Home » Eclipse Projects » Rich Client Platform (RCP) » problem with JOGL in RCP
problem with JOGL in RCP [message #446505] Tue, 21 March 2006 07:52 Go to next message
Originally posted by: vze3gfkr.verizon.net
I am trying create a view in my RCP program that can display an opengl
view. I have the tried the code snippet 209 and everything works well.
however I cannot seem to get this to work under my RCP program. within
the view class I have added the following code under the
createPartControl method.
public void createPartControl(Composite parent) {
parent.setLayout(new FillLayout());
GLData data = new GLData ();
data.doubleBuffer = true;
final GLCanvas canvas = new GLCanvas(parent.getShell(), SWT.NONE, data);
canvas.setCurrent();
final GLContext
context=GLDrawableFactory.getFactory().createExternalGLConte xt();
initialize3DWindow(context,canvas); // initialize the 3D window
create3DWindow(context,canvas); // draw the 3D object
The code compiles fine but i don't see anything. Is there any code
examples on how to do this with RCP or any documentation. Any help would
be greatly appreciated.
thanks
Fintan Mac Cormack
Re: problem with JOGL in RCP [message #446645 is a reply to message #446505] Wed, 22 March 2006 12:25 Go to previous messageGo to next message
Originally posted by: dittmar.steiner.web.de
Hi Finatan,
although I don't have experience with JOGL, in my oppinion it could be a problem with the composite hierachy.
Please try to simply insert a Composite:
Composite top = new Composite(parent, SWT.NONE);
top.setLayout(new FillLayout());
But I may be totally wrong. I took this code from a project where I create the content for an EditorPart.
best regards
Dittmar
Re: problem with JOGL in RCP [message #446649 is a reply to message #446505] Wed, 22 March 2006 14:39 Go to previous messageGo to next message
any errors about missing native libs in your .log ?
/Stepan
Re: problem with JOGL in RCP [message #446652 is a reply to message #446645] Wed, 22 March 2006 15:02 Go to previous messageGo to next message
Hi Dittmar
I tried what you suggested but the view still does not display the 3D
image. I am able to get the program to partially work by changing the
code to the following.
Shell shell = parent.getShell();
shell.setLayout(parent.getLayout());
final GLCanvas canvas = new GLCanvas(shell, SWT.BORDER, data);
final GLContext
shell.open();
window
However this messes up the remainder of the gui such as menubar coolbar
etc. however i am able to see part of the 3D image. Also the code only
works when i add the line
shell.open();
regards
fintan
Dittmar Steiner wrote:
> Hi Finatan,
> best regards
> Dittmar
Re: problem with JOGL in RCP [message #446653 is a reply to message #446649] Wed, 22 March 2006 15:04 Go to previous messageGo to next message
for the reply Stephen i dont see any message in the error log.
regards
fintan
Stepan Rutz wrote:
> /Stepan
Re: problem with JOGL in RCP [message #446654 is a reply to message #446652] Wed, 22 March 2006 15:57 Go to previous messageGo to next message
you seem to be messing around with the Shell of Eclipse. The shell is a
the desktop-window of your eclipse rcp/ide. It's not a good idea to mess
around with it.
Have you tried to remove all these calls to the shell and just do the
following:
final GLCanvas canvas = new GLCanvas(parent, SWT.BORDER, data);
final GLContext
Note that I pass "parent" to the GLCanvas constructor, not
parent.getShell().
parent.getShell() is something you want to leave alone.
Stepan
fintan Mac Cormack wrote:
> Hi Dittmar
> final GLContext
> shell.open();
> window
> shell.open();
> regards
> fintan
>> Hi Finatan,
>> best regards
>> Dittmar
Re: problem with JOGL in RCP [message #446655 is a reply to message #446654] Wed, 22 March 2006 16:34 Go to previous messageGo to next message
Hi Stephen I tried your example but still no luck.
regards
fintan
Stepan Rutz wrote:
> around with it.
> following:
> final GLContext
> parent.getShell(). parent.getShell() is something you want to leave alone.
> Regards,
> Stepan
>> Hi Dittmar
>> final GLContext
>> shell.open();
>> window
>> coolbar etc. however i am able to see part of the 3D image. Also the
>> code only works when i add the line
>> shell.open();
>> regards
>> fintan
>>> Hi Finatan,
>>> best regards
>>> Dittmar
Re: problem with JOGL in RCP [message #447528 is a reply to message #446505] Sun, 09 April 2006 13:32 Go to previous messageGo to next message
Hi Fintan and to everyone in the forum
I'm trying to build a RCP application that should use jogl package to open a OpenGL View.
Reading your post, I supposed that you managed to setup correctly RCP to interact with jogl, even if then you have got problems.
Please, could you report the procedure you used to setup you RCP application with jogl package?
I try this
1) I created 2 folder /lib and /native in the root application folder (at the same level of plugin.xml file)
2) then I added the jogl.jar file in the Java Build Path/Library with the Native Library Location pointed to the <application>/native folder (but I read that this doesn't work in RCP, is correct?)
3) I add the Bundle-NativeCode in the MANIFEST.MF
4) I check the /lib and /native folder in the Build/Binary Build tab (I can see the 2 folder in the jar generated)
When I build all is ok, but at runtime when I made the first call to a jogl method I got this error
java.lang.NoClassDefFoundError: javax/media/opengl/GLDrawableFactory
So it's clear that the application cannot resolve the class.
At runtime I added this test code just to see if the library is correctly added/loaded:
[this is a method of a generic view]
final GLCanvas canvas = new GLCanvas(parent, SWT.NONE, data);
final GLContext ctx = GLDrawableFactory.getFactory().createExternalGLContext();
Any help is welcome
Thanks all for the attention
Cheers
Ludovico Cellentani
Re: problem with JOGL in RCP [message #447589 is a reply to message #447528] Tue, 11 April 2006 08:46 Go to previous messageGo to next message
http://eclipsewiki.editme.com/PDEFaq - use this list to add 3rd party
libraries to a plugin.
If you find yourself using Java Build Path>Libraries tab, it won't work.
Later,
PW
Re: problem with JOGL in RCP [message #447731 is a reply to message #447589] Thu, 13 April 2006 12:55 Go to previous message
Thanks for you reply
I will take a look! :)))
Ludovico Cellentani
Previous Topic:how to export an plug-in by ant build?
Next Topic:How to register action in EditorActionBarContributor
Current Time: Tue Sep 16 22:15:52 EDT 2025
Powered by FUDForum. Page generated in 0.07665 seconds
