Home » Eclipse Projects » Standard Widget Toolkit (SWT) » how to embed openoffice
how to embed openoffice [message #447288] Mon, 13 December 2004 06:09 Go to next message
I've been using the Openoffice.org OfficeBean to embed OpenOffice in a
AWT application. Well, I used that app only to test OO-embedding and now
I'm looking for a decent java window toolkit.
AFAIK, it should theoretically be possible to embed OO in SWT (it isn't
in Swing, because Swing uses non-native-drawing-routines), the only
thing is: I have no idea how. Obviously, many widgets expect a
shell-parameter which notices the shell to draw them, but of course the
O.o O-Bean does not expect a shell-parameter in it's constructor beause
it is used to the process that the layout manager is explicitly told to
show this new widget.
Is there a way to get AWT-Components to work in SWT? If there was, maybe
that would be similar to the solution for my OO-problem? Or does anybody
happen to know how to embed OpenOffice?
thanks,
Jochen
Re: how to embed openoffice [message #447304 is a reply to message #447288] Mon, 13 December 2004 08:31 Go to previous messageGo to next message
You can embed AWT in SWT using the SWT_AWT class. See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet135.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
See also this SWT FAQ about support for AWT in SWT:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#swinginswt
"Jochen Staerk" <jstaerk@usegroup.de> wrote in message
news:cpjt97$2bi$1@www.eclipse.org...
> I've been using the Openoffice.org OfficeBean to embed OpenOffice in a AWT
> application. Well, I used that app only to test OO-embedding and now I'm
> AFAIK, it should theoretically be possible to embed OO in SWT (it isn't in
> Swing, because Swing uses non-native-drawing-routines), the only thing is:
> I have no idea how. Obviously, many widgets expect a shell-parameter which
> notices the shell to draw them, but of course the O.o O-Bean does not
> expect a shell-parameter in it's constructor beause it is used to the
> process that the layout manager is explicitly told to show this new
> widget.
> thanks,
> Jochen
Re: how to embed openoffice [message #447623 is a reply to message #447304] Wed, 15 December 2004 07:32 Go to previous messageGo to next message
thanks, I figured out how to embed AWT components, unfortunately, the
OfficeBean does not seem to be compatible to SWT
(Exception in thread "main" java.lang.RuntimeException: assertion failed
at com.sun.star.beans.LocalOfficeWindow.getNativeWindow(Native Method)
at
com.sun.star.beans.LocalOfficeWindow.aquireSystemWindow(Loca lOfficeWindow.java:171)
at
com.sun.star.beans.LocalOfficeWindow.setVisible(LocalOfficeW indow.java:226)
at swt1.BasicOfficeBean.load(BasicOfficeBean.java:187)
at swt1.Snippet137.main(Snippet137.java:30)
thanks a lot anyway.
bye
Jochen
Re: how to embed openoffice [message #447627 is a reply to message #447623] Wed, 15 December 2004 10:27 Go to previous messageGo to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Hello Jochen,
do you have any idea what this incompatibility could be?
Jörg.
Jochen Staerk schrieb:
> Method)
> at
> at
> bye
> Jochen
Re: how to embed openoffice [message #447643 is a reply to message #447627] Wed, 15 December 2004 16:08 Go to previous message
Joerg von Frantzius wrote:
> Hello Jochen,
I think I've already seen this when I tried to get the officebean
directly on a Swing JForm. I'd guess that maybe the officebean does not
get a native window handle in the format it expects, if it gets one at
all, but that's wild guessing right now.
Besides, this is not related to the fact that the SWT/AWT bridge does
not work correctly on linux with jdk 1.4.2, I upgraded to 1.5.0 to get
Veronika's Snippet 135 working.
My source is (LocalOfficeConnection, SimpleBean and dependant files are
taken from the OO-SDK):
package swt1;
import org.eclipse.swt.widgets.Composite;
import java.awt.Frame;
import com.sun.star.beans.LocalOfficeConnection;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.*;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.layout.GridLayout;
import java.io.IOException;
public class Snippet138 {
final Display display = new Display();
final Shell shell = new Shell(display);
Composite comp = new Composite(shell,SWT.EMBEDDED);
Frame frame = SWT_AWT.new_Frame(comp);
SimpleBean rv = new SimpleBean();
rv.setOfficeConnection(new LocalOfficeConnection());
// this next command causes a getNativeWindow-Assertion
try {
rv.load("private:factory/swriter");
} catch (IOException ex) {
ex.printStackTrace();
frame.add( rv );
frame.setVisible(true);
// seems as if SOME sort of layout is needed
GridLayout layout = new GridLayout(1, false);
shell.setLayout(layout);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
bye
Jochen
Previous Topic:Good books for SWT and JFace
Next Topic:Open an file when clicking a TableTreeViewer
Current Time: Fri Jul 25 19:45:40 EDT 2025
Powered by FUDForum. Page generated in 0.04608 seconds
