: Sat Jul 19 00:21:04 EDT 2025
Powered by FUDForum. Page generated in 0.03255 seconds
